class 11 help?
ceedubbya
ceedubbya is offline
PostPosted: Sat Dec 06, 2003 6:05 am    Post subject: class 11 help? Reply with quote
does anyone where i can get info on class 11 baja's?..mainly the suspension..if any different from stock.
Dono Power
Dono Power is offline
PostPosted: Sat Dec 06, 2003 6:49 pm    Post subject: Class 11 Reply with quote
Im building a Class 11 style car also. You can get rule book from SCORE for the "real" Class 11 race car. I am building a 66 body on a late IRS 68 pan ( Yeah 68 IRS..think autostick!!! ) with a 3 inch body lift and with 3 inch front lifted spindles. I cant decide on tire size/type and which method to use on lifting the rear end. The car is straight and clean with a factory metal sunroof and the pan I restored the pan about 2 years ago to duplicate a friends killer all original 66 Beetle. Its like new with all new parts, pans, paint etc. I bought the friends 66 and had all of this "left over". The motor put aside for it is a late Dual Port 1600 with a Engle 100 cam, Compufire DIS IX and a stock tricked out 34 carb.
Finding info on these cars is tough. There is a killer pic of a Class 11 style "comanduer" car in the forum today. I had a Class 11 a few years ago and had a blast driving it and it drew all kinds of attention!!! This one will be Bigger and better than the last one. I would think these cars would be more popular!!
Thanks,
Dono Power
P.A.C.E Buggi Werks
Benton Arkansas
Diagnosed as a Sambachodriac.
Hebster52
Hebster52 is offline
PostPosted: Tue Dec 09, 2003 6:00 am    Post subject: Reply with quote
Here is some discussion about the topic:
http://www.thesamba.com/vw/forum/viewtopic.php?t=55362
And here: (I know it is on an other forum...)
http://shoptalkforums.com/viewtopic.php?t=58230
http://shoptalkforums.com/viewtopic.php?t=47232
http://shoptalkforums.com/viewtopic.php?t=58976
~Kristian E~
The Hebster52
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen
The KidVRod project
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
ceedubbya
PostPosted: Wed Dec 10, 2003 3:59 pm    Post subject: class 11 help? Reply with quote
I had a 70 and a 64 "baja" several years ago.No fiberglass kit,just cut the fenders and add bigger tires.I have always liked the way class 11 vw's looked and didn't know how to get the bigger tires under them.I have a 69 I want to "raise" a bit.Thanks for the feedback on the subject!
sixfootdan
Samba Smartass
Location: \Lo*ca"tion\, n. 1. The act or process of locating.
sixfootdan is offline
PostPosted: Fri Dec 12, 2003 12:33 am    Post subject: Reply with quote
They usually just have stock rims and a Knobby 29' tire?
Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!!
62ragman
62ragman is offline
PostPosted: Sat Dec 20, 2003 12:47 am    Post subject: Reply with quote
The suspension is stock per the rule book,but if your not going to race build it the way you want. www.score-international.com has the rule books for sale for like $15 if you still want one. Also www.chenowth.com sells a Class11 roll cage that would be a good start, it has to be welded in though. Good luck.
KDF Baja
KDF Baja is offline
PostPosted: Tue Jan 06, 2004 8:40 pm    Post subject: Reply with quote
speaking of class11, who has used the chenowth or similar rollcage?does it actually support you in a rollover or is it just for show? i know the cage surrounds the driver, does it go back into the rear seat area?
72 baja up for sale/trade! moving to WI in march, bug must go!
89 suburban
bajaherbie
Samba Sooner
bajaherbie is offline
PostPosted: Tue Jan 06, 2004 9:18 pm    Post subject: Reply with quote
the chenowth kit is the real deal, and yes it will help in event of a rollover. you can forget the rear seat, because several tube brace the rear torsion tube and frame horn,etc. my rollcage is a different design but the rearseat is still eliminated. there is a couple of photos of my ride in the readers rides section
68deluxe
68deluxe is offline
PostPosted: Tue Mar 02, 2004 10:13 pm    Post subject: Reply with quote
Just wondering if there is a particular year bug better suited to Class 11 racing or are they all pretty much equal? Does anyone know if type 2 transaxles are ok in class 11 (just ordered the Score rule book). Thanks-
62ragman
62ragman is offline
PostPosted: Wed Mar 03, 2004 4:07 pm    Post subject: Reply with quote
'69 and later are better as you are limited on suspension, so the balljoint front end will last ok. Be sides they are cheaper than the eariler ones. Only type one parts are allowed, no bus boxes.
Kafer Wolf
Kafer Wolf is offline
PostPosted: Tue Mar 16, 2004 6:19 pm    Post subject: Reply with quote
if type 1 suspensions are used, are they still stock or are they modified for strength?
how do you lift the suspension? is a class 11 essentially a stock beetle?
also, any good website with lotsa class 11 pics?
class11s are cool IMO, way cooler than bajas... Very Happy
vwclass11
vwclass11 is offline
PostPosted: Wed Mar 17, 2004 2:59 pm    Post subject: Reply with quote
Here is my street legal class 11 car.
Kafer Wolf
PostPosted: Thu Mar 18, 2004 2:28 am    Post subject: Reply with quote
cool class 11 car!
are those rear suspension all stock? won't the cv's break down in that angle?
how did you raise the front suspension?
vwclass11
PostPosted: Thu Mar 18, 2004 7:36 am    Post subject: Reply with quote
Well in the rear I am using thing flanges,bus cvs, bug axles, stock trailing arms, and modified type 1 stub axles. Pretty much stock vw. In the front I cut and turned the front end, I have 3 inch raised spindles with disc brakes from SoCal Imports. You should check the thread "Lifts and CVs". Anyways hope this helps. I also posted pictures of the rear suspension in the off-road gallery.
DanGreen
DanGreen is offline
PostPosted: Sat Mar 20, 2004 2:09 am    Post subject: Reply with quote
are the spring plates as far as they can go or did you leave some space for them to travel? ...... are they touching the stops?
vwclass11
PostPosted: Sat Mar 20, 2004 2:39 pm    Post subject: Reply with quote
No, the spring plates are not touching the stops. There is probably 2 inches from the spring plate to the stop. One added benefit is that I did not have to fight the spring plates to get them back on, also makes for a smoother ride since the torsion bars are not preloaded that much. Pretty much rides like a stock bug.
