Flickering alternator light is a sign of?
gatorjos
gatorjos is offline
PostPosted: Thu Dec 19, 2013 8:52 am    Post subject: Flickering alternator light is a sign of? Reply with quote
My alternator light is coming on when revs are high (over 65mph in 4th, over 45 in 3rd). It doesn't come on solid though. It sort of ghosts on and off. Not quite a flickering.
- Is my voltage regulator on its last legs?
- is my relatively new alternator a dud?
- is it the ghost of Jerry Garcia?
The alternator appears to be charging fine, but we are about to cross the border to Baja Mexico so I want to know if I should pick up spare parts. Thanks!
1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
1972 Ghia cabriolet (full body-off restoration -- stolen after five years of ownership)
2004 Passat 1.8T (manual)
http://21stcenturyhobo.com
SGKent Premium Member
SGKent is offline
PostPosted: Thu Dec 19, 2013 8:55 am    Post subject: Reply with quote
could be a bad alternator - could also be a bad VR, loose wire or a slipping belt. So yes, if it were me I would carry a spare of each.
aeromech
aeromech is offline
PostPosted: Thu Dec 19, 2013 9:29 am    Post subject: Reply with quote
Drive that thing down to Autozone and have them hook up their fancy tester to your bus. They can check the alternator and tell you specifically if it's bad diodes or VR. It's free!
I had them do this to my Daughter's Passat and was able to remove and replace just the VR from the alternator while in place. Saved me a bunch of headaches because in that car you need to remove the entire front bumper/grill in order to remove the alternator. $50 job instead of about $250 for the whole alternator.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Wasted youth
Wasted youth is offline
PostPosted: Thu Dec 19, 2013 9:46 am    Post subject: Reply with quote
Don't listen to those guys. You damn well know that's Jerry's ghost. Handle it.
mikedjames
mikedjames is offline
PostPosted: Thu Dec 19, 2013 11:14 am    Post subject: Reply with quote
Ok I could add loose feed from alternator b+ to battery.
Worn brushes on the alternator.
Had both at the same time.
Cost me a battery and a set of new brushes.
SGKent is offline
PostPosted: Thu Dec 19, 2013 2:37 pm    Post subject: Reply with quote
I have seen brushes do that so that could be it too. If so unless they are in a carrier that easily comes out the alternator has to come apart.
geopanoramic
geopanoramic is offline
PostPosted: Thu Dec 19, 2013 3:26 pm    Post subject: Reply with quote
Smartass comment would be - "Dude, it's a bus..."
but curious about your solution.... Also:
I like this comment by mikedjames:
I had an alternator really kill itself and a battery in 88 Subaru. I was curious how that happens.... can't remember how or why....
Combo electrical problems (as mentioned above) are successively hard to solve, and occasionally very weird.
