54 info
oring71
oring71 is offline
PostPosted: Wed Dec 04, 2013 1:46 pm    Post subject: 54 info Reply with quote
Im helping a friend put his 54 samba back on the road after it being off the road since 1972......
Have a few Q's to ask please. (lots more to come too)
1... chassis number reads 20-09658 can anyone tell if it IS a 54, the 16" Rims say its a march 54.
2... would the two rear corner windows be glass or plexy glass?? this has the latter.
3... OG colours are SWR/CB (under the blue it has now) roof is white but has signs of CB underneath, could the white be OG as it was delivered to Malta?? and yes it is RHD too.
4... Can i fit a gearbox from a 57 to the BD after i change the spring plates and fit mounting brackets for the shocks? bus came without gearbox.
5... does anyone repop the front safari hinges for a BD?? his are broken in half.
Thanks and will try to upload some pics of the beast soon.
Eric.
Das Maltese Kruizers
mandraks
mandraks is offline
PostPosted: Wed Dec 04, 2013 2:09 pm    Post subject: Reply with quote
can you check the chassis number? fro 54 you should have 20- and 5 digits
http://www.thesamba.com/vw/archives/info/chassisdating.php
4 digits is much earlier
regards
Uli
Lowdown Dirty Rat
Lowdown Dirty Rat is offline
PostPosted: Wed Dec 04, 2013 2:22 pm    Post subject: Reply with quote
20-09658 is missing a number. It won't be a February 1951.
The 96000 barndoors were built in September 1954.
Yes to plexiglass/Perspex
Yes to the colour and safaris.
I would say the white roof was added later.
I'm guessing this is the bus.
RockStock
RockStock is offline
PostPosted: Wed Dec 04, 2013 2:24 pm    Post subject: Reply with quote
Assuming you are missing the last VIN digit, it would make it a Jan 55 dlx.
Corner windows should be Plexiglas.
Chances are roof was painted white later. Order the birth certificate.
I think pre58 gearboxes are ok?
-StockRocks-
bubblehead
bubblehead is offline
PostPosted: Wed Dec 04, 2013 5:39 pm    Post subject: Reply with quote
The 57 trans will bolt up to chassis no problem but you will need to make some spacers to go between springplate and reduction box.
oring71
oring71 is offline
PostPosted: Wed Dec 04, 2013 5:45 pm    Post subject: Reply with quote
Thats the one, took me ages to clear a path for it to come out Smile
Thank you all for the info regarding the chassis number ill have another look at the number tmro and post up.
oring71
oring71 is offline
PostPosted: Wed Dec 04, 2013 5:48 pm    Post subject: Reply with quote
Who is it that makes the safari hinges please? got a link?
bubblehead
PostPosted: Wed Dec 04, 2013 6:44 pm    Post subject: Reply with quote
You'll also need to clearance/notch the springplates where they hit the stops on the torsion housing. Assuming stock height?
oring71
oring71 is offline
PostPosted: Wed Dec 04, 2013 6:59 pm    Post subject: Reply with quote
Why would i need to notch the spring plates if staying stock height??
Are the 57 springplates not the same size as the OG ones??
Thanks for all the info...... will be very helpful when i get to it.
bubblehead
PostPosted: Wed Dec 04, 2013 7:29 pm    Post subject: Reply with quote
Because on BD the springplate attaches to the axle tube, similar to a bug. On later bus it bolts directly to the RGBs below the axle. If you tried to put together w/same springplate angle, it would lower the rear like 6 inches. I can post some pictures showing how it all works. Might be a day or two before I have time.
jeremy6
jeremy6 is offline
PostPosted: Wed Dec 04, 2013 7:48 pm    Post subject: Reply with quote
Yes there is some fab work to be done if you are putting a 57 style trans in. Why not install a stock Barndoor trans if you are keeping it stock? For the Safari stuff heres a link to the guys ad
http://www.thesamba.com/vw/classifieds/detail.php?id=1526576
call him and he will sell you the parts you need.
GOOD LUCK
low54
low54 is offline
PostPosted: Thu Dec 05, 2013 12:24 am    Post subject: Reply with quote
Looks a realy nice project I have a big nut box in my 54 you have to notch the later spring plates to clear the bottom bolt where the lever arm shock would of been.
Then all you need is a pair of spacers to fit between the reduction boxes and the spring plate some longer bolts to go through the spacer and a 57 box will bolt up.
I have a friend that has done quite a few spacers pm me and I will pass on your details.
Cheers ben
Scotty
Scotty is offline
PostPosted: Thu Dec 05, 2013 1:51 am    Post subject: Reply with quote
Have a search in the classifieds on here, you should find some hinges.
oring71
oring71 is offline
PostPosted: Thu Dec 05, 2013 3:07 am    Post subject: Reply with quote
Yeah some pics would help out LOTS thanks. When you get time.
oring71
oring71 is offline
PostPosted: Thu Dec 05, 2013 3:09 am    Post subject: Reply with quote
GOOD LUCK
Thanks for the link, will send him a msg.
Cant refit BD gearbox cos i dont have one and believe it or not this is the only BD known of here in Malta so doubt i will find a gearbox running around Smile
RockStock
PostPosted: Thu Dec 05, 2013 7:05 am    Post subject: Reply with quote
So you could use a pre58 bus gearbox to lower a barndoor bus?
How does this drop of 6 inches compare to the drop you get by using a beetle straight axle gearbox?
-StockRocks-
streetwagens
streetwagens is offline
PostPosted: Thu Dec 05, 2013 7:07 am    Post subject: Reply with quote
The notching is because the 55> spring plate sits below the axle, on barndoors it is in line with it - Here are a few pics of the '62 trans going into the '50 kombi:
You can see from the last pic that I had to re-notch the spring plates deeper to achieve stock height with this setup. A mate does the spacers that are needed in the UK and can post, pm me if you need some making up Very Happy
To catch a fish, you must first think like a fish....
oring71
oring71 is offline
PostPosted: Thu Dec 05, 2013 5:24 pm    Post subject: Reply with quote
Thanks for the pics and info, very helpful.
oring71
oring71 is offline
PostPosted: Thu Dec 05, 2013 5:28 pm    Post subject: Reply with quote
So i had a better look at the chassis number today and found the last digit i was missing.... so the number reads -20-0964585-
PostPosted: Thu Dec 05, 2013 6:15 pm    Post subject: Reply with quote
Getting closer. Smile
It should be -20-0XXXXX
5 digits where the X's are located, not 4 and not 6
If it's one of these they are both still September, 1954:
-20-096585-
-20-096458-
