Mr Orange Samba Member
Joined: September 30, 2011 Posts: 64 Location: Göteborg SWEDEN
Posted: Fri Nov 29, 2013 9:11 am Post subject: Turnsignal switch cable harness |
Hi All!
I have an early 66 Microbus which haves the high beam switch on the floor.
Can anyone show me what the turnsignal switch cabel harness should look like. Mine has a few broken cables and I want to find out if they're needed.
Thanks in advance,
Jörgen Forssling
SWEDEN |
Paul Botello Samba Member
Joined: October 18, 2008 Posts: 46 Location: Temecula
Posted: Fri Nov 29, 2013 2:03 pm Post subject: |
Hi, here is a switch from a later 66, the brown wires at the bottom of the photo are for the high beam switch, so disregard those, everything else should be the same.
Posted: Sat Nov 30, 2013 3:28 am Post subject: |
Thanks!
My switch does not look quite like that. It had four wires attaced. Looks like It does not have the upper on the left and the middle one on the right.
Do you have any pics or diagrams of the harness end?
Regards,
Jörgen |
Posted: Sat Nov 30, 2013 3:42 am Post subject: |
Here are some pics.
//Jörgen |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51129 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Nov 30, 2013 7:37 am Post subject: |
Your switch is for a non USA 66 without the floor mounted high beam switch, the brown wires are the high beam switch and control a relay. If you want to use the floor switch tape up the brown wires. Here's the 66 diagram from Vintagebus.com:
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
