palmettofx Samba Member
Posted: Sat Dec 14, 2013 5:04 pm Post subject: Clearancing: 92mm AA Pistons, 76mm Stroker, & 5.325" |
I have a set of 92x69 thickwall (94 top, 90.5/92 bottom) AA Performance P/C's that I bought for my bug before finding that the case that came with the car is junk.
I figured since I had to get a new case that I would go a little larger and get a low/middle stroker crank, 74/76mm, to go with my 92mm pistons.
ACN says I can use both a 74/76 crank with their 5.325 rods without too much clearancing fuss in their budget stroker article. When I go to look at the 5.325 rods to buy them they have the note stating piston skirt clearance will most likely be an issue with 76 cranks.
My question is, would anyone who's used AA 92mm pistons with a 74/76mm crank, & 5.325" rods have any insight on this specific combination of parts? I'd like to get a 76 but my feelings wouldn't be hurt with a 74mm crank.
To be as specific as I can, here's what I'm considering
Crank
Rods
Pistons
I understand this might be a shot in the dark but I figured I would see if anyone has this combo. I searched and didn't see any AA brand clearancing posts. |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Sat Dec 14, 2013 5:11 pm Post subject: |
AA's "a" pistons are are dimensionally a copy of mahle
I have used 92 "A" mahle pistons with 74 and 76 AND 78 strokes several times before, and never had to clearance the skirts.
The .070 shorter rod is like having 3mm more stroke, so.....with 74 I would not even check.
With 76-78 stroke it probably will clear, but I would take a look before balancing the pistons.
Verses a stock piston, the 92 are shorter skirt, and bigger diameter, thus less tendency to hit the crank! |
itHaKa Samba Member
Joined: February 20, 2008 Posts: 254 Location: Argentina
Posted: Sat Dec 14, 2013 5:18 pm Post subject: |
this is what my brother had to do to the skirts of his AA pistons in 88 mm
76 crank and 5.4 rods, ( 1849cc) so i assume if you use 5.3 rods and a 76 crank you will have to do it even more
complete build in my signature . _________________ 76x88 , 1849cc engine build :
http://mundoescarabajo.com.ar/me/viewtopic.php?t=635 |
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 1068 Location: Dover, PA.
Posted: Sat Dec 14, 2013 5:28 pm Post subject: |
I run a 76 strokeX92A pistons with stock length H beam rods. I think the spacers are .060. The shift point is at 7200. I have run the combo for 4 years in a drag car with no problems. No clearance troubles with stock length rods. |
Posted: Sat Dec 14, 2013 6:37 pm Post subject: |
Thank you all for your advice! |
Danwvw Samba Member
Posted: Sat Dec 14, 2013 7:24 pm Post subject: |
So if I got some Hbeam 5.4" aftermarket rods this would keep them up?
The reason I was brought on to the 5.3's was I was taking with someone about it at work Friday and he mentioned they were available. I didn't really think about it but I'm not sure I really want to get a stroker crank just to negate the stroke with a shorter rod. Seems counterproductive. |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Hell, I am building an 84mm motor with 912 rods (5.354) with mahle 90.5 b's if there is a will there is a way. I would use a 78 crank if I were you. Better yet get some b pistons 5.400 rods and build a 82mm motor. Don't let having to do some clearancing scare you it is not that big a deal. Dan |
Posted: Sat Dec 14, 2013 7:32 pm Post subject: |
palmettofx wrote: |
Nothing counterproductive about it, the vw engine had a longer than necessary rod to begin with and adding stroke without adding rod length hurts nothing. Dan |
Posted: Sat Dec 14, 2013 7:39 pm Post subject: |
It's not necessarily the clearancing that scares me, I have a machine shop that's been pretty cool thus far just a few miles from work.
It's just that I've already bought the 92x69 AA pistons and I don't really want to go through the hassle of returning them. I sent them an email asking about an RMA since they're still in the box, untouched, so I guess I'm not against going to a larger stroker.
Dan Ruddock wrote: |
Counterproductive in my case, I meant. |
modok Samba Member
Posted: Sat Dec 14, 2013 7:47 pm Post subject: |
I really don't see any problems, and to clearance the skirts is very easy anyway, just takes time, which I'll assume you have a little to spare.
I have 5.3 rods and mahle 92 a and 78 DMS racewight crank, maybe I mock this up real quick.
82mm crank costs about the same as a 76 so why not? The bigger the crank the nicer it drives but one thing to keep in mind is the longer the stroke the weaker the crank will be and the more necessary it is for a quality piece. Dan |
Posted: Sat Dec 14, 2013 7:57 pm Post subject: |
I was pricing cranks from CBPerformance, where the 74/76 cranks are about 100$ cheaper than the 78+ cranks. As well as having A pistons that I'd have to return and get replacements.
There is no rush for this build, I have all winter - I'm just not a huge fan of returning things and paying the fancy shipping for the heavy jugs would not be fun. |
modok Samba Member
Posted: Sat Dec 14, 2013 8:00 pm Post subject: |
it clears by over .100" |
Posted: Sat Dec 14, 2013 8:13 pm Post subject: |
You are a gentleman and a saint.
What is the reasoning to using the 5.3" rods in your application with a 78 stroker? You're essentially ending up with a 76mm crank after the shorter rots coupled with the 78mm crank, right? Why not run factory length and 76? I'm asking in curiosity, not doubt. |
modok Samba Member
Posted: Sat Dec 14, 2013 8:19 pm Post subject: |
I made the 5.3 rods for the next time I build a 74 or 76 stroke, the old 92 mahle A pistons are spares.
The crank is for something else, it will have 5.5 eagle rods and B pistons
so really, I the parts are unrelated, but do fit together |
Posted: Sat Dec 14, 2013 8:24 pm Post subject: |
A 78mm crank is 78mm no matter what rods you use. The CB 82mm cranks are more because they are 4340 vs. 4140 (better steel). A dpr welded crank is about the same price 78 to 82. Dan |
Posted: Sat Dec 14, 2013 9:08 pm Post subject: |
I didn't mean the crank was shorter with different rods, but the effective stroke would be - or am I completely off on this? |
modok Samba Member
Posted: Sat Dec 14, 2013 9:17 pm Post subject: |
yeah, I figure you mean "Deck height"
"Deck height" in the main engine building world means the distance from the crank center to where the head bolts on, and we like to keep this near the stock 212.5mm
In the vw world deck height can also means quench clearance, which, IMO just creates confusion. |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Sat Dec 14, 2013 9:21 pm Post subject: |
I am not sure what you mean by "effective stroke", my suggestion is that you read up on "rod ratio". Different length rods change the leverage that the rod has on the crankshaft. |
