yammi450 Samba Member
Joined: October 04, 2005 Posts: 149 Location: Las Vegas,Nv
Posted: Sun Dec 08, 2013 1:00 pm Post subject: air bleed screws IDFs |
I was wondering if I should mess with my air bleed screws if the throats are off a little. They are 1/4 of a point off on the snail gauge. should I worry about that or not? |
mark tucker Samba Member
Posted: Sun Dec 08, 2013 8:27 pm Post subject: |
probably not,but there yours do it if you wish.I found on mine closing them up some makes for easyer tuning& better running motor.But with that said....you never know if they were where they should of been to start with...aparently not for me. if there off I would bring the high ones down,not low one up. |
spectre6000 Samba Member
Joined: April 19, 2009 Posts: 2014 Location: Broomfield, CO
Posted: Sun Dec 08, 2013 8:28 pm Post subject: |
If you're saying the snail gauge reads something like 4.5 on one side of the carb and 4.75 on the same side, then yes, that's how you reconcile the difference. You'll want to open it up a crack (a tiny crack) on the 4.5 side.
Whether or not it's worth worrying about is something people can argue about. Were it me and I were putting time and energy into properly setting up my carbs and I want my engine to run the best it possibly can, you bet your ass I'm going to fret that quarter cfm to the best of my abilities.
That said, there is a reason the cylinders are off. Wear in the cylinder, perhaps a bent throttle shaft, something up with the throttle plate, maybe something weird with the manifold or head casting could be throwing it off. maybe worth investigation, maybe you know why it's off, maybe it's not worth the time to investigate since the bleed screw can rectify it (the symptom at least). _________________ Jason Hopper
-'58 German Market Deluxe Beetle (in progress)
-'84 M1009 CUCV
-'81 K10
"Buy the best, cry once." -Gene Berg
"A cheap man will always buy the cheapest thing available, and then buys another one hoping for a better result, and then spends the rest of his life in misery complaining about it. A thrifty man will buy a good part once and never think about it again." -RockCrusher
"Don't feed the Shitty Parts Monster!" -Me |
Jesse1914 Samba Member
Joined: April 25, 2013 Posts: 171 Location: San Diego
Posted: Sun Dec 08, 2013 8:43 pm Post subject: |
spectre6000 wrote: |
That said, there is a reason the cylinders are off. Wear in the cylinder, perhaps a bent throttle shaft, something up with the throttle plate, maybe something weird with the manifold or head casting could be throwing it off. maybe worth investigation, maybe you know why it's off, maybe it's not worth the time to investigate since the bleed screw can rectify it (the symptom at least). |
Pretty much.
X2 _________________
Quote: |
You have to heat the tips up until they are a straw color... Then quench them in Soy Sauce. |
Posted: Sun Dec 08, 2013 8:44 pm Post subject: |
Pretty much.
Pretty much.
Posted: Sun Dec 08, 2013 8:45 pm Post subject: |
My apologies. "Smart phone owner" issues... _________________
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Dec 09, 2013 8:40 am Post subject: |
Jesse1914 wrote: |
My apologies. "Smart phone owner" issues... |
Don't you mean not "too" smart phone?.... Actually if you will review posts after making them, you can (usually) delete any duplicates as long as you are last poster, meaning that no one has responded after you....
Posted: Mon Dec 09, 2013 11:44 am Post subject: |
Opened the lower barrels up (1 on each carb). Took at least 3/4 turn to even out the vacuum signal. Re sync carbs and re did LBI. It runs worse with random popping through the carbs. I'll put them back( all closed).
Should I sync the lower vacuum barrels or the higher vacuum ones? |
Posted: Mon Dec 09, 2013 3:03 pm Post subject: |
do you have gaskets under the stacks? a leek there will change the reading,also it's a flow meater, not vacume gauge.I lower the high.unless there already closed.but be sure that is what it needs. |
Posted: Mon Dec 09, 2013 3:59 pm Post subject: |
Mark, you are very hard to follow sometimes. I'm not trying to be a jerk, but spelling and grammar are really important when you're trying to communicate solely via text.
This is how "leeks" in your "meater" would appear to the casual observer:
(OK, maybe a bit of a jerk)
yammi450 wrote: |
Does not compute... Lower barrels? Close all of the air correction screws all the way and start there (make sure you're actually manipulating the air correction screws and not the venturi set screws or idle mixture screws or something). If you're out of balance with all of the air correction screws all the way closed, you can bring a barrel up to meet a higher flow cylinder by opening the correction screw associated with that cylinder. If you were only a quarter of a cfm off on one cylinder, 3/4 of a turn sounds like a bit much to need to pull it out... _________________ Jason Hopper
-'84 M1009 CUCV
-'81 K10
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Mon Dec 09, 2013 4:16 pm Post subject: |
I'm glad you didn't find a different kind of "leeking meater" to show a picture of.... |
Posted: Mon Dec 09, 2013 5:13 pm Post subject: |
here a leek there a leek old McDonald had a leek or did he take a leek....
Most people who tune Webers forget they (the air correction screws) are there once they are closed completely .... As recommended by almost all WEBER tuning guides.....
Popping back through carbs indicates lean mix in what ever cylinder is doing the popping...
Posted: Mon Dec 09, 2013 5:30 pm Post subject: |
http://vwparts.aircooled.net/Innovate-MTX-L-Wideband-Oxygen-Sensor-Kit-3844-p/innovate-3844.htm
Your new best friend. _________________ Jason Hopper
-'84 M1009 CUCV
-'81 K10
