mcdonaldneal Samba Member
Joined: June 13, 2013 Posts: 2649 Location: Gullane, Scotland
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2875 Location: Auckland, New Zealand
Posted: Sun Feb 26, 2017 1:13 am Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
mcdonaldneal wrote: |
kiwighia68 wrote: |
We had the annual Bug Jam event here in Auckland over the weekend.
How is this for a tidy engine bay? I have the VintageSpeed roofrack: Martin has the VintageSpeed exhaust/muffler underneath.
Looks like a great day!
That is a beautiful engine bay! Real attention to detail, so I'm interested that he has put a filter on the higher pressure side of the pump.
I wonder if he's planning to paint the wood under the battery the same colour as the rest of the engine bay!? :wink:
Love your roof rack! 8) |
Hi Phil, To do him justice, Martin has just completed his restoration, and we spoke about his fuel-filter. He is going to move it to a position next to the gear box underneath and is likely going to get one of those steel and glass filters.
I'm going to try persuading him to kove the battery to under the back seat.
You should see his Ghia: The attention to detail is unbelieveble. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Fri Apr 07, 2017 8:25 pm Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
After a year of prevaricating I got around to replacing and repositioning the quarter window channels. I haven't been able to close (into the lock position) the pop-outs ever since I got my Ghia back on the road. The result was a lot of road noise in my ears.
Here's the damaged old part.
Old and new together:
I started by cleaning the bed where the channel has to sit.
Next I put some window rubber sealant under the corner to prevent/reduce leaking.
The new channel in its rubber bed: The rubber also received a dose of sealant on the underside:
Everything back together before the final rubber:
With everything reinstalled, my pop-outs can lock at last.
I took Emiko for a test drive: The car is so quiet now - with the pop-outs closed - that I'm now considering reinstalling my radio. _________________ Festina lente - hasten slowly
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Sat Apr 08, 2017 5:02 am Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
kiwighia68 wrote: |
I took Emiko for a test drive: The car is so quiet now - with the pop-outs closed - that I'm now considering reinstalling my radio. |
While it could be just a trick of the camera angle or something like that, it appears to me that the new piece looks slightly wider than the old one.
Assuming that it actually is wider, do you think that may have something to do with the quarter window being able to close more completely and lock easier now?
Perhaps with a wider area in which to spread out, the rubber seal can now compress a bit easier? |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1048 Location: Jacksonville, FL
Posted: Sat Apr 08, 2017 6:59 am Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
A quiet car is a happy car driver. Nice work. _________________
It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
Posted: Mon May 01, 2017 6:26 pm Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
I've finally got around to tackling the gas fumes problem on my car. When I turn hard right, gas fumes fill the cabin. Filled, I should say, because it's a problem no more.
There were gas stains on the paintwork in the wheel well below the air vent for the gas tank. I deduced that on a right hand turn the gas spurts out that vent. The stains are faintly visible here.
This is the kit for the cure. (I used the plastic tube to test my repair plan. I attached it to the vent tube and drove around the block. It was filled with gas.)
The problem begins and ends with the vent the gas tank needs to suck in air as the fuel pump and carbs suck gas from the tank. I plugged that vent once, and my Ghia chugged to a halt, and only recovered when I removed the plug. The vent is the small black pipe (unplugged) you see here. The other is the drain pipe for gas or water around the filler cap ('68 Ghia).
Step 1 is to attach a short piece of gas hose to the vent, like here:
Step 2 is to secure the gas hose to the splash guard with a clamp. This requires some drilling into the guard. The hose is also clamped at both ends to ensure no spill.
Step 3 is to attach the hard line (copper) and secure it also with clamps. The clamps have rubber sleeves to protect the copper from the stainless steel of the clamps.
This system allows the vent to do its work - drawing in air as the gas level in the tank falls - while also allowing gas to escape to a position under the car instead of splashing against the wheel well and finding its way in the form of fumes into the cabin.
If I were to do the job again, I would route the gas hose and copper line behind the splash guard. Come to think of it: I'll definitey do that some other day. _________________ Festina lente - hasten slowly
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Tue May 02, 2017 10:39 am Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
kiwighia68 wrote: |
Looks good, But I would recommend putting in a 'shepherds crook' in at the top , tucked in to the top of the stash guard. Just to give a little more hieght clearance from the fluid level.
Theory:
You fill up the tank full. Then go park the Ghia somewhere on an angle towards the cap side. The sun bakes down and the gas expands . Gas pushes out and starts to drip towards the new vent line....... Suddenly there is a siphon effect because the drain is below the holding tank . Later cars had and expansion can to prevent that.
Some carb-distributor combos had shepherds crooks for basically the same reasons:
Posted: Tue May 02, 2017 11:38 am Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
swavananda wrote: |
Looks good, But I would recommend putting in a 'shepherds crook' in at the top , tucked in to the top of the stash guard. Just to give a little more height clearance from the fluid level.
