Purpose of these holes in rear corners under tail lights? FAQ
Page: Previous  1, 2, 3  Next
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Jul 09, 2014 7:45 pm    Post subject: Reply with quote
Glenn
Member #1009
#BlueSquare
SGKent Premium Member
SGKent is offline
PostPosted: Wed Jul 09, 2014 7:50 pm    Post subject: Reply with quote
so from #50 that looks like the caps that used to be rubber that filled the holes under the battery and on the other side. Am I reading that right?
I got some that were rubber with a T on the back from somewhere and I don't know where.
Kind of like this one below. I am asking because I wanted to get the correct part and now my head is spinning as to what that part is supposed to look like. I found a black plastic one on the Vanagon forum just now and then someone posted the clear plastic ones as what is currently used.
Making it even more embarrassing that I don't know this, the fiche shows them going in from the top which I did and Colin said they went undernearth going up which actually makes more sense because then they let water drain out but not come in. But don't know if they are supposed to be plastic or rubber.
NASkeet
NASkeet is offline
PostPosted: Thu Jul 10, 2014 7:58 am    Post subject: Reply with quote
The battery-tray, drain-hole bungs are rubber.
Regards.
Nigel A. Skeet
http://www.vwt2oc.net
busdaddy
busdaddy is offline
PostPosted: Thu Jul 10, 2014 9:01 am    Post subject: Reply with quote
Well now I'm really confused, #50 in Glenns pic says that's the part number but it shows it in the battery tray and as Nigel says that's rubber and as you say it has the Tee on the back (yes it goes in from below BTW). 211 813 395 looks from here like the plugs for the rustproofing holes below the tail lights. 211 611 849 is a mystery to me, there's no round holes in the inner valance on a later bus, the only application I can come up with for it is the mystery hole in the left end of the outer valance found on late 78 and 79 models, I wonder what the diameter is?
Слава Україні!
germansupplyscott
germansupplyscott is offline
PostPosted: Thu Jul 10, 2014 9:30 am    Post subject: Reply with quote
yes.
211 611 849 - no idea where those go on a Bay Bus. weird part number too because 611 group is brake cylinders.
SL
Tcash
Tcash is offline
PostPosted: Thu Jul 10, 2014 12:03 pm    Post subject: Rear Panel Corner Part Plug Reply with quote
Same illustration has #50 as Prt# 211 813 398. No description as noted in the early diagram below. Was the part superseded, or is it a typo.
e
Thanks to jerseylooker.
Early Baywindow Bus Parts Book
211 611 849
https://www.google.com/?gws_rd=ssl#q=211+611+849
So do I understand this correctly that 211 611 849 is mounted in the rear inner valance. Is it this part?
http://www.busdepot.com/j12020
busdaddy
busdaddy is offline
PostPosted: Thu Jul 10, 2014 12:21 pm    Post subject: Re: Rear Panel Corner Part Plug Reply with quote
According to Justkampers but I don't know how, the only holes in that part are oval slots for rustproofing access and that round plug sure ain't gonna squeeze into them. Confused
Слава Україні!
seventyfo
seventyfo is offline
PostPosted: Thu Jul 10, 2014 1:26 pm    Post subject: Reply with quote
http://youtu.be/muA5EBmpDhA
85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
"I don't know you well enough to care about your comments". Watkins Cravey
Tcash
Tcash is offline
PostPosted: Thu Jul 10, 2014 1:35 pm    Post subject: Reply with quote
Thanks Busdaddy.
Flat4VW
Flat4VW is offline
PostPosted: Thu Jul 10, 2014 2:16 pm    Post subject: Reply with quote
Are we talking about the same hole as on my '79? I've always wanted to know what this was for...
busdaddy
busdaddy is offline
PostPosted: Thu Jul 10, 2014 3:43 pm    Post subject: Reply with quote
[pic]
Well now we are sort of...... I asked if maybe that plug was sized to fit the 79 mystery hole, without knowing it's dimensions we may never know. I thought Hazetguy posted a cap for that somewhere years ago IIRC but I can't find his post right now.
As for what the hole is really intended to do it's still a mystery, saw one on a late 78 a while ago too.
Слава Україні!
SGKent is offline
PostPosted: Thu Jul 10, 2014 3:46 pm    Post subject: NOS 211 813 395 Reply with quote
that has to be for that hole in the orange bay above. For the 211 611 849 part BusOk has a note on one of their pages that says 8/78 -1979.
Here is a thread from Hazetguy and these are what goes in the rear panel - and the number doesn't lie in the photos.
edit - the battery rubber plug is 111-801-177
hazetguy wrote:
NOS. 211 813 395
old pics.
no.
SGKent is offline
PostPosted: Thu Jul 10, 2014 3:59 pm    Post subject: Reply with quote
Someone make this post so it can be found next time it is needed
The rubber plug under the battery and other side is 111-801-177
The large plastic plug on a late 78 and 79 bay is a 211-611-849
The small plug that fits under the rear lights on late bays is 211-813-395
Tcash
Tcash is offline
PostPosted: Thu Jul 10, 2014 4:38 pm    Post subject: Reply with quote
The 211-813-395 fits the Early bays as well.
curtis4085
curtis4085 is offline
PostPosted: Fri Jul 11, 2014 5:21 am    Post subject: Reply with quote
This also is same plug that on either side of rear view mirror in late bay
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
NASkeet
NASkeet is offline
PostPosted: Fri Jul 11, 2014 8:28 am    Post subject: Reply with quote
germansupplyscott wrote:
yes.
Interesting!
Note that new hydraulic brake slave cylinders, have temporary bungs in the hydraulic connections, to exclude dirt and moisture, whilst the cylinders are in parts storage, so this they might be what they are.
Regards.
Nigel A. Skeet
Tcash
Tcash is offline
PostPosted: Fri Jul 11, 2014 9:28 am    Post subject: Reply with quote
The 211 611 849 appears to be a lot bigger in diameter.
NASkeet
NASkeet is offline
PostPosted: Sat Jul 12, 2014 8:02 am    Post subject: Reply with quote
It was just a thought! Smile
Regards.
Nigel A. Skeet
Tcash
Tcash is offline
PostPosted: Sat Jul 12, 2014 8:54 am    Post subject: Reply with quote
[quote=It was just a thought! Smile[/quote]
It was the best one yet.
Tcash
Tcash is offline
PostPosted: Sat Jul 12, 2014 9:28 am    Post subject: Bung, Rear Valance & B post T25 211611849 Reply with quote
Just to make it a little more interesting.
http://www.vwheritage.com/vw_spares_Bung-Rear-Vala...172490.htm
So what is the deal with the, I am assuming early T2b 211 813 398. I come up with nothing with this Prt#. When they changed back to 211 813 395, there is no modification letter so the part did not change. Any idea?
Still have not figured out where this location is for the 211 611 849? It states it is inside the engine bay.
JK=This is the bung that goes in the back of the inner valance inside the engine bay, to stop water and road grime getting in.
Page 2 of 3
