Crank start option pictures/ dimensions - help please!
GüteAndTite
Early Convertible Güru
GüteAndTite is offline
PostPosted: Sun Dec 15, 2013 3:11 am    Post subject: Crank start option pictures/ dimensions - help please! Reply with quote
Hello there,
I know that crank start was available on buses up to around 1959 and beetles through 52/55ish? I want to add the crank start setup to my 1958 beetle and have found the rear tin with hinged hole flap, the crank start handle, and a repro bracket for the rear bumper.
heres the thing. I cant find much info about the crank start option on the net or on the samba itself. i have a few questions.
im looking for a pic of the hole in the rear apron. what are the correct dimensions for its location as well as correct diameter of the hole in the apron?
what covers this hole and keeps hot air from comoing up through it into the engine compartment- i mean vw did the hinged flap on the engine tin, but missed this? is there some unobtanium cover for the hole in the apron
how is the bumper bracket mounted? any pics of hardware?
how long was the original handle? there is a gentlemen on the samba that makes reproduction handles. I dont have my motor in currently and need to know the correct distance from the face of the crank pulley washer to the furthest point of the center of the bumper? i have an original EMPI push bar that bolts through the overrider uprights and i need to make the crank handle long enough so its 90 degree bend clears the push bar. how long was the original handle??
detailed pics of all this stuff posted here or links would be awesome!!! thanks- Bret
Official 58-60 "Early Big Window" Convertible Thread & Registry
http://www.thesamba.com/vw/forum/viewtopic.php?t=426481
F&S Saxomat Automatic Clutch System Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=462533
61-67 Delanair Air conditioning Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=457944&highlight=air+conditioning
PUNCTUATION CHANGES THE WORLD: "I need to help my uncle, Jack, off a horse" is way better than, "I need to help my uncle jack off a horse"
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Sun Dec 15, 2013 8:35 am    Post subject: Reply with quote
Here's a picture of a September 1949, maybe you can derive the location from this. Mine measures about 1 5/8" or about 42mm
Heres the crankstart bracket that mounts on the bumper with two 6mm bolts.
There is no cover on the apron hole.
JWDII
JWDII is offline
PostPosted: Mon Dec 16, 2013 1:42 pm    Post subject: Reply with quote
another pic for you to look at. maybe it will help. 1948 with wrong bumpers, so no crank mount yet.
this space for rent.
Bruce
Bruce is offline
PostPosted: Wed Dec 18, 2013 8:56 pm    Post subject: Reply with quote
The 52 and later rear bumper may put the bracket higher than that of a Split's grooved bumper. Check the height.
GüteAndTite
PostPosted: Thu Dec 19, 2013 7:04 am    Post subject: Reply with quote
what was the last year of crankstart for a beetle? ive seen a 55 with it before and a 55 should have the same bumpers as my 58, bumpers changed in 53
nlorntson
Crazy VW Lady
PostPosted: Thu Dec 19, 2013 9:57 am    Post subject: Reply with quote
From PR:
October 1949 the crankstart handle was no longer supplied on all cars (deluxe and standard) and was instead supplied only on cars ordered with the feature.
29 Aug. 58 at chassis 384 875
Starting handle was no longer supplied in tool kit, starter dog (crank pulley bolt) discontinued after present stocks are exhausted.
GüteAndTite
PostPosted: Thu Dec 19, 2013 10:13 am    Post subject: Reply with quote
nlorntson wrote:
From PR:
Chassis 384 875 must refer to a bus?
billmetric
billmetric is offline
PostPosted: Thu Jan 02, 2014 2:38 pm    Post subject: Reply with quote
Virtanen in finland is making new crank guides:
http://www.thesamba.com/vw/classifieds/detail.php?id=1332624http://www.restorationpanels.com/
There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there...
GüteAndTite
PostPosted: Thu Jan 02, 2014 5:56 pm    Post subject: Reply with quote
Yes - I have one of these -
GüteAndTite
PostPosted: Sat Apr 18, 2015 1:23 am    Post subject: Reply with quote
Anyone know the dimensions of a beetle crank start handle?
JWDII
JWDII is offline
PostPosted: Tue Apr 21, 2015 11:13 am    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=1090316
This may help. I would think the supplier should be able to help
Mr. OGPaint
Mr. OGPaint is offline
PostPosted: Thu Mar 25, 2021 3:37 pm    Post subject: Reply with quote
Bump, the overall length would be a very helpful bit of information that would help me right now. Can anyone measure their beetle handle please?
https://instagram.com/mr.ogpaint
Patrick Hall
Zwitter UK
Zwitter UK is offline
PostPosted: Fri Mar 26, 2021 9:31 am    Post subject: Re: Crank start option pictures/ dimensions - help please! Reply with quote
I'll have a look at mine at the weekend and do some measurements for you
Good day sir
Zwitter UK
PostPosted: Sat Mar 27, 2021 3:11 am    Post subject: Re: Crank start option pictures/ dimensions - help please! Reply with quote
Here you go - mine measures like this:
Good day sir
Mr. OGPaint
PostPosted: Sat Mar 27, 2021 6:53 am    Post subject: Re: Crank start option pictures/ dimensions - help please! Reply with quote
Thank you sir!
Patrick Hall
Suboval
Suboval is offline
PostPosted: Sat Mar 27, 2021 12:42 pm    Post subject: Re: Crank start option pictures/ dimensions - help please! Reply with quote
If you are looking for a crank handle (not mine): https://www.thesamba.com/vw/classifieds/detail.php?id=1090316
He can also make the early version:
It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history.