Theory:
You fill up the tank full. Then go park the Ghia somewhere on an angle towards the cap side. The sun bakes down and the gas expands . Gas pushes out and starts to drip towards the new vent line....... Suddenly there is a siphon effect because the drain is below the holding tank . Later cars had and expansion can to prevent that... Some carb-distributor combos had shepherds crooks for basically the same reasons:
Sound advice, no doubt, and thank you for it. I'm going to implement it today. _________________ Festina lente - hasten slowly
c21darrel Samba Member
Posted: Tue May 02, 2017 1:26 pm Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
c21darrel wrote: |
I have no idea what a "shepherds crook" is but I would have put a loop in the line up at the top. 8) :wink: |
I didn't either, but now I'm better informed (if none the wiser). Swavananda's photo of the engine bay with one in place educated me. _________________ Festina lente - hasten slowly
Posted: Tue May 02, 2017 6:32 pm Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
Implemented Swavananda's advice today: Shepherd's hook tucked in high up:
Wheel arch tidied up, as you see it here:
I bought some thicker gas line from a marine equipment supplier. He told me 2 things: "This fuel line has been approved by the US Coastguard."
And:
"Wow, that's the nicest Porsche I've ever seen." _________________ Festina lente - hasten slowly
J1 Samba Member
Posted: Wed May 03, 2017 12:10 am Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
Either you cheated and knew how that vent hose looks on later ghias or you're a clever man. Here's my 71 and I happen to be dealing with that hose now. It goes upwards, into the body, then shortly back out again as a metal line (as seen here) all the way down to the pan. Feels a little circuitous and the metal line is exposed so your solution actually looks a little cleaner!
I'll have to try a marine equipment store too for that fuel hose. Haven't been able to find one in that small diameter so I just have a vacuum hose for now.
And what are you using for that other overflow hose? It looks like a clear accordion style hose. I need a replacement there as well. _________________ 1971 Ghia coupe. Assume I know nothing and you'll be pretty darn close to the truth. |
Posted: Wed May 03, 2017 1:12 am Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
J1 wrote: |
And what are you using for that other overflow hose? It looks like a clear accordion style hose. I need a replacement there as well. |
No cheating - and I've made a fool of myself so many times that clever is not a word even I would associate with my efforts.
I've seen no post 1970 Ghias in New Zealand. My mate Dean has a '69, and Michael a '65, and they have the same problem. Dean, at least, I know does. Desperate times call for desperate measures, and after a bit of experimenting, and some help from Swavananda, I settled for the configuration you see in the photos.
As to your car: Yours has an extra pipe going into the body and exiting again, as you point out. Then there is the small pipe going towards the back of the car, but ending right there. That looks like the vent I have on mine and to which I attached the gas/fuel hose you see in my photos.
The other hose you mention (short with the 90 degree bend in it and on the right in your photo) also takes spill from the gas tank back to the tank (I think of the process as reflux). The hose I have there is impervious to gas and has a spiral wire inside. I have a small piece spare (enough for your purposes). PM me your address and I'll put it in the mail for you. I was told it is special gas line and received it at no charge.
The gas hose you need is of the same internal diameter as the ones we use for the carbs on the VW motor. It shouldn't be too difficult to find that, although I went for the more sturdy hose used in marine environments. _________________ Festina lente - hasten slowly
J1 Samba Member
Posted: Wed May 03, 2017 9:30 am Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
Thanks for your generosity on that elbow piece! PM coming soon.
Do you happen to know if that is intended to be a fuel hose and where one might find something like that? For future reference _________________ 1971 Ghia coupe. Assume I know nothing and you'll be pretty darn close to the truth. |
Posted: Wed May 03, 2017 2:37 pm Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
J1 wrote: |
Do you happen to know if that is intended to be a fuel hose and where one might find something like that? For future reference |
This is what the hose looks like I was told that it was "fuel rated."
Where to buy? I found it at a place here that sells hoses and clamps. The 2 men working there are both VW nut cases (like me) and when I showed them the application, they agreed that this hose would serve the purpose. _________________ Festina lente - hasten slowly
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13954 Location: Southampton U.K.
Posted: Thu May 04, 2017 12:53 am Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
John Moxon wrote: |
For a minute I thought you'd been drinking at the Cricket Chris... :wink:
Looks like a lot of English and Australians there, judging by the colours and uniforms. No good at cricket, but can they drink! As your photo demonstrates. _________________ Festina lente - hasten slowly
Posted: Thu May 04, 2017 12:16 pm Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
kiwighia68 wrote: |
Wow, nicely done. But it is a crook ,not hook I'm not making that up.
https://en.wikipedia.org/wiki/Shepherd%27s_crook
Although ,I'm not sure if thats the 'official VW' term for the distributer vac line..... |
Posted: Thu May 04, 2017 2:25 pm Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
Shepherd's crook it is, and I stand corrected.
Writing from a country with only 4.5 million people and more than 50 million sheep, one would have thought I would get that right.Not even counting Swavananda's prompt. _________________ Festina lente - hasten slowly
Posted: Sun May 21, 2017 10:28 pm Post subject: Re: Saving Emiko: 68 RHD Restoration in New Zealand |
I installed a speedometer gear to accommodate the smaller tyres I have on the front - 165/65/R15.
It fits on the back of the speedo - 5 minutes installation - and corrects the reading on the speedo to within about 2% accuracy.
I have a niggle with my carbs. Twin webers. From a cold start there is no problem with the car accelerating smoothly through the gears and even at low revs going uphill it pulls strongly and smoothly. Note, at low revs. However, when the motor has warmed up - say, after ten minutes of running - there is some hesitation and spluttering at low revs.
Help please. _________________ Festina lente - hasten slowly
