BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Mon Apr 29, 2019 10:43 am Post subject: Re: Bus Rear / Back Seat information thread |
SpreadinTheLove64 wrote: |
Hi, just wanting to confirm that this is a early 68-73 rear seat? |
Just to be certain maybe post this same post in the Bay threads? |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Mon Apr 29, 2019 1:48 pm Post subject: Re: Bus Rear / Back Seat information thread |
Hi, just wanting to confirm that this is a early 68-73 rear seat? It has holes on the bottom of the legs, and a rounded seatback ilo the squared which I believe is the later bus from what i’ve researched? I’m still learning and am in process of re-doing this seat for my 64 split window, didn’t want to spend a small fortune on a split window rear seat. One other question I have (as I’m told the early bay seat will fit) is will I have any issued with it when I go to put heat in it down the road? Sorry if that’s a stupid question. I’m thinking for some reason I read somewhere that it might. Thanks in advance for anyone who’d be so kind as to shed light and clarify.
That is definitely bay window tan upholstery. If the pics of the bare frames are from that same seat, you have an early bay seat. It will be a little narrow for your split, but it can be made to work.
Are you worried about turning the heat on in the rear and melting something? If so, as log as you do not have anything directly in front of the heat outlet, you will be fine. I melted a plastic water bottle in my 64 bus one time. It fell down there while driving and I didn't notice until much later. _________________ nothing |
volkswagen60 Samba Member
Posted: Fri Oct 18, 2019 10:49 pm Post subject: Re: Bus Rear / Back Seat information thread |
Looking for help identifying what year(s) these pieces were originally from?
And looking for opinions on what a fair asking price would be?
Thanks!
_________________ http://www.vw-trader.com |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Sat Oct 19, 2019 9:37 am Post subject: Re: Bus Rear / Back Seat information thread |
EverettB wrote: |
The little tab on the bottom of the back rest means it's from a Bay Window, I believe they are the same from 1968-1978?
Upholstery has been replaced, of course
Search rear seat in the Bay Window parts section for possible values:
https://www.thesamba.com/vw/classifieds/search.php...=rear+seat
Tab reference:
Thanks. I figured the top was probably bay, but the bottom doesn’t have holes in the bottom of the legs so the bottom through me off a little.
Thanks for the info. _________________ http://www.vw-trader.com |
Posted: Sat Oct 19, 2019 3:59 pm Post subject: Re: Bus Rear / Back Seat information thread |
I did not think about the seat bottom clamp holes but I can't see that area in the photos.
The seat bottom would only have holes in the tops of the legs for the clamps - they are not drilled all the way through.
If there are no holes on the legs, it could be a Split Bus seat bottom _________________ How to Post Photos
Posted: Sat Oct 19, 2019 9:45 pm Post subject: Re: Bus Rear / Back Seat information thread |
EverettB wrote: |
If there are no holes on the legs, it could be a Split Bus seat bottom |
No holes at all on legs. Looks like back is from a bay, bottom may be from a split. _________________ http://www.vw-trader.com |
Posted: Sat Oct 19, 2019 9:49 pm Post subject: Re: Bus Rear / Back Seat information thread |
volkswagen60 wrote: |
EverettB wrote: |
No holes at all on legs. Looks like back is from a bay, bottom may be from a split. |
Ok, I think the seat bottom is probably the mid-63 to 1966 style then, according to some pics in the first post of this thread where it shows how one of the legs changed shape. _________________ How to Post Photos
james309 Samba Member
Joined: October 09, 2016 Posts: 24 Location: Gloucestershire, England
Posted: Tue Nov 05, 2019 4:13 am Post subject: Re: Bus Rear / Back Seat information thread |
On a pre 60 bus is the rear seat in a microbus only supported by the 2 brackets ?
Is the base connected to the back ?
I have the 2 brackets, does anyone know the bolt/screw sizes ?
TIA |
Posted: Tue Nov 05, 2019 9:58 am Post subject: Re: Bus Rear / Back Seat information thread |
Thanks Everett,
Most helpful. |
Posted: Tue Nov 05, 2019 1:46 pm Post subject: Re: Bus Rear / Back Seat information thread |
Does anyone have pictures of the mounting of their seat, with wing nuts & plates under seat frame ?
Also I bought some retro WW clamps, which have a locating pin yet the 2 OG clamps don't.
Any thoughts ?
James |
Posted: Tue Nov 05, 2019 4:36 pm Post subject: Re: Bus Rear / Back Seat information thread |
james309 wrote: |
Any thoughts ?
James |
The rear seat does not have plates, that is for the middle seat with a floor mat only.
The locating pin is 1967 up so if you have an earlier Bus you should grind those off.
I couldn't find a great pic of the rear seat mounting clamps but here's 2 photos I did find
Slip t-bolt into floor mount, rotate it 90 degrees so it stays in place, slide bracket over it, secure with nut (or wingnut) _________________ How to Post Photos
Posted: Thu Nov 14, 2019 7:54 pm Post subject: Re: Bus Rear / Back Seat information thread |
Thought this was a good thread for this. These pieces of wood were in my 66 bus when I bought it. It looks like they were used to mount a later seat bottom frame (with holes in legs). The bolt with the big washer slides into the original slot.
vwcollective Samba Member
Posted: Sat Nov 16, 2019 9:44 am Post subject: Re: Bus Rear / Back Seat information thread |
I’m trying to determine if this rear seat seat-back is correct for a November 55 built Wolfsburg bus? I realize there is a curve to the profile but not sure how flat a correct seat would be for this year?
Any help is appreciated.
Posted: Sat Nov 16, 2019 6:21 pm Post subject: Re: Bus Rear / Back Seat information thread |
Bummer - thanks for the help Everett! |
Posted: Sat Nov 16, 2019 7:35 pm Post subject: Re: Bus Rear / Back Seat information thread |
vwcollective wrote: |
Everett’s a heartbreaker with all his facts. Shattering hopes and dreams. _________________ http://www.vw-trader.com |
Posted: Sat Nov 16, 2019 9:58 pm Post subject: Re: Bus Rear / Back Seat information thread |
If anyone has a good pic of a Standard or Deluxe flat back back seat backrest, please post a pic in this thread so I can add it to the reference listing in the first post of this thread.
I have a black back rest I will try to photograph soon but it would be nice to have one with the Standard/Deluxe pleats too. _________________ How to Post Photos
banana split Samba Member
Joined: January 22, 2002 Posts: 1070 Location: Beautiful British Columbia Canada
Posted: Mon Jan 27, 2020 3:53 pm Post subject: Re: Bus Rear / Back Seat information thread |
I have a hardware question : exactly what type of screw or bolt is used to fasten the rear luggage bar to the backside of the seat?
I would have assumed it was some kind of self tapping screw - similar to something like this (I know these are tiny) :
I double checked a parts manual that I have and found this information :
Qty 6
N 11 976 1
Screw, countersunk raised head AM 6x25 DIN 91 high polish galvanized
I did a search of the classifieds for N 11 976 1 and found these :
https://www.thesamba.com/vw/classifieds/detail.php?id=1498898
Are these correct? I see the installed photo shows a Phillips head while the NOS screws are flat head.
Or was a self tapping style screw used?
Are the seat frames drilled & tapped to accept a threaded screw?
Thanks _________________ My Beetles :
1953 Zwitter
1964 Chop Top |
