Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Sat Dec 14, 2013 9:26 pm Post subject: |
You are off on this. The effective stroke and engine displacement stay the same with a rod length change. A long rod engine will have a little more top end power and a short rod will have better torque down low.
Cam choice can compensate for this to some degree and many believe long rod motors are easier on the pistons and cylinders.
For street use I like short rods because the engine fits better and they drive nice. As long as you keep the rod length to stroke ratio between 1.6 to 2.0 you are good to go. Dan |
palmettofx Samba Member
Posted: Sat Dec 14, 2013 9:53 pm Post subject: |
It doesn't help that I'm drunk off toilet wine, so I appreciate your responses. |
GodJockey Samba Member
Joined: April 03, 2007 Posts: 240 Location: Lehigh Valley, Pa
Posted: Sat Dec 14, 2013 10:11 pm Post subject: |
bugguy076 wrote: |
I run a 76 strokeX92A pistons with stock length H beam rods. I think the spacers are .060. The shift point is at 7200. I have run the combo for 4 years in a drag car with no problems. No clearance troubles with stock length rods. |
That's all the spacer you needed, Im surprised. I have a 76x92 b pistons 5.5 rod and needed a .05 spacer for. 05 deck.
I have some spare 5.4 scat ibeam rods and wanted to make a turbo engine. Just fear clearancing for an 82 with I -beams ,maybe a 76 with a pistons would be the answer. |
Posted: Sat Dec 14, 2013 10:36 pm Post subject: |
I was really hoping to get away with stock pushrod length, will 74/76 be requiring cut-to-length pushrods?
I just remembered my new heads were flycut to accept 94mm jugs so I'd need them anyway, right? |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Sat Dec 14, 2013 11:27 pm Post subject: |
He thinks the shorter rods are reducing stroke. They're not. Regardless of your rod choice, a piston will still travel 74mm with a 74 stroke. We use different rods to change ratios or to achieve a certain length. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Danwvw Samba Member
David Wayne Samba Member
Posted: Sun Dec 15, 2013 6:28 am Post subject: |
I am throwing my intended combo out there for suggestions and comments. I have 94mm AA pistons now, 50cc combustion chamber, Engle 110 with 1.25 rockers. Current deck is .110 so I intend to go with a 76mm crank, adding .275 of an inch of stroke, but only .138 inches to the top. Then I will go with the 5.325 rods subtracting .070 inches. If I calculate correctly, that should render a deck of about .038, from which I will shim .020 inches to get my compression ratio, which might be a wee bit high for my cam, but I intend to deal with it in my lightweight street buggy. This is on paper, but I think I am calculating correctly. Your opinions please. |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Sun Dec 15, 2013 12:10 pm Post subject: |
math seems correct.
You know the reason you have .110 deck is because when you bore a case for 94 cylinders you are supposed to deck each side .060 too.
Watch out for leaks at the case -savers |
modok Samba Member
Posted: Sun Dec 15, 2013 12:15 pm Post subject: |
palmettofx wrote: |
hmmm, well yeah thick wall 92 are that size at the head, but if they didn't cut any deeper than it won't change anything. If the deck height is within .040 of stock then you can "probably" use stock length pushrods, but don't forget that your cam and lifters and rockers and everything..... may be a little different than OE, so you won't know till the very end. It is possible to figure pushrod length just from measuring everything but when you do measure everything you find that.........the stuff really varies! So I'm not gonna try to guess |
Posted: Sun Dec 15, 2013 7:36 pm Post subject: |
I'm between the following
76 / 5.4
74 / 5.3
I don't think I'd be able to tell the difference when driving between the two though. |
modok Samba Member
Posted: Sun Dec 15, 2013 8:41 pm Post subject: |
what heads and carbs and exhaust? |
Posted: Sun Dec 15, 2013 8:44 pm Post subject: |
New OEM heads machined to 94 - standard sized valves
dual 1bbl empi 34's (came with the car - they look like the weber 1bbls i think, and yes I knoew EMPI carbs are crap)
The best way to describe the exhaust is each port has its own pipe, never meeting, baffled. They basically turn around and point backwards.
This is on a sandrail.
I'm basically having to build this motor from the bottom on, and replace everything according to the machine shop. The only thing he said that was usable were the rocker arms, everything else was warped. The only thing I currently have is the new 94 heads and 92mm thick wall AA's. I'd rather not deal with returning those because I'm trying not to waste money (return shipment) because I'm gonna have to spend a lot on the rest of the motor. |
modok Samba Member
Posted: Sun Dec 15, 2013 8:53 pm Post subject: |
I'd use a 74 stroke then.
74 is a good size for "small" heads and carbs.
76 is just an odd size, it is the least handy of them all. 80 would be a handy size but why 76? I have no idea why we have 76 stroke cranks. |
Posted: Sun Dec 15, 2013 9:04 pm Post subject: |
Fair enough, I am very excited to be putting this motor together, and it isn't my first, just I haven't gone through replacing every aspect of the motor before and never quite had as many "cheap" options as far as engine building has gone so being flooded with aftermarket parts it's overwhelming as hell.
Thank you for your advice and such, I appreciate it. |
Posted: Sun Dec 15, 2013 10:06 pm Post subject: |
Afterthought, if I go with the 74, is it likely that I'll need non-standard pushrods? If I could I'd prefer to go ahead and order those too if there's a good chance I won't need cut ones. |
Danwvw Samba Member
Posted: Sun Dec 15, 2013 10:23 pm Post subject: |
My 5.325" Rods with a 74mm crank uses standard length push rods, It's one of the reasons I chose to go with the combination. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Sun Dec 15, 2013 10:28 pm Post subject: |
Suite, thanks!
There are too many combinations to these things, which is great, but I'd really just like to order as few times as possible since the holidays equals extended shipping/handling times it seems. |
Bret Young Samba Member
Joined: August 26, 2006 Posts: 756 Location: Turlock, CA
Posted: Sun Dec 15, 2013 11:16 pm Post subject: |
Paging mightymouse regarding medium length stroker cranks.....
76mm is considered sort of an odd size when considering stroker cranks. Some people say go stock, 78 or 82. But to each their own.
I like what mighty had to say about medium stroker's, and its what I have sitting on my shelf waiting for me to actually build it.
RIMCO stroker clearanced case set up for 82x90.5, 92mm thick walls (B pistons) turned down to 90.5 at the case, 76mm DPR crank and 5.5" I-beam rods. I haven't mocked mine up yet, but guys that have used that combo say it goes together really easy, deck is very close out of the box and is VERY close to stock width.
Lot of people say I should have just gone with an 82mm crank since my case was clearanced, but I got the crank brand new (still in plastic wrap from DPR) for 1/3 the price. |
modok Samba Member
Posted: Sun Dec 15, 2013 11:24 pm Post subject: |
The piston ends up near .060 in-the-hole with that combo only if you forgot to deck the case for the 94's to begin with, but then the engine is .060 wider per side. so no, but it does appear so in some cases.
Your engine will be .060 wider each side.
78 stroke with stock rods and AA B pistons or 94 cima, or cima 92 decked .020", or cima 90.5 decked .040" is stock width, IMO, that's easier. Cima making the pistons different heights does complicate matters tho, but it's always been that way. |
Posted: Mon Dec 16, 2013 12:21 am Post subject: |
I will have to look at the case spec's on the card thats still attached to it from RIMCO, but I know the case was decked for the thick walls. The case is setup to be built as a 82x92 thick wall engine.
They have to deck it different for 92's/94's compared to 90.5's? |
