ehoff Samba Member
Posted: Mon Dec 02, 2013 6:05 am Post subject: 2WD lift springs |
I am interesting in de-sagging the suspension on my 2WD full westy. I am debating on going with the progressive GW lift springs or the almost stock, non progressive, baby lift, syncro.org springs.
Can anyone with the progressive springs speak to their van's handling after the install?
Any information and/or opinions appreciated.
Thanks |
akyrie Samba Member
Joined: March 24, 2010 Posts: 518 Location: Driftless, Wisco
Posted: Mon Dec 02, 2013 7:26 am Post subject: |
what about the cutting board lifts? you can add space to the top and bottom for almost free-to get rid of the sagging butt.
Search: fixing sagging but or something like that will get some answers. been done here a lot and tons of information on the search button.
I don't have an opinion on it otherwise. _________________ Although I got a funny message from the Porsche guys, it read, "what a mighty ship that you must sail"
....has anyone else received that?
82 AHU DK, 1950's Puch-black |
ehoff Samba Member
Posted: Mon Dec 02, 2013 7:34 am Post subject: |
I like that idea, but I do think the suspension can use a rebuild in general. 23 year old springs are just getting a little saggy in general. I'll check it out.
Thanks. |
insyncro Banned
Joined: March 07, 2002 Posts: 15087 Location: New York
Posted: Mon Dec 02, 2013 7:46 am Post subject: |
Plenty of threads dedicated to your question already.
Yes, I have experience with both springs you list...documented in many threads.
Springs and shocks should be replace together and each vendor has a preferred shock for their spring, due to spring rates.
You will need to shim to level a van even with new parts.
Your best chance of purchasing the springs/shocks YOU will prefer is to drive in other vans with different combinations and make an informed choice.
Buying by opinions on internet forums may present you with a Vegas outcome...money spent to crap out...my opinion. |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 2849 Location: Dartmouth, Mass.
Posted: Mon Dec 02, 2013 6:00 pm Post subject: |
insyncro wrote: |
Agreed, but for most of the country, finding someone with a Vanagon nearby with a non-stock suspension is slim at best, never mind the combination one is interested in. For many parts of the country, just finding anyone with a Vanagon nearby is hard to do! _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
insyncro Banned
Posted: Mon Dec 02, 2013 6:14 pm Post subject: |
I have most combos sitting in my shop or mounted to a personal van I own.
My time is worth money, but would like to help those looking for answers. |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Mon Dec 02, 2013 6:27 pm Post subject: |
insyncro wrote: |
Well said. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'10 Wrangler 3.8 6SP Manual
'12 Ford E350
'12 Tiguan 2.0T 6SP Tiptronic - Lady Shadetree's |
ehoff Samba Member
Posted: Mon Dec 02, 2013 7:48 pm Post subject: |
I'll ask around and try to get some drive time on some local vans. There arent a ton in my area but I'll see what i can muster up. I'm just looking for some humble opinions. I won't run out and buy what you suggest, but I will look further into setups that current users prefer.
Thanks. |
jetpoweredmonkey Samba Member
Joined: September 20, 2004 Posts: 191 Location: Sacramento, CA
Posted: Mon Dec 02, 2013 9:06 pm Post subject: |
I've had both the Van Cafe springs and the GW 1.5" lifting springs on my 1991 full Westy.
I bought the VC springs lightly used. I got about 1/2" lift out of them. The van did not sit level on the original springs, which I assume were pretty well sacked out at 130K. The rear sat 1/2" lower than the front. The VC springs leveled it out...for a while. Slowly the rear lost that 1/2" again. This is on a street driven van. However, these springs were a noticeable improvement over stock in terms of handling.
Now I have the GW 1.5" springs installed. I definitely got a true 1.5" lift over stock (or what I assumed was the stock ride height taking into consideration my 20 year old sacked out springs). After 6 months or so, they have not packed down at all, not even a little. I installed the left rear with two stock spring plates to help balance the extra load on that side and the van sits almost perfectly level all the way around. Nose dive is vastly reduced, ride is great and handling is 100% improved over the VC springs.
