carterzest Samba Member
Joined: January 22, 2008 Posts: 3842 Location: Eagle, ID/Sun Valley, ID
Posted: Wed Jan 01, 2014 9:14 pm Post subject: STOLEN: 1990 Syncro Westfalia Weekender (Tacoma,WA) |
With Mod approval, I am posting one that appears to have slipped through the cracks. Thanks MadMaxine for the tip. The announcement of this one being stolen was buried in another thread.
1990 Syncro Westfalia Weekender *STOLEN* ~ 11/24/13 Tacoma Washington
adamsushi77 wrote: |
THIS VAN WAS STOLEN ON 11/24/2013 FROM TACOMA WA
PLEASE FORWARD ANY INFO VIA THIS ADD OR CONTACT TACOMA P.D.
1990 Vanagon Syncro Westfalia w/ carat-weekender interior:
This vehicle has undergone a complete exterior restoration including:
-cutting/nutralizing/recaulking all body joints and seams
-R&R all windows and doors (new rubber seals installed)
-smooth sanded pop top
-tinted spray-on bedliner on lower body (color matched to V.A.G spec)
-painted door jambs
2.1L waterboxer
Syncro (4WD/AWD) w/ rear diff lock (new diff lock actuator)
4speed manual w/ granny low
pwr windows
pwr mirrors (heated)
cruise control (that really works)
Removable sunroof over driver and passenger (that doesnt leak a drop!)
148,000 miles on van
40k on rebuilt engine
15k on rebuit transmission
New brakes Front and Rear (disks, drums, complete fluid change and master cyl)
New wheel bearings (front and rear)
New front ball joints
New 2" GOWESTY lift springs
New syncro.org/ Old Man Emu shocks and struts
New water pump
New coolant lines
New fuel pump and filter (the old one still works and is included as a spare)
New U-joints and rebalanced driveline
New front heater/blower motor
New canvas top with full zipouts
New westy mattress up top with new washable cover
New battery
New Bosch starter
New Das Mule rocksliders color matched to lower body
Also included is a RARE westy lav cabinet that sits behind either the driver or passenger front seat. This houses a small portable toilet that will make any cowboy or cowgirl feel right at home out on the range.
Set of six (6) Audi wheels with matching 235/ 70R 16 A/T tires...thats right, two full size matching spares. All tires have 80% tread and come with receipt from Les Schwab for hassle free waranty, repair, rotation, etc.
Also have set of four studded snow tires mounted on stock syncro steelies.
Alignment was done at time of new tire install. |
kamzcab86 wrote: |
I assume a van is missing until someone says it's been found. The ad still says "stolen", so...
If you want to start a thread on it, go for it. If it's still missing, perhaps it'll get found since the announcement of this one being stolen was buried in another thread.
All vans listed as stolen on TheSamba will be put into a PDF and uploaded to my blog (which I'm swamped with updating after only two years!... new URL coming!)... it'll be easier to keep track of that way, rather than in the forum.
Further info: http://www.thesamba.com/vw/classifieds/detail.php?id=1561613
Lets get this one found folks. Please share liberally. I have PM'd the owner for more information as we have had really good success with this format in this forum. Fingers crossed! _________________ Happiness=Portland, Oregon in the rearview mirror! |
