New Nokian Rotiiva AT winter offroad tire
Page: Previous  1, 2, 3, 4
Steve M.
Steve M. is offline
PostPosted: Thu Mar 08, 2018 8:41 am    Post subject: Re: New Nokian Rotiiva AT winter offroad tire Reply with quote
Steve Arndt wrote:
Should I pursue the warranty they have? They have a 60,000 mile warranty.
I love how quiet they are, the stability compared to BFG AT, and the packed snow and ice performance also compared to BFG.
Yes. Persue it if you think the wear is abnormal.
Hopefully you have reciepts if you had a shop rotate the tires for you.
You know manufacturers-they will look for every reason you are at fault.
dhaavers
dhaavers is offline
PostPosted: Thu Mar 08, 2018 3:55 pm    Post subject: Re: New Nokian Rotiiva AT winter offroad tire Reply with quote
Any 14" option other than 175 profile...???
- Dave
[EDIT] I guess not... https://www.nokiantires.com/all-season-tires/nokian-rotiiva-at/ [/EDIT] Crying or Very sad
86 White Westy Weekender
"The WonderVan"
RGS Paul
RGS Paul is offline
PostPosted: Fri Mar 09, 2018 7:04 am    Post subject: Re: New Nokian Rotiiva AT winter offroad tire Reply with quote
Steve Arndt wrote:
I have 16K miles on my Rotiivas. They are below 60% now. Worthless on snow and ice at this point. I rotated them three times in that period. My syncro seems to eat tires for lunch.
Something isn't right here. Three questions that immediately come to mind were: Where are they worn out? What tire pressures were you running? and When was the last time you had the van aligned? It could also be that your suspension is somewhat worn and has more compliance than it should. Contrary to popular belief the rear control arm bushings do not last forever.
If memory served I run my 16's pretty high, 46 front 48 rear as I recall. They have probably 25-30k miles and are worn between 40-60% on the snow bars in the tread. I might be running them a tad high at this point but the van is reasonably stable and they do not seem to be wearing the center excessively.
Paul
'87 Syncro 7-Pass. Adventure Touring Vehicle
"Simplicate, then add lightness." Colin Chapman
Guybrush
Guybrush is offline
PostPosted: Sat Jul 21, 2018 12:51 pm    Post subject: Re: New Nokian Rotiiva AT winter offroad tire Reply with quote
What pressures do you guys run on the Rotiiva? I've been a bit annoyed trying to figuring that out. I haven't put many thousands of miles on mine but I'd say they seem to wear out a lot quicker than I would expect, although it's all in-town driving on crappy roads.
Regarding pressure, if going by equivalent to the door jamb sticker for my 86 2WD, that would result in 36 PSI in front and 39 in the rear, although to keep a similar spacing as with the stock tires, you'd want to ignore the 39 and just add 6-8 PSI to the front pressure instead to use for the rear? So something like 36/42 or 36/44. (max pressure on tire is 51). 36 might feel/look a bit deflated, but perhaps it's correct.
I think that the last time I've inflated them I was at 40/42. I want to go for best safety first, hopefully keep them from wearing out too fast, and my other concern is that the van gets pretty squirelly as soon as there's a bit of wind (super straight without wind) and since I haven't tested it with any other tires, it's hard to be 100% certain that the tires have a big impact on that, but given that a lot of other things were upgraded (new Bilstein HD shocks, T3 anti-sway bar with the HD end links, poly bushings)...
davevickery
davevickery is offline
PostPosted: Sat Jul 21, 2018 12:59 pm    Post subject: Re: New Nokian Rotiiva AT winter offroad tire Reply with quote
Guy, I didn't think the Rotiiva's were squirrely compared to other tires I have tried. I did notice they were not super long wearing, but not bad, similar to Firestone Destination or Geolander ATS. I don't recall what I had mine inflated to, but I usually like 40 front 45 rear.
Guybrush
Guybrush is offline
PostPosted: Sun Jul 22, 2018 8:09 am    Post subject: Re: New Nokian Rotiiva AT winter offroad tire Reply with quote
Thanks Dave.
Steve Arndt
Steve Arndt is offline
PostPosted: Mon Jul 23, 2018 8:27 am    Post subject: Re: New Nokian Rotiiva AT winter offroad tire Reply with quote
I've been running 42 front 47 rear on my loaded tin top.
I'm either going to go with BFG AT or Cooper AT before winter time. Buying five tires $sucks.
Steve
Steve's 87 Syncro project
professorplumb
professorplumb is offline
PostPosted: Wed Jan 16, 2019 4:08 pm    Post subject: Re: New Nokian Rotiiva AT winter offroad tire Reply with quote
Steve, did you end up filing a warranty claim? If so, what was the outcome?
I'm in the same boat you are - my Rotiivas are at 60% after a year and a half and are near useless in deep snow and/or ice. Nokian's warranty page seems to have enough exclusions and caveats that it doesn't seem worth trying to make a claim though.
Steve Arndt
PostPosted: Thu Jan 17, 2019 10:57 am    Post subject: Re: New Nokian Rotiiva AT winter offroad tire Reply with quote
I couldn't find my receipt from tires by web for the Nokian purchase so I sh!t canned them.
I went with BFG TAK02 215/70R16 for replacements. Five of them of course. I also got a set of studded Cooper evo winter tires and an extra set of CLKs.
Steve
professorplumb
PostPosted: Thu Jan 17, 2019 1:34 pm    Post subject: Re: New Nokian Rotiiva AT winter offroad tire Reply with quote
Sounds good, thanks for replying. I think I'll probably do the $$$ame.
Page 4 of 4