In my mind it is no comparison if you are talking about a full camper. The VC springs would probably be fine on a tin top and might possibly be preferable - not sure if the non-lifting GW springs are a bit too heavy for a much lighter van.
I will say that my Bilstein HDs are not a good match for the GW springs, they are far too soft. I would like to sell them and try a set of the "sport" valved shocks that GW now has. _________________ 1991 Westfalia 2WD |
madspaniard Samba Member
Posted: Mon Dec 02, 2013 9:11 pm Post subject: |
jetpoweredmonkey wrote: |
I bought the VC springs lightly used. I got about 1/2" lift out of them. The van did not sit level on the original springs, which I assume were pretty well sacked out at 130K. The rear sat 1/2" lower than the front. The VC springs leveled it out...for a while. Slowly the rear lost that 1/2" again. This is on a street driven van. However, I will say that these springs were a noticeable improvement over stock in terms of handling.
Now I have the GW 1.5" springs installed. I definitely got a true 1.5" lift over stock. After 6 months or so, they have not packed down at all. I installed the left rear with two stock spring plates to help balance the extra load on that side and the van sits almost perfectly level all the way around. Nose dive is greatly reduced, ride is great and handling is 100% improved over the VC springs.
I will say that my Bilstein HDs are not a good match for the GW springs, they are far too soft. I would like to sell them and try a set of the "sport" valved shocks that GW now has. |
When did you purchase your VanCafe springs? They had different versions thru the las 3-4 years, with the last generation greatly improved. There was one batch some years ago that showed some fabrication flaws, the springs would be too soft giving you noticeable front bounce and nose dive and soft cornering.
If you bought yours lightly used there is a chance the previous owner sold them because of these issues? This is what happened to me. I now have the last generation, they work great. _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
insyncro Banned
Posted: Mon Dec 02, 2013 9:16 pm Post subject: |
madspaniard wrote: |
When did you purchase your VanCafe springs? They had different versions thru the las 3-4 years, with the last generation greatly improved. There was one batch some years ago that showed some fabrication flaws, the springs would be too soft giving you noticeable front bounce and soft cornering. |
Correct.
The latest version are by far the best ride feel, allow easy alignment and do not sag as previous versions have.
Shimming to level maybe needed depending upon a tin top or Westy.
The 2wd spring rates are paired with Konis and the Syncro spring rates are paired with Old Man Emus.
I consider both equivalent in description of "lift" to Go Westy zero lift springs, but are not progressively wound as the GWs are. |
Posted: Mon Dec 02, 2013 9:21 pm Post subject: |
Yes, I would say the last VanCafe springs might actually be a bit too stiff for a tintop van, perfect for Westys. _________________ 1991 Westy auto w/ Peloquin TBD
Posted: Mon Dec 02, 2013 9:26 pm Post subject: |
All good to know - and yes, since they were used I have no idea how old my VC's were, at least a couple of years, though.
Also, just to be clear, I heart Van Cafe - and it sounds like they have ironed out the problem I had with their springs, naturally! _________________ 1991 Westfalia 2WD |
insyncro Banned
Posted: Mon Dec 02, 2013 9:31 pm Post subject: |
Also, just to be clear, I heart Van Cafe - and it sounds like they have ironed out the problem I had with their springs, naturally! |
Van Cafe is a vendor, Steve Schwenk is the spring designer and he has them manufactured. |
singler3360 Samba Member
Joined: February 25, 2009 Posts: 1191 Location: Corvallis, Oregon
Posted: Mon Dec 02, 2013 9:45 pm Post subject: |
I've had the Konis for about a year with stock, saggy springs (about 14" on all four corners). Last month I bought the VC 2WD springs and they are being installed this month. I'm encouraged to hear these springs and shocks are supposed to work well together. I won't get to drive my Westy for another three weeks, but I will report back what I think. |
