Volkswagen logo on engine lid of a 64 Ghia vert
passoa55 Premium Member
passoa55 is offline
PostPosted: Sat Nov 09, 2013 7:22 am    Post subject: Volkswagen logo on engine lid of a 64 Ghia vert Reply with quote
Hi, can someone tell me if the 6 holes are correct for a 64 small Volkswagen logo.
It looked Original but all the Volkswagen badges that I found had 4 tabs but none of the tabs are mathing with the holes......
Can someone tell me what I need.
The enine lid was mathing to the car and was Original paint.....
Thanks for your help! Wink
Vintage only!
1950 Hebmuller #458
1952 zwitter vert (sold)
1952 december zwitter
1955 original paint oval
1956 1600 super V-sunroof Porsche
1963 firetruckred 23 window
1969 original paint Westy
1969 Karmann Ghia
1970 one owner 1300L bug
Rome
Rome is offline
PostPosted: Sat Nov 09, 2013 8:40 am    Post subject: Reply with quote
I also have a '64 Cabriolet. It has its factory-original engine lid and the correct VOLKSWAGEN emblem. I just measured the length of the emblem along the continuous line along the bottom- it's 215mm long.
The one you have is most likely from a mid '60's Bus, such as seen here. I know from experience that the bus emblem is at least a few centimeters longer-
http://www.thesamba.com/vw/archives/lit/1968_bus_comes_in_a_box/3.jpg
I also checked the underside of my Ghia's engine lid. The emblem is attached using only 4 holes.
So the engine lid you have is most likely from a '66 and later Ghia which had the "slanted" VOLKSWAGEN emblem. Like this one, from theSamba gallery of an original '66 Ghia-
If your emblem is also 215mm long, then you have the right one, but the later engine lid.
Here's a VW press photo of a '65 Ghia which would have the same emblem as on my car/what your should have.
http://www.thesamba.com/vw/archives/pressphotos/65ghia_2a.jpg
Another shot from theSamba gallery showing the correct emblem; this one is also a '65-
passoa55 is offline
PostPosted: Thu Nov 14, 2013 3:03 pm    Post subject: Volkswagen logo Reply with quote
Just want to know if the 6 holes are correct.
The 2 left ones are correct.
It will be painted within 2 weeks and want to know if a VOLKSWAGEN logo exist with 6 tabs.
Thanks for your help. Wink
Vintage only!
1950 Hebmuller #458
1969 Karmann Ghia
walkerman
walkerman is offline
PostPosted: Fri Nov 15, 2013 1:17 pm    Post subject: Reply with quote
Is your car an autostick? They have a "Volkswagen autostick" emblem that goes there
retrowagen
retrowagen is offline
PostPosted: Fri Nov 15, 2013 2:16 pm    Post subject: Reply with quote
His '64 wouldn't have had a "Autostick" (though the Saxomat semi-auto was a rare factory option, predating the '68-up factory Autostick transmission).
David Ruby
President, Karmann-Ghia World Club
walkerman
PostPosted: Fri Nov 15, 2013 5:18 pm    Post subject: Reply with quote
True….but could the engine lid havr come from a later ghia?
NWGhiaGuy Premium Member
NWGhiaGuy is offline
PostPosted: Fri Nov 15, 2013 7:04 pm    Post subject: Reply with quote
The correct emblem has 4 posts.
Peter_KG
Peter_KG is offline
PostPosted: Tue Dec 01, 2015 5:04 am    Post subject: Re: Volkswagen logo on engine lid of a 64 Ghia vert Reply with quote
Hi,
The engine lid on my '63 is an older one I suppose (no holes for the Volkswagen emblem). I bought an emblem on a swapmeet but it's 29 cm long (4 pins)... That emblem should be for a bus then?
I was searching on the www where to drill the holes, couldn't find it though... Someone knows?
Thanks !!
VW Karmann Ghia '63
VW Kupla Dickholmer '64
VW Bubbla Oval '54
NOVA Airhead
NOVA Airhead is offline
PostPosted: Tue Dec 01, 2015 7:43 am    Post subject: Reply with quote
The Autostick emblem was something done at the dealership. Not all dealerships put them on.
