Altoona Samba Member
Posted: Tue Nov 12, 2013 3:42 pm Post subject: |
RCB wrote: |
Altoona wrote: |
onemat wrote: |
RCB wrote: |
If there is enough space in there to store a squirrels head it might be worth $ 45.00 otherwise its a waste of money. |
Yeah I liked it too, but you know it cost them about $2.00 from China. It would be neat if it was deep enough to hold a spare key. |
Just noticed the MADE IN THE USA logo on the web page.... |
OK so it costs $3.00 then if its a USA item. Still....... $45.00....um... |
You should totatly get some made for $3 and them undercut GW and sell them for $6.
Good luck..... |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Tue Nov 12, 2013 5:29 pm Post subject: |
Altoona wrote: |
RCB wrote: |
Altoona wrote: |
onemat wrote: |
RCB wrote: |
Good luck..... |
OOOOOOOOOOOOOO..... totally |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Tue Nov 12, 2013 6:06 pm Post subject: |
zippyslug31 wrote: |
Me, I always wanted a squirrel skull. |
I think they are the perfect size too, but I'd settle for a Fisher Cat skull, or some other similar sized ermine skull. _________________ John - 86 Wolfsburg Westfalia "Weekender"
unibagel Samba Member
Joined: December 02, 2004 Posts: 529 Location: Bflo, NY
Posted: Tue Nov 12, 2013 6:42 pm Post subject: |
I have a golfball from an 83 GTI...LOVE it! |
RainierSyncro Samba Member
Joined: February 26, 2013 Posts: 809 Location: Seattle
Posted: Wed Nov 13, 2013 3:06 pm Post subject: |
Bought a custom shift knob from a Samba vendor a couple of years ago. Really good quality, but it seems he's not in business anymore. Fits really good in my hand. The knob on my Syncro was chewed up by a bored pitbull. I might keep it for the battle scars.
Honuak Samba Member
Posted: Wed Nov 13, 2013 5:31 pm Post subject: |
I got this one from a vendor here on SAMBA. I had to re-thread it but it was totally worth the trouble...IMHO
SAMBA |
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
Posted: Wed Nov 13, 2013 8:02 pm Post subject: |
^^ My OCD is twitching.
Yeah, I like that guy's tiki stuff, he has nice small knobs too that I've been considering for the lockers. _________________ '86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight= |
tam_shops Samba Member
Joined: November 15, 2012 Posts: 1530 Location: Vancouver BC
Posted: Wed Nov 13, 2013 8:51 pm Post subject: |
My stereo might look like that! I couldn't find enough of those two ended clear tube connectors so had to use the yellow ones instead...I've been meaning to fix it b/c I didn't think it was *right* and b/c it bothered me that they didn't match! In my defence, I bought two connectors and did not realize you also had to cap everything. LOL
And, I'm sad that I do not have a shifter to change the knob on, dang automatic transmission! LOL
tam _________________ 1987 Vanagon Westfalia GL Automatic
Making it special:
http://www.thesamba.com/vw/forum/viewtopic.php?t=545885 |
Ben Root Samba Member
Posted: Fri Jan 17, 2014 1:13 pm Post subject: Weight a factor |
Has anybody ever had weight be a factor in a custom shift knob?
There's a lot of CNC stainless steel out there. But might it contribute to popping out of gear on rough roads or bumps?
Basically, I don't want to spend fat cash on a fancy knob in the name of aesthetics only to have the functionality of my van decrease . |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
Crankey Samba Member
Posted: Fri Jan 17, 2014 10:49 pm Post subject: |
I got this military surplus handle. it's got 2 triggers and a button underneath.
the hole fit the shaft just right, and it's got 2 set screws holding it on. the wires just run down the shaft unconnected to anything.
Dampcamper Samba Member
Joined: October 07, 2013 Posts: 788 Location: Rainy Portland, Oregon
Posted: Sat Jan 18, 2014 12:04 am Post subject: |
rsxsr wrote: |
The early vanagons had a smaller diameter shift rod. |
My '82 and my '71 have 12mm by (I think) 1.5 threaded shafts. Not sure when they went to the larger diameter. When I looked online for knobs many of the places had different bushing inserts so you could order whatever you needed for your car. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Sat Jan 18, 2014 12:39 am Post subject: |
dobryan wrote: |
As long as your trans is in good shape I can't imagine the weight of the shift knob making a difference. YMMV. |
It might contribute to a shifter failure where it fatigues near the bottom at the set screw that holds the collar until complete failure. This type of failure happens even without a weighted shift knob. |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1868 Location: Pittsburgh PA (ish)
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4791 Location: Bemidji, MN
Posted: Sun Feb 05, 2023 2:51 pm Post subject: Re: Gear shift knobs |
just epoxied a nut into a burl shift ball a friend turned me years ago. ball is a little small in my hand, will have to see if it suits me in the long run.
_________________ -dan
www.thefixitworkshop.com |
1988M5 Samba Member
Joined: January 23, 2016 Posts: 674 Location: Santa Cruz, CA
Posted: Sun Feb 05, 2023 5:53 pm Post subject: Re: Gear shift knobs |
I miss the Scat short throw shifter I had on my 62 bug. The distance from 2nd and third was like an inch but on a Transporter it would be like scratching your ankle to reach.
BK _________________ 1991 tin top GL
Some BMWs. |
1988M5 Samba Member
Posted: Sun Feb 05, 2023 6:06 pm Post subject: |
tam_shops wrote: |
tam |
I also have an automatic transmission but on my “to do” is to relocate the shifter to push button Select-O-Matic style via servo or column shifter with custom boat steering control cabling. Reason being to free up the super valuable floor space in that area. Logically the manual shifter needed to be be there but the AT doesn’t.
Some BMWs. |
Posted: Mon Feb 06, 2023 7:01 pm Post subject: Re: Gear shift knobs |
and done....
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1890 Location: Sidney B.C. Canada
Posted: Mon Feb 06, 2023 8:11 pm Post subject: Re: Gear shift knobs |
Made a few over the years, loose copies of the stock shape. In Delrin and aluminum and one in yew and aluminum ( with shift pattern engraved on top ), quentin has the latter, can’t find pic.
And then a bit of scrap from another machine shop. I drilled and tapped, stupid big and cold but you could have a potpourri in it
Btw, the aluminum copy of the stock shape knob is crap. Too cold. Prob too hot in summer. It’s gone !
[/img] _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
syncroanddestroy Samba Member
Joined: October 03, 2018 Posts: 73 Location: British Columbia
Posted: Tue Feb 07, 2023 8:36 pm Post subject: Re: Gear shift knobs |
I've driven vans with a lot of different shift knobs and this Yew one Alistar made is by far my favorite one.
