EverettB Administrator
Joined: April 11, 2000 Posts: 69697 Location: Phoenix Metro
banana split Samba Member
Joined: January 22, 2002 Posts: 1068 Location: Beautiful British Columbia Canada
Posted: Tue Jan 28, 2020 11:27 am Post subject: Re: Bus Rear / Back Seat information thread |
Great! Thanks for the reply. This answers my questions. _________________ My Beetles :
1953 Zwitter
1964 Chop Top |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2327 Location: Kelowna, BC. Canada.
Posted: Sun Feb 16, 2020 1:39 pm Post subject: Re: Bus Rear / Back Seat information thread |
I am in the midst of covering my '67 seats and have a question about the back of the seat back.
Was there a pressed particle board support in the back to help support the cover material from shifting cargo?
In this photo there is obviously no support.
Yet in this photo the back seems to be well supported.
Also, my '67 seat back has 7 holes drilled into the top bar that look as though they are to attach a protective edge piece similar to the above picture.
Any thought?
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
Posted: Sun Feb 16, 2020 6:07 pm Post subject: Re: Bus Rear / Back Seat information thread |
Yes, here's the backing board from when I took a '60 Deluxe rear seat back apart
It's pretty thin board, less rigid than a door panel
You have a Bay Window seat so not sure about the guard along the top but if it has holes, maybe it has that same metal guard? _________________ How to Post Photos
Posted: Sun Feb 16, 2020 6:35 pm Post subject: Re: Bus Rear / Back Seat information thread |
Thanks Everet,
I assume that is the same for middle seat too?
Posted: Tue Feb 18, 2020 10:15 am Post subject: Re: Bus Rear / Back Seat information thread |
EverettB wrote: |
Yes and the ash tray holder rivets to it too |
You are awesome, as always. Thanks.
I may opt for something slightly beefier on my seats, as long as I can keep the lines of the upholstery correct.
Peter_N Samba Member
Joined: February 19, 2014 Posts: 321 Location: The Netherlands
Posted: Mon Mar 30, 2020 12:48 pm Post subject: Re: Bus Rear / Back Seat information thread |
Hi there!
I’m looking for a few dimensions of a splitbus seat. Did use the search function of course but could not find it yet.
I have a rock and roll bed that has to be narrowed anyway, so I’m planning to cut the legs of and replace them and make it look a bit more correct.
(Not my picture, borrowed from this topic).
I’m looking for the tube diameter, heights and how far the legs are apart
Many thanks! _________________ My 1958 PGSG project topic |
teahead Samba Member
Joined: October 30, 2019 Posts: 326 Location: Seattle
Posted: Tue Apr 07, 2020 12:58 pm Post subject: Re: Bus Rear / Back Seat information thread |
I have a 1963 rear seat, but only on the bottom.
I'm missing the seat back.
I plan on installing Z hinges so it lays flat. Is it possible to get a rear seat back that's flat, from say, a different year that will still work?
I think this is from a 62, but same as 63? Curved? Don't really want that.
_________________ '63 German Walk-Thru Deluxe 15-window - SOLD |
volkswagen60 Samba Member
Posted: Fri May 01, 2020 12:07 am Post subject: Re: Bus Rear / Back Seat information thread |
Need help identifying this seat bottom and back rest.
The bottom does not have holes in the legs to mount to floor. The outer leg rails that lay on floor have dimples or ‘indentions’ on top of them.
_________________ http://www.vw-trader.com |
Stocknazi Samba Member
Posted: Fri May 01, 2020 8:05 am Post subject: Re: Bus Rear / Back Seat information thread |
The seat top is later bay (mid 70's?); bottom probably too based on covers; not sure why there are no holes for the clamps, but maybe later bays do not have holes?
I believe all split lower rear seats have provisions for the heater log. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
velvetgreen Samba Member
Posted: Fri May 01, 2020 9:37 am Post subject: Re: Bus Rear / Back Seat information thread |
^^ late bay- in the picture you posted you the bottom of the seat turned around 180 degrees from where it should be (back in facing the front) |
Posted: Fri May 01, 2020 9:46 am Post subject: Re: Bus Rear / Back Seat information thread |
velvetgreen wrote: |
Oh haha. Thanks! _________________ http://www.vw-trader.com |
fotoroadie Samba Member
Joined: May 07, 2013 Posts: 180 Location: Manitowoc, WI
Posted: Sun Sep 13, 2020 4:07 pm Post subject: Re: Bus Rear / Back Seat information thread |
Looking for floor positioning guide to mount these seat brackets. '59 Kombi.
Thanks,
Bobby
Posted: Sun Sep 13, 2020 6:25 pm Post subject: Re: Bus Rear / Back Seat information thread |
EverettB wrote: |
For the rear seat base?
Right in the middle of the cargo floor indents
1959 had 4.
Mid-63 up only had the rear-most 2 brackets, one on each side |
Thanks, that's helpful.
Regards |
eddie.would.go Samba Member
Joined: September 02, 2005 Posts: 84 Location: in the garage
Posted: Sun Sep 25, 2022 7:09 am Post subject: Re: Bus Rear / Back Seat information thread |
As far as rear seat bases go… is there a difference between the bottom covers over the years? For example, will a 57-60ish original seat cover fit on a flat back rear seat bottom or is the bottom a different shape/profile as well? I realize the springs are different but is the cover the same? |
Highbody Samba Member
Joined: January 04, 2022 Posts: 6 Location: North east ct
Posted: Tue Sep 27, 2022 2:35 pm Post subject: Re: Bus Rear / Back Seat information thread |
flemcadiddlehopper wrote: |
Anyone have an idea of the distance the screws for the rear seat mounting brackets are from the top and side? I don’t want to cut a million holes |
Posted: Tue Sep 27, 2022 3:34 pm Post subject: Re: Bus Rear / Back Seat information thread |
Highbody wrote: |
Top hole to top of seat - 65mm
Top hole to side of seat - 30mm
Distance between 2 holes - 15mm
