lintbrush Samba Member
Joined: October 10, 2013 Posts: 269 Location: Campbell, California
Posted: Fri Dec 06, 2013 5:17 pm Post subject: Purpose of these holes in rear corners under tail lights? FAQ |
What ar these holes for? I have one on each side.
_________________ 1970 Westfalia Campmobile - SF Bay Area
https://www.instagram.com/campishome/ |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51131 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Dec 06, 2013 5:23 pm Post subject: |
Rustproofing, it provides access to the rear frame rail. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Fri Dec 06, 2013 5:34 pm Post subject: Re: Purpose of these holes in rear corners under tail lights |
lintbrush wrote: |
What ar these holes for? |
they are the source of mystery and intrigue, and the reason for seemingly endless topics of discussion. |
Collie Samba Member
Joined: April 03, 2006 Posts: 1285 Location: Virginia
Posted: Fri Dec 06, 2013 6:05 pm Post subject: Re: Purpose of these holes in rear corners under tail lights |
hazetguy wrote: |
lintbrush wrote: |
Sorta like the 'silver socket'. |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Fri Dec 06, 2013 6:27 pm Post subject: |
They are portals for the search function here on Samba. _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Fri Dec 06, 2013 6:45 pm Post subject: |
BUSBOSS wrote: |
They are portals for the search function here on Samba. |
Okay so this is one thing that you actually can't really search for!! _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Fri Dec 06, 2013 7:13 pm Post subject: |
scrivyscriv wrote: |
BUSBOSS wrote: |
Okay so this is one thing that you actually can't really search for!! |
Yep, I was just about to say that. I actually did do a cursory search attempt, but got a bunch of crazy results. _________________ 1970 Westfalia Campmobile - SF Bay Area
Posted: Fri Dec 06, 2013 7:32 pm Post subject: |
lintbrush wrote: |
BUSBOSS wrote: |
Yep, I was just about to say that. I actually did do a cursory search attempt, but got a bunch of crazy results. |
Do not enter the portal casually.
http://www.thesamba.com/vw/forum/viewtopic.php?t=575714&highlight=apron+holes _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
Tcash Samba Member
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Sat Dec 07, 2013 11:32 am Post subject: |
richparker wrote: |
That's where you put the rod in to crank down the engine. |
Lol! The other side is for optional electric start, you can use a drill and a rare 1/4" square drive shaft to engage a one-year only starter clutch for improved cold-weather starts. Most PO's removed the setup as they didn't understand how to use it, and their mechanics had a much easier and better setup to replace it. _________________ Robert in Memphis
Posted: Sat Dec 07, 2013 4:02 pm Post subject: |
I dropped of my bus today to the engine builder for new carbs and electronic ingintion.
While I was ther I asked him about the holes. He is like 65 and had been a VW mechanic for 40+ years. He was stumped on the reason of the holes on a T2A but was sure the ones on a T2B were for drainage. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
FlatfourFrenchy Samba Member
Joined: March 13, 2013 Posts: 297 Location: Boonville, MO
Posted: Sat Dec 07, 2013 5:30 pm Post subject: |
If those are not for the pass- thru wire for those rare rear facing European fog lamps I would say they are for drainage. |
kevhum Samba Member
Joined: April 05, 2008 Posts: 726 Location: State of Jefferson
Posted: Sat Dec 07, 2013 6:54 pm Post subject: |
The double cabs have A set up higher around the level of the rear engine hatch.I have wondered if they were for A jig that lined up the rear when they were assembling the body in the factory. |
Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
Posted: Sat Dec 07, 2013 7:21 pm Post subject: |
busdaddy wrote: |
Rustproofing, it provides access to the rear frame rail. |
^^ This. There is another hole behind it, which allows you to spray rust proofing inside that rail.
Alex6373 Samba Member
Joined: August 05, 2007 Posts: 882 Location: Vancouver Island,B.C.
Posted: Sat Feb 01, 2014 1:35 pm Post subject: |
This must have been the way they assembled the panels at the factory before welded them.
I have just repaired both sides on my bus and these holes provide no access to the frame rail for rust proofing just access to the rear bumper nuts that are welded to the frame , there is no access forward due to a curved bulkhead just behind the first bolt hole on the frame rail.
At least 0n my 1973 |
1967250s Samba Member
Posted: Sat Feb 01, 2014 3:53 pm Post subject: |
I thought they were for a tow hooks that attach to the frame? Saw somewhere here........ |
Tcash Samba Member
kevhum Samba Member
Posted: Wed Jul 09, 2014 7:36 pm Post subject: |
autobus73 wrote: |
you know now that I read you bringing this up I found this in the technical section. Vw bus cavity protection 1972 under the service bulletins.Though it does show the front wheel wells as access holes, in the back it clearly shows them going under the bus to get to the rear of the frame.Heres A link to the rear frame.Although its in German and of poor quality you can see clearly that they are under the back of the bus in order to do rust protection into the frame http://www.thesamba.com/vw/archives/manuals/3_72_bus_cavity_preservation/17.jpg |
SGKent Samba Member
