New Wide 5 Fuchs
Page: Previous  1, 2
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
Stock Steve
Stock Steve is offline
PostPosted: Sat Mar 14, 2015 5:29 am    Post subject: Reply with quote
Todd66 wrote:
Here are the ones we put on my son's car.
Wow, very slick!
Stock Steve
Shoreline Antique Auto Connection
http://www.shorelineantiqueautoconnection.com/
Ich Bin Ein Facebooker: https://www.facebook.com/steve.fromsaac
Join VVWCA: http://www.vvwca.com/
Your source for old school metal tire valve caps: http://www.thesamba.com/vw/classifieds/detail.php?id=1416217
Thanks Veterans
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Sat Mar 14, 2015 6:10 am    Post subject: Reply with quote
Looks nice and classy
For reference.. would you state/add wheel spec width on that car.
Please, when adding reference pics please state sizes.
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
Todd66
Todd66 is offline
PostPosted: Sat Mar 14, 2015 3:53 pm    Post subject: Reply with quote
2" narrowed beam, dropped spindles, 67 trans/axles. Front tires 195/55/15. Rear tires 205/65/15.
VOLKSWAGNUT
PostPosted: Sun Mar 15, 2015 5:43 am    Post subject: Reply with quote
Good that you added the rest for visual reference.
but...since this is the "New Fuchs" topic I was specifically requesting for wheel specs to be added.... The 4.5 wide or 5.5 wide. ??? Wink
aka Ken {o\!/o}
Todd66
Todd66 is offline
PostPosted: Sun Mar 15, 2015 3:38 pm    Post subject: Reply with quote
Sorry, meant to put it down too. 15x5 1/2 all around.
desertshawn
desertshawn is offline
PostPosted: Fri Jul 13, 2018 7:13 am    Post subject: Re: New Wide 5 Fuchs Reply with quote
I'm rolling a set of the American Eagle Fuchs (15x5.5X205) on my 64 Bus...get lots of props everywhere I go!
sportin-wood
sportin-wood is offline
PostPosted: Thu Jul 01, 2021 8:21 am    Post subject: Reply with quote
Todd -
Reviving an old thread, but were these mounted on drums or discs? Did you have issues fitting the flat center caps on the fronts? Any dust cap clearance issues? I just picked up a set for my project and have seen there are clearance issues with the dust caps and wondered how you got them to fit. Sharp looking bug for sure!
Paused 66 project bug
lowN2slo
lowN2slo is offline
PostPosted: Tue Oct 05, 2021 4:50 pm    Post subject: Re: New Wide 5 Fuchs Reply with quote
All Chrome, 5.5's front and back.
the.fordhams
the.fordhams is offline
PostPosted: Sun Apr 16, 2023 9:18 am    Post subject: Re: New Wide 5 Fuchs Reply with quote
4.5 on the front with 155R15 Firestone
Stock spindles 2 inch narrow adjustable beam
5.5 on the rear with 205/75/15
Spring plates set to 16 degrees
63 OG Turkis Bug project
65 OG Safari Beige Notch
65 OG Pearl SO42 Patina
67 SO42 welding project
03 Eurovan Weekender
08 Touareg 2 V6
WANTED :
Bob King VW dealer Wilmington NC dealer tag surround and any Literature for 03 Weekender
EVfun
EVfun is offline
PostPosted: Sun Apr 16, 2023 11:11 am    Post subject: Reply with quote
What year drums are you running. It is not well known, but there are 2 different wide 5 rear drums used between '58 and '67. The '65-'67 drums are 6mm wider than the older ones (VW says for tire chain clearance.) The older drums have a smooth center hub and the later type have 5 ridges out from the center in the hub.
On a similar note, oval window front brake drums are 7.5mm narrower than '58-'65 front drums. That could cause a fit issue for the center caps too. Rear oval drums are the same width as '58-'64 drums.
Wildthings wrote:
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
Page: Previous  1, 2
Page 2 of 2
