goffoz Samba Member
Posted: Sun Nov 24, 2013 11:13 pm Post subject: scoop |
A little fun wit some aluminum..to help my intercooler this summer...keeps the rain out too
only on the passenger side...snorkel for the intake side, coming soon |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Sun Nov 24, 2013 11:19 pm Post subject: |
Nice work. PM me if you want to do a second set! |
insyncro Banned
Posted: Sun Nov 24, 2013 11:36 pm Post subject: |
Yes, very clean lines.
Well done. |
1621 Samba Member
Posted: Mon Nov 25, 2013 2:56 am Post subject: |
Looks way better than the plastic tubs. Nice work. _________________ '85 Westy |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Mon Nov 25, 2013 8:13 am Post subject: |
Nice metal work. I like to use that spot for intercoolers too, have you done any testing to see if it draws in any more air? |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Mon Nov 25, 2013 8:51 am Post subject: |
That looks great. I agree, nice lines. You could probably sell more than a couple of those if you wanted to. How is it mounted? _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1868 Location: Pittsburgh PA (ish)
goffoz Samba Member
Posted: Mon Nov 25, 2013 9:03 am Post subject: |
xoo00oox wrote: |
Thanks all...It took a few hrs of staring and trimming to get the shape right.
..I really like how it looks so far ..thinking of adding some fins at the front (giant bug/bird deflectors) just a thought
The intercooler fan sounds really awsome thru this, when parked, idling
"Yes, I have a little jet engine in there"
Only testing done so far is driving.
At freeway speeds climbing hills my temp seems to stay flat, usually I would get a 7 to 10 degree F. increase on a 30 min climb.
The other noticeable difference is a lot less dust in the engine compartment |
WestiCoast Samba Member
Joined: June 25, 2012 Posts: 194 Location: Oceanside Ca
Posted: Mon Nov 25, 2013 9:06 am Post subject: |
goffoz Samba Member
Posted: Mon Nov 25, 2013 9:13 am Post subject: |
Phishman068 wrote: |
How are these secured? |
It has a full lenght bend on the rear vertical that slips in beside the stock louvers, then a single sheetmetal screw top and bottom, mostly hidden by the angles...you can just see the top one in the pic.
I also left the bottom radiused corner standing clear of the body, that way it drains and any debris is blown out.
Once I get it all painted, and the front fins on, it should be barely noticable.
I originally made it a clip on, but testing showed it won't hold, It catches alot of air |
canasync Samba Member
Posted: Mon Nov 25, 2013 9:18 am Post subject: |
Looks great. I will have to copy that on my van. _________________ 1987 Syncro
3 knobs
PumpeDüse TDI (17mm Garret Turbo, bigger injectors, stage 4 malone tune, intercooled)
Cruise Control
Remote Start/locks
Custom Lift
Custom Bumpers with receivers
Coast Mountain Hightop - Comming Soon
1985 2wd Vanagon Pre-runner in the making
soon to be powered by 2.5L Subaru
Custom Lift |
Posted: Mon Nov 25, 2013 9:30 am Post subject: |
Nice! _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3417 Location: OR & CA (Oregon/California)
Posted: Mon Nov 25, 2013 10:16 am Post subject: |
it's very nice....
I made similar air scoops using aluminum sheet, for both side, but a bit smaller and attached to the black plastic air grills, not screwed into the body....to bring in more air to the oil cooler (I don't have a turbo).
btw, I made a prototype using the plastic tubs but I didn't like it because the Mickey Mouse ears look...
goffoz Samba Member
Posted: Mon Aug 04, 2014 6:01 pm Post subject: |
Found a little time for paint, and a few improvements to the scoop:D
I removed the factory louvers , and immediatly got more air volume
[img][/img]
Added some screen, to keep out the trash/bugs/ birds made this from a piece of "gutter saver"
There are now 2 internal structures that direct the airflow down the pillar,
instead of just letting buffet around in there
[img][/img] |
Merian Samba Member
Posted: Mon Aug 04, 2014 7:29 pm Post subject: |
have any of you measured the air flow after doing this? |
goffoz Samba Member
Posted: Mon Aug 04, 2014 7:46 pm Post subject: |
Merian wrote: |
What/how/method? do you suggest?
If there is a simple tool I can put in the path, I would love to know about it.
My scoop is sealed to the intercooler w/fan, there is noticeable draw(reduced pressure) at the scoop, when idling.
At freeway speeds, where scoop volume should exceed fan draw,
measurements are done at the Scan tool in temps on the IAT
noticeable improvements are observed...usually -10F overall and rapid returns to nominal temps after coming off boost.
averaging 20F over ambient, in most driving conditions
Your requirements may be different |
Posted: Mon Aug 04, 2014 8:53 pm Post subject: |
Dang, that looks sexy. You are the man. _________________ Tim Potts
'74 Jeep CJ5 |
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
Merian Samba Member
Posted: Mon Aug 04, 2014 9:57 pm Post subject: |
goffoz wrote: |
Merian wrote: |
easiest way would be to use an anemometer designed for measuring flow rates in ducts (which is what you have)
TequilaSunSet Samba Member
Joined: May 30, 2012 Posts: 2109 Location: Philippines
WOOT!!
No 75lbs parrots!! _________________ Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me |
