Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Sun Jan 05, 2014 1:47 pm Post subject: Frozen door hinge |
The passenger door on my 1959 VW bus that I am restoring has a frozen lower hinge. Someone over in the split window bus section recommended pouring some muriatic acid over the hinge. Does anyone recommend this and, if so, should I mix it with water like I have done when cleaning the inside of fuel tanks? _________________ Don't worry; be happy. (Baba) |
racoguy Samba Member
Joined: May 15, 2010 Posts: 687 Location: new zealand
Posted: Mon Jan 06, 2014 2:26 am Post subject: Re: Frozen door hinge |
Campy wrote: |
The passenger door on my 1959 VW bus that I am restoring has a frozen lower hinge. Someone over in the split window bus section recommended pouring some muriatic acid over the hinge. Does anyone recommend this and, if so, should I mix it with water like I have done when cleaning the inside of fuel tanks? |
Heat it up with a torch and have a helper open and close the door while spraying wd40 at the hinge pin, have used this technique many times. |
far rider Samba Member
Joined: August 30, 2005 Posts: 771 Location: Rutland, VT
Posted: Mon Jan 06, 2014 4:46 pm Post subject: |
Here's what has worked for me. I soak the pin/hinge in pb blaster or a 50-50 mix of acetone and automatic transmission fluid. I apply liberally several times a day for a few days. Sometimes this will be enough. If not I then use an air chisel with a punch attachment and hit the bottom of the pin driving it up. Always works. Whatever method you use good luck. _________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
oldmanmark Samba Member
Joined: July 08, 2006 Posts: 842 Location: n.w. indiana,chicagoland
Posted: Sun Jan 12, 2014 3:52 pm Post subject: |
every time i went into the garage for whatever i sprayed frozen hinge with WD40. after several weeks took channel locks and tried to break loose. Nope. try over n over. got out the propane and heated it up each trip into garage and it wiggled more. added WD40, heat until free. never severe heat. several months. |
Campy Samba Member
Posted: Fri Apr 11, 2014 1:37 pm Post subject: |
I will try spraying more PBblaster on the hinge for several days, then get out the air chisel with a punch on it. If that does not work, I will heat it up. What if it still won't break free? _________________ Don't worry; be happy. (Baba) |
Campy Samba Member
Posted: Fri Apr 18, 2014 2:00 pm Post subject: |
PB blaster has not loosened the hinge. Muriatic acid did not loosen it. I put a punch on my air tool and all that did was spread out ther bottom of the pin. I used a propane torch to heat it and that did nothing. Should I use my oxy/acetelyne welder to heat it up? I am worried that too much heat will ruin it. What else can I do? This is really disturbing. _________________ Don't worry; be happy. (Baba) |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Apr 18, 2014 2:22 pm Post subject: Re: Frozen door hinge |
racoguy wrote: |
Campy wrote: |
racoguy says he's used this technique many times. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Campy Samba Member
Posted: Tue Apr 22, 2014 9:34 pm Post subject: |
The center part of the piece that the pin goes through is attatched to the front part of the hinge (on A pillar) and stays stationary (the top and bottom pieces are attatched to the rear part of the hinge on the door and move with it), which must be where the pin is frozen. I would like to soak the hinge but there is no way to do it. There seems to be no way to get PB blaster inside the piece by spraying it over it. _________________ Don't worry; be happy. (Baba) |
Campy Samba Member
Posted: Sat May 10, 2014 2:19 pm Post subject: |
I have continued to spray PB blaster over the hinge and it is still stuck. There is no way to get the liquid insided the hinge to the pin. I would like to soak the hinge in a solvent but there is no way to have a container around the hinge. _________________ Don't worry; be happy. (Baba) |
MMW Samba Member
Joined: April 30, 2012 Posts: 846 Location: northern NJ
Posted: Sun May 11, 2014 1:29 pm Post subject: |
I would heat the hinge with oxy/acet real hot, even cherry red if needed. At this point you don't have much to loose as nothing else has worked.
You could also drill a small hole in each section of the hinge to spray pb in it to soak.
Drill out the pin & replace it with a new one? _________________ Mic
1959 356 coupe
Missing the original engine 72488
Update - third pc. found!
Now just need the case halves.
1965 fenderless beetle |
Middle child Samba Member
Joined: April 18, 2009 Posts: 119 Location: Minnesota
Posted: Sun May 11, 2014 1:41 pm Post subject: |
Nobody has addressed heat warping the door...years ago we used in the auto body field asbestos in a paste form about as thick as toothpaste but made entirely of asbestos...probably illegal and not recommended today. I've done the heat with acetylene torch wd/40 it works....no more paint left but it works. |
Campy Samba Member
Posted: Mon May 12, 2014 7:55 pm Post subject: |
I tried a propane torch so the paint is already messed up; the bus is going to be repainted, anyway.
I had thought of drilling two little holes, one on each side, into that center part of the hinge that the pin is stuck in. Once freed, I would cover each hole with a tack weld.
How about grinding off the head on the pin, supporting the base of the hinge with a board between it and the floor, then trying to pound it out? Also, PB blaster might trickle down from the top. Are new door pins available? _________________ Don't worry; be happy. (Baba) |
ritchiet002 Samba Member
Joined: January 27, 2003 Posts: 1676 Location: Kaneohe, HI
Posted: Sat May 31, 2014 12:25 pm Post subject: |
Campy wrote: |
How about grinding off the head on the pin, supporting the base of the hinge with a board between it and the floor, then trying to pound it out? Also, PB blaster might trickle down from the top. Are new door pins available? |
If you are going to do that, why not drill the pin out? Start small and work up. If you screw up you could ream out and use/make and oversized pin? Not sure they are available aftermarket, but it seems simple enough for a machinist _________________ Somewhere there is a jar with your name on it!
From now on, I'm gonna connect the dots my own way!______________________________________ |
Campy Samba Member
Posted: Fri Jun 13, 2014 1:45 pm Post subject: |
I drilled a small hole in the upper rear side of the center part of the hinge where the pin is stuck and I have been spraying PB blaster in there, then putting a sheet metal screw in the hole to try and hold the solvent in. It is as frozen as ever. _________________ Don't worry; be happy. (Baba) |
Posted: Fri Jun 13, 2014 1:58 pm Post subject: |
Take it to a Muffler Shop if you are skeered to put heat on it and drive it out. They can weld up the new screw hole while it's there. You've been dinking around with this for 5 months. _________________ https://imgur.com/user/FisherSquareback/posts
