Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Tue Dec 09, 2003 12:40 pm Post subject: Replacement westy T molding |
The off white plastic T molding on the edges of my otherwise wonderful SO42 interior was all shrunken and puckered up so I went looking for replacements.
I found T-molding.com sells 3/4" molding in 25 foot coils. http://t-molding.com/cart/customer/product.php?productid=18&cat=22&page=1 I ordered some and it arrived last night. The color is putty gray and is almost a dead-on match for the factory molding. The 3/4 molding is a bit wider than the factory stuff, but I wasn't able to find anything thinner. I'll trim it on the icebox top only.
Anyways it looks great; hope this is helpful to someone.
Has anyone found a source for replacement icebox door seal material? |
KevinCompton Samba Member
Joined: September 08, 2003 Posts: 344 Location: Los Angeles, CA
Posted: Tue Dec 09, 2003 12:46 pm Post subject: |
Thats sooo helpful. I need that stuff because mine has shrunk also.
Thanks a grip, woody. |
kintail Samba Member
Posted: Sat Dec 13, 2003 9:42 am Post subject: |
If the original t moulding has shrunk, you can "rejuvenate" it by using a paint stripper gun and stretching it back to it's original length.
Obvously, finding new "original color" works better! |
Dogo Samba Member
Posted: Mon Aug 08, 2016 11:00 am Post subject: Re: Replacement westy T molding |
Does anyone have a source for the K or X -or whatever it's called- molding (the one that goes around the latched doors) in the same putty colour? |
srfndoc Samba Member
Posted: Mon Aug 08, 2016 6:27 pm Post subject: Re: Replacement westy T molding |
nlavw.com _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Juan Samba Member
Joined: September 01, 2003 Posts: 878 Location: Miami, FL
Posted: Wed Aug 10, 2016 9:34 am Post subject: Re: Replacement westy T molding |
It should be the second one, though they don't give the width and they describe it as "white" when it was really a putty color. |
Stocknazi Samba Member
Posted: Wed Aug 10, 2016 10:09 am Post subject: |
kintail wrote: |
Boiling it in water works well too. When you put it back on, glue it and don't over-stretch it. Stretch it just enough so that it's the same length as it was originally. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Juan Samba Member
Posted: Fri Aug 12, 2016 10:51 pm Post subject: Re: Replacement westy T molding |
what's the profile for the trim that runs the length of the edge of the big vertical cabinet? (Same one that lines edges of seats etc.) Trying to identify it. Thanks again!
_________________ Instagram: @juanskombi
1967 Velvet Green/Pearl White Kombi
1964 Pearl White Ghia Coupe
1969 BMW 2002
1959 Ford F100 |
Posted: Sat Aug 13, 2016 8:57 am Post subject: Re: Replacement westy T molding |
Juan wrote: |
It's the same T-profile as the other pieces. _________________ WANTED:
Thomas Jefferson |
Juan Samba Member
Posted: Sat Aug 13, 2016 3:29 pm Post subject: Re: Replacement westy T molding |
Thanks StockNazi. This is when the size difference of the replacement molding becomes really evident. At first I thought that trim was a smaller version of the T-molding that goes on the tables.
I've taken some pics today in case it might help others.
OG molding on top and replacement from Tmolding.com on bottom. They may look the same but replacement is wider.
This photo shows the difference in size quite clearly:
Replacement molding slightly overlaps the edge of the table.
Compare to OG, which is flush:
Overall though it doesn't look bad at all. My cargo door table had no molding at all; this is definitely a big facelift. I'm just not sure I would apply the same to the big table. I'd love to find the right width/color molding. If anyone knows of a place that sells it, please let me know.
1969 BMW 2002
1959 Ford F100 |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Sat Aug 13, 2016 6:55 pm Post subject: Re: Replacement westy T molding |
It sure looks good. Maybe it will shrink but I doubt it. It actually will keep stuff from sliding off the table if that is a benefit. |
Juan Samba Member
Posted: Sat Aug 13, 2016 9:28 pm Post subject: Re: Replacement westy T molding |
I went ahead and ordered some of the trim from nlavw. Let's see how it compares. _________________ Instagram: @juanskombi
1969 BMW 2002
1959 Ford F100 |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Sat Jan 21, 2017 6:57 pm Post subject: Re: Replacement westy T molding |
Juan wrote: |
I went ahead and ordered some of the trim from nlavw. Let's see how it compares. |
Did you ever find out how it compares? |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Sat Jan 21, 2017 8:03 pm Post subject: Re: Replacement westy T molding |
... lotta' valuable info here. Thanks...
When I cut my cabinet down. So, I could eliminate the blind spot and get full use of the window, I fashioned all pieces from old material, I've been saving, over the years
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Sat Jan 28, 2017 9:43 pm Post subject: Re: Replacement westy T molding |
nlorntson wrote: |
Juan wrote: |
I contacted nlavw and theirs is 18mm wide and comes in white or gray |
Juan Samba Member
Posted: Sun Jan 29, 2017 10:11 pm Post subject: Re: Replacement westy T molding |
nlorntson wrote: |
nlorntson wrote: |
Juan wrote: |
Purchased both the white and the gray from them. Having all three options (putty gray from tmolding.com, white and gray from nlavw) I'll say none of them perfectly matches the original. The closest one, at least to my eyes, is the putty gray from tmolding.com. The gray from nlavw is close but a different close, I think it matches more an aged molding. Either of these though is closer than the white, which I think is just too white though might look nicer. But I simply bought more of the gray so I'm going with that.
I've used the gray nlavw molding for the insides of the cabinet doors. For the tables I stuck with the gray from tmolding.com. I did try the gray nlavw molding on the tables but it was pretty much the same in terms of width and how much it stuck out from the table edge. With that being the same, I chose to go with tmolding putty gray which I had already used on my door folding table, and found easier to install anyway.
I'll try to snap some photos of all four molding (original + 3 options) for everyone to compare. _________________ Instagram: @juanskombi
1969 BMW 2002
1959 Ford F100 |
Juan Samba Member
Posted: Sun Jan 29, 2017 10:45 pm Post subject: Re: Replacement westy T molding |
Here you go. Side-by-side pics.
Left to Right:
Original - Putty gray (tmolding.com) - nlavw gray - nlavw white.
Original (left) and Putty gray (tmolding.com)
Original (left) and nlavw gray
Original (left) and nlavw white
Top to bottom:
Original
Putty Gray (tmolding.com)
nlavw gray
nlavw white
1969 BMW 2002
1959 Ford F100 |
Rick Samba Member
Joined: December 17, 2003 Posts: 1539 Location: Soquel, California
Posted: Wed Feb 01, 2017 7:40 am Post subject: Re: Replacement westy T molding |
fyi - it's standard practice in the cabinet making world to install t-molding like this then take a wide chisel and run it along the surface of the table, trimming the t-molding off perfectly flush. I used this t-molding on my 67 westy and did just that. Works perfect! |
lushtech Samba Member
Posted: Tue May 29, 2018 1:11 pm Post subject: Re: Replacement westy T molding |
https://www.t-molding.com/quad-edge-trimmer.html
They make a trimmer for T-molding. As Rick (above) stated standard practice is to get slightly oversized T-molding and "trim" to fit. |
