AirKooledGarage Samba Member
Joined: September 28, 2012 Posts: 314 Location: Wisco
Posted: Sat Jan 03, 2015 8:18 pm Post subject: |
Sorted alternator rebuild. Fresh everything.
Install did not go so well. Unknowingly flipped pulley around, but Samba folks got me sorted.
Next up was Pertronix distributor and Bosch wires.
Still need to sort a bracket for the oil pressure switch and wire the distributor. Heat exchangers are at sand blast and then I'll be ready for a set of dual Kadrons. Stoked to finally be on the tail end of this build. |
Posted: Fri Oct 02, 2015 2:51 pm Post subject: |
Job change put the kybosh of forward moment for a bit, but I'm back at it now.
Scored some detail parts. Surprisingly difficult to get. Thanks to German Supply for making these happen.
And finally had time to install carbs from Kaddie Shack. Jeff has been really helpful and responds quickly to every dumb question I've emailed him. Good company to deal with.
Using the original power brake crossover tube, so it'll need to go to powder. SVDA distributor needs a vacuum line and everything needs clamps. Kit is pretty thorough although the plastic breather lines are suspect.
Couple of things to tidy up and waiting on clutch kit before it goes back in. Should be soon, though! |
Posted: Fri Oct 02, 2015 7:19 pm Post subject: |
One last missing piece of tin. Saw a couple in the classified, hoping to score one this week.
obieoberstar Samba Member
Posted: Fri Oct 02, 2015 7:47 pm Post subject: |
Good to see this engine coming along. Just thought I would throw in a tip regarding that throttle linkage.
It works, but the design of the linkage makes it difficult to sync the 2 carbs easily. After almost 2 years I broke down and bought a linkage kit from Jeff at KS. LT and RT hand threaded rods make dialing in the carbs a breeze. Plus, your engine is on the stand and that would make setting it up a breeze compared to when it is installed.
Had to do some modifications, but am really happy with it. |
Pinetops Samba Member
Posted: Sat Oct 03, 2015 3:37 am Post subject: |
It's coming along nicely. _________________ "A rolling bus gathers no rust." |
1967250s Samba Member
Posted: Sat Oct 03, 2015 12:06 pm Post subject: |
Nice looking engine. You'll need a clamp on the oil filler tube, along with an grommet in the sheetmetal. And you'll need the cork gaskets for the new heat exchanger closers.
PS you should run the #1 and 3 spark wires under the cross rod. _________________ '72 Elm Green Deluxe |
Posted: Sat Oct 03, 2015 12:24 pm Post subject: |
Thanks! Got the clamp, have not found the oil filler grommet or the cork for heat exchanger closers.
Any suggestions?
1967250s wrote: |
PS you should run the #1 and 3 spark wires under the cross rod. |
Posted: Sat May 28, 2016 5:44 pm Post subject: Re: 1973 Bay Window Rescue - Long term project |
Scored one of Boat Yard Bus's billet taco plates. Easy install and nice home for temp sensor. Had to shorten dipstick by 1/4" though.
Posted: Wed Jun 22, 2016 10:34 pm Post subject: Re: 1973 Bay Window Rescue - Long term project |
This project is endless, but makes me smile whenever I work on it. Finally time to install motor, had to get creative getting it off the stand
It went in pretty easily after that (dropped the trans a few inches to line things up). Now onto the peripherals.
Posted: Sun Mar 12, 2017 7:40 pm Post subject: Re: 1973 Bay Window Rescue - Long term project |
Five years in, probably built ten bikes since I started the bus project and last summer moved from Cali to chilly Wisconsin. Finally getting back in the groove. Dash wiring was pretty rough, most it needed love. Wrapped ignition switch, all switches and tidied up the mess that PO had left behind the dashboard. Special thanks to Busdaddy for all the help along the way.
If you're working on your dash, buy this tool!
JP6210 Samba Member
Joined: October 14, 2015 Posts: 119 Location: Beaufort, NC
Posted: Sun Mar 12, 2017 7:58 pm Post subject: Re: 1973 Bay Window Rescue - Long term project |
And what is that tool for? _________________ '76 Chrome Yellow Westy "Tallula" |
Intersmashable Samba Member
Joined: June 08, 2016 Posts: 13 Location: Alberta, Canada
Posted: Mon Mar 13, 2017 8:15 am Post subject: Re: 1973 Bay Window Rescue - Long term project |
Nice build! I see you used a vanagon motor as your core and ended up going with carbs....do you still have any of the EFI bits and interested with parting with any?
Thanks! _________________ 1978 Sage Green panel, 2.0 FI |
Posted: Mon Mar 13, 2017 8:22 am Post subject: Re: 1973 Bay Window Rescue - Long term project |
Thanks! Dropped off both motors to the builder and got one good one back, EFI stuff is long gone.
Intersmashable wrote: |
Thanks! |
Posted: Mon Mar 13, 2017 8:30 am Post subject: Re: 1973 Bay Window Rescue - Long term project |
Oldbikedoc wrote: |
Thanks! |
Darn! Thanks anyway! Keep up the good work, nice to see the interest of your young one. My 7 yr old likes my 78 panel bus too. _________________ 1978 Sage Green panel, 2.0 FI |
Posted: Wed Apr 26, 2017 12:53 pm Post subject: Re: 1973 Bay Window Rescue - Long term project |
No heater fan requires some creativity. |
69Weekender Samba Member
Posted: Thu Apr 27, 2017 10:37 am Post subject: Re: 1973 Bay Window Rescue - Long term project |
First time viewer of this build. Gotta say, it is pretty awesome. I just recently started to take apart my dash and now I think I need to go with the all metal dash.
Keep up the awesome work!
Mitchell _________________ Mitchell
ISO any California Road Runner Camper parts or info
1969 California Road Runner Camper: http://www.thesamba.com/vw/forum/viewtopic.php?t=646780
2015 Toyota Tacoma V6 4x4
Past:
01 Honda Insight, 06 Beetle TDI, 77 Toyota, 96 Geo Metro, 06 Tacoma, 13 Jetta Wagon, 05 Jetta, 96 Corrado VR6
Other ICE Machinery: Alco 251F 16v & 8v |
Posted: Tue Jul 04, 2017 4:27 pm Post subject: Re: 1973 Bay Window Rescue - Long term project |
Thanks! Samba has been pretty amazing support.
Last part of the bus that leaked got replaced today.
Also started the engine compartment panel install.
and scraped 45 years of goo out of the drivers compartment.
Posted: Sun Jul 09, 2017 5:23 pm Post subject: Re: 1973 Bay Window Rescue - Long term project |
First time it's had a running motor (or possibly any motor) in 35 years. Some tuning to sort, but pretty excited to see it move under its own power.
Healthy oil pressure as well. Paint burning off the header and looks to be running rich.
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
