chojinchef Samba Member
Joined: February 17, 2011 Posts: 1539 Location: Central Massachusetts
Posted: Tue Jun 16, 2015 3:01 pm Post subject: |
The bullihutzen scoops are the ones installed on the Thingamajigger.
Can see the product and my install in Thingamajigger thread. _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Tue Jun 16, 2015 4:09 pm Post subject: |
Page 10 on the thingamajig er thread.
I've got a set of plastic ones in my shop. I don't recall where in the eu they came from. The blitz ones from the thingamajig er thread looked fiberglass.
I'm going to ditch mine and build some out of sheet metal or aluminum. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
Posted: Tue Jun 16, 2015 8:20 pm Post subject: |
Bullihutzen scoops are fiberglass. Mine were a good thickness too, with decent gel coat.
Hopefully the others come the same way. _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Wed Jun 17, 2015 9:45 am Post subject: |
Really nice scoops.
However, your letting air and unless you let it out it's not as good as it could be.
Who's the guy who posted a picture of the tail lights with the extension of the frame toward the center with the exhaust vents in them?
The other alternative is to have one scoop as the inlet and the other facing aft to get the air flowing across the engine compartment.
It's not going to look good with one facing aft. |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3417 Location: OR & CA (Oregon/California)
Posted: Wed Jun 17, 2015 10:00 am Post subject: |
I use my air scoops with this C clamp... to let more air out
yiucycle Samba Member
Last i look at the engine bay, i can see all the way to the ground. I dont think it will have problem venting unless you cover the bottom of the engine bay like the new car does. _________________ 1980 2.8LV6 Fiero ASI/Riviera Vanagon
"there is no point in being embarrassed of all the stupid shit i done and will continue to do"
Posted: Wed Jun 17, 2015 10:09 am Post subject: |
yiucycle wrote: |
Last i look at the engine bay, i can see all the way to the ground. I dont think it will have problem venting unless you cover the bottom of the engine bay like the new car does. |
ooh... Sh*t...forgot about that, dumbass again! lol!
It's got me wondering again about that airflow under the van around the gearbox.
I was thinking a while ago of making scoops under there to direct the air directly at the gearbox to help cool it off. |
dkoesyncro Samba Member
Posted: Wed Jun 17, 2015 2:45 pm Post subject: |
I made one using abs plastic. Very easy, first made a template out of cardboard got the shape I wanted. I then cut the template into 3 pieces top, bottom and broad. Used a jig saw for the abs and some 80 grit to fine fit. Glued it together with home depot abs glue. I then glued it to the vents and drilled a hole for the lower screw and fitted it with a finish plug.
However I made some steel ones using goffoz's template. This of course took some welding. |
TequilaSunSet Samba Member
Joined: May 30, 2012 Posts: 2109 Location: Philippines
Posted: Wed Jun 17, 2015 2:48 pm Post subject: |
dkoesyncro wrote: |
His require ZERO welding _________________ Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me |
Posted: Wed Jun 17, 2015 2:51 pm Post subject: |
Posted: Wed Jun 17, 2015 2:59 pm Post subject: |
I hope it works, phones acting out |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1890 Location: Montreal
Posted: Sun Oct 24, 2021 4:47 pm Post subject: Re: scoop |
does anyone have a saved picture that goffoz originally posted of his scoop?
I found the template with dimensions, just looking for the original photo. |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
Posted: Sun Oct 24, 2021 6:28 pm Post subject: Re: scoop |
Wellington wrote: |
does anyone have a saved picture that goffoz originally posted of his scoop? |
_________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
4Gears4Tires Samba Member
Posted: Mon Oct 25, 2021 7:17 am Post subject: Re: scoop |
Does anyone have the numbers for increased drag vs increased horsepower that the scoop provides? Or is this a net negative in top speed? _________________ '87 Syncro
Schnippzle Samba Member
Joined: February 04, 2021 Posts: 288 Location: Swede in London, UK
Posted: Mon Oct 25, 2021 7:25 am Post subject: Re: scoop |
4Gears4Tires wrote: |
Does anyone have the numbers for increased drag vs increased horsepower that the scoop provides? Or is this a net negative in top speed? |
But how many "cool points" or "street cred points" do you get? _________________ 1988 Caravelle - FB25B - Syncro converted
2016 MB E63 AMG S - The daily driver
2019 Harley Davidson FXFBS Fat Bob - The leisure |
Posted: Mon Oct 25, 2021 9:29 am Post subject: Re: scoop |
LOL if you must, but the scoop is a net performance improver if you have a diesel because it shoves air into the engine or the intercooler, especially at higher speeds. For bigger engines it will push more air down into the engine room and keep things cooler. For stock engines probably no advantage. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
RainierSyncro Samba Member
Joined: February 26, 2013 Posts: 809 Location: Seattle
Posted: Mon Oct 25, 2021 11:57 am Post subject: Re: scoop |
More goffoz scoop pics. I saved them because I liked the design and color match.
Abscate Samba Member
Posted: Mon Oct 25, 2021 3:58 pm Post subject: Re: scoop |
The left side scoops air in, the right side let’s the heat out.
That’s why it’s important to have the battery door on the right. _________________ .ssS! |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Mon Oct 25, 2021 5:25 pm Post subject: Re: scoop |
Abscate wrote: |
only when you're going downhill... uphill the direction reverses. _________________ -dan
www.thefixitworkshop.com |
Diy2k Samba Member
Posted: Thu Oct 28, 2021 10:26 pm Post subject: Re: scoop |
... and sideways the air inverses _________________ 1987 VW Vanagon Wolfsburg Weekender
2012 Ford Transit Connect Xlt |