The Autostick emblem used the same mounting holes as the Volkswagen emblem.
Ghia Owner Emeritus
passoa55 is offline
PostPosted: Tue Dec 01, 2015 2:04 pm    Post subject: Re: Volkswagen logo on engine lid of a 64 Ghia vert Reply with quote
Thanks for the info! Wink
Car is finished now!
Vintage only!
1950 Hebmuller #458
1969 Karmann Ghia
c21darrel
c21darrel is offline
PostPosted: Tue Dec 01, 2015 3:38 pm    Post subject: Re: Volkswagen logo on engine lid of a 64 Ghia vert Reply with quote
That is a beautiful convertible, well done.
GhiaBuild
Rome
Rome is offline
PostPosted: Tue Dec 01, 2015 4:46 pm    Post subject: Re: Volkswagen logo on engine lid of a 64 Ghia vert Reply with quote
passoa, great that you have the Ghia finished! Engine lid looks very nice with the "petite" VW badge. Have you been able to drive it since completion?
Even though the title of your thread is "64 Ghia", you actually have a 1965 model year based on the heater levers next to the handbrake. So most likely the car was first registered in 1964, but built as of Aug. 1 1964 to be a '65 model year.
passoa55 is offline
PostPosted: Tue Dec 01, 2015 10:41 pm    Post subject: Re: Volkswagen logo on engine lid of a 64 Ghia vert Reply with quote
Thanks, yes the Ghia comes out from time to time with good weather.
This is my dad's car.
Yes it is a late 64.
Base was pretty solid.
It was a bolt to nut restoration.
I've done 2 others already, also a 64 Manilla yellow vert and a 67 Savannahbeige vert.
Vintage only!
1950 Hebmuller #458
1969 Karmann Ghia
BostonVWFanatic
BostonVWFanatic is offline
PostPosted: Fri Dec 04, 2015 5:41 am    Post subject: Re: Volkswagen logo on engine lid of a 64 Ghia vert Reply with quote
Good luck on your restoration! I love the older underlined VW script. I have that on my '65 Convertible.
Dash76
Dash76 is offline
PostPosted: Mon Dec 05, 2016 2:22 pm    Post subject: Re: Volkswagen logo on engine lid of a 64 Ghia vert Reply with quote
Great looking restoration!
Did you ever get a clear answer about the holes in the engine lid? I have a '69 KG with a similar pattern of holes, but the correct badge only has 3 thicker pins.
c21darrel
PostPosted: Mon Dec 05, 2016 2:47 pm    Post subject: Re: Volkswagen logo on engine lid of a 64 Ghia vert Reply with quote
The discussion was regarding 64-65 ghias with the petite volkswagon script. A 69 would have the more common larger volks script. Over the decades... plenty of VW's have extra or incorrect holes in them.
69...
64-65
GhiaBuild
Dash76
Dash76 is offline
PostPosted: Tue Dec 06, 2016 1:32 am    Post subject: Re: Volkswagen logo on engine lid of a 64 Ghia vert Reply with quote
Thanks C21darell. I have the correct script, just not on the car, and may just need to consider drilling new holes.
I was mainly just curious since the holes seem to be similar to those on my car. I thought it'd also be nice to know a bit more about the history of my car i.e. engine lid from another model, etc.
paul_round Premium Member
paul_round is offline
PostPosted: Tue Dec 06, 2016 6:46 am    Post subject: Re: Volkswagen logo on engine lid of a 64 Ghia vert Reply with quote
Darrel, what about 66-68?
c21darrel
PostPosted: Tue Dec 06, 2016 11:26 am    Post subject: Re: Volkswagen logo on engine lid of a 64 Ghia vert Reply with quote
Difficult to really know if your hood is the original one or if it was replaced at some time. I admit to have removed and replaced some rear scripts in the 80's. They had these really cool "California Special" scripts on late 60's Mercury Cougars that I may or may not have moved over to a ghia once Embarassed .
I guess you could sand it down to see what lies under the paint Crying or Very sad
what about 66-68?
Hi Paul. Same as the 69 script above.
GhiaBuild
