Waterless Engine Coolant ??
randywebb
randywebb is offline
PostPosted: Wed Jan 01, 2014 5:56 pm    Post subject: Waterless Engine Coolant ?? Reply with quote
Anybody tried a Waterless Engine Coolant?
thoughts?
1986 2.1L Westy 2wd Auto Trans.
D Clymer
D Clymer is offline
PostPosted: Wed Jan 01, 2014 6:08 pm    Post subject: Reply with quote
If you're talking about non-aqueous propylene glycol, I always thought it was a great idea until if found out it was flammable. If you look on the Evans website, they provide many testimonies from over the road truckers who run it in their wet sleeve industrial diesels with great results - no corrosion. So it probably would work wonders for the WBX contact corrosion issue, but IIRC they also admit on that same website that its flash-point is in the range of hot exhaust manifolds. With the Vanagon's circuitous, plastic intensive cooling system in mind, I stopped considering it at that point.
D
morymob
morymob is offline
PostPosted: Thu Jan 02, 2014 7:01 am    Post subject: Reply with quote
Growing up on a farm some people around filled their tractors with kerosene, none had any fire problems, no freezing either but my uncle did switch to water 4 the warm season.
insyncro
Banned
insyncro is offline
PostPosted: Thu Jan 02, 2014 9:05 am    Post subject: Reply with quote
I run Evans coolant in two H6 converted Syncros.
Evans is a sponsor of our race machines so it is available to me at no cost.
Works well and only sees summer driving in these vans.
MarkWard
MarkWard is offline
PostPosted: Thu Jan 02, 2014 2:59 pm    Post subject: Reply with quote
Some of these coolants require a cleaning/flushing of the cooling system which is easy to do once. If you travel, you will need to carry enough coolant to fill the system in the event you get a leak or open the system. Regular anti freeze is available anywhere, mixes with water and most other products.
insyncro
Banned
insyncro is offline
PostPosted: Thu Jan 02, 2014 5:15 pm    Post subject: Reply with quote
David's flash points are valid.
I have removed all plastic junctions from my systems, have aluminum tanks and silicone hoses.
I personally have not had Evans ignite and it has hit plenty of cherry red exhausts manifolds at the track.
nacradriver
nacradriver is offline
PostPosted: Thu Jan 02, 2014 6:27 pm    Post subject: Reply with quote
Saw this on Wheelers and Dealer last night as the were putting it in a TR-6...
Nice coincidence!
Güdrun -1989 Westfalia - 2013 - 2018
Petra - 1985 Vanagon - 1985 to 1991
Zisa - 1974 VW Van "Bus" - 1974 to 1985
Dampcamper
Dampcamper is offline
PostPosted: Thu Jan 02, 2014 6:33 pm    Post subject: Reply with quote
I've been using a waterless engine coolant for decades, it's called "Air"...
