obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 2928 Location: East Northport, NY
Posted: Tue May 17, 2016 3:14 pm Post subject: Re: Restoring Camper Top |
So, I'm getting moving in my top. My canvas was in good shape, but it was gray, had some stains and overall I just wanted the yellow.
I came home from work today and started removing the screws around the alumnus trim. I got all out, and in a jar then marked my trim pieces so I put them back in the same places.
I rolled my canvas up a bit and was able to get to the staple strip.
Now, I have bought new strip from BD, but am more concerned about the condition of the roof.
Can someone tell me, should I be worried about this? What should I do to preserve the integrity of the wood/strips where the canvas staples to?
_________________ Mike
1964 Beetle
2001 Eurovan Camper |
curtp07 Samba Member
Posted: Tue May 17, 2016 6:12 pm Post subject: Re: Restoring Camper Top |
In keeping it simple and under $30, I used plastic pipe hangar from Home Depot for the staple strip, and rustoleum semi gloss with the finest small roller I could get (2 coats no finish sanding). Looks very good and I'm not doing anything new that hadn't been talked about here. The rustoleum seems to get thumbs up.
Installing the top canvas I removed the upper bunk and it made the job much easier than my other bus...
http://www.thesamba.com/vw/forum/viewtopic.php?t=636839 _________________ Subaru |
yellowCOwesty Samba Member
Joined: April 16, 2016 Posts: 97 Location: Rocky Mountains
Posted: Tue Jul 26, 2016 11:09 pm Post subject: Re: Restoring Camper Top |
Just a quick reply to say thank you to the previous posters in this thread. Been a lurker here for a while and have not posted until now. This is my second bus, had a 78 back in college and decided to get one before these follow the air cooled 911 market into the stratosphere....
After a lot of reading here I tackled the canvas this past weekend leaving the top on. Like everyone said, just took my time with lots of breaks, mainly because it was 90+ degrees out an HOT in the bus. There are a few wrinkles, but I am pleased with my first attempt at this.
Bill
Hoody Samba Member
Posted: Wed Jul 27, 2016 1:32 am Post subject: Re: Restoring Camper Top |
Mike...I would not be too concerned with the wood unless you see rot. The key is using stainless staples and an electric staple gun. If the tack strip you bought splits at all during the process. Take it off and start over. I bought my tack strip from Jeffrey at BusOk....who probably buys it from Adam at NLA VW parts. I imagine that your strip is sourced from the same place. Take your time. That wood that Westfalia used is usually still very strong and rot free. If you still have the old strip you will notice they were not shy with the staples. I would "tack" it into place to make sure your happy with the fit first. Then go to town with the staple gun. |
Posted: Wed Jul 27, 2016 9:16 am Post subject: Re: Restoring Camper Top |
Thanks! I did use some exterior grade wood putty to fill in the larger "gaps" just so that there was a level surface for the tack strip to bind to.
Got the surface flush and did exactly what you mentioned. The tent came out great. I have one spot I wish was a bit more taught, but I think I am over-inspecting it.
Used the tutorials here and was very pleased. Not difficult, just time consuming and I had to be a bit of a contortionist.
I also painted the roof and put on all new seals.
I think I put some pics in my build thread. _________________ Mike
1964 Beetle
bus_lover Samba Member
Posted: Wed Jul 27, 2016 5:05 pm Post subject: Re: Restoring Camper Top |
I just got a 73 westy. The Tent looks to be in good condition but doesnt seem to stay up- is there a trick? The hinges dont seem to have enough room to lock out.
Also, is it supposed to be stapled all the way around on inside?
And does the 73 westy not come w a bunk up top- can you only order the cots? If so, do they have to be removed when top is down? I guess there is room for only one cot?
Thanks for the help! |
Hoody Samba Member
Posted: Wed Jul 27, 2016 11:50 pm Post subject: Re: Restoring Camper Top |
That's great to hear Mike! Keep in mind that if you have a cotton poptop tent that it will shrink and stretch a bit with moisture and heat. You may find that with a little time the fit is perfect. My first Westy had the original tent and it was almost too tight. Over time I think it shrunk and eventually ripped in places. So a little loose isn't going to hurt....too tight may over the long haul. |
Dandelion Samba Member
Joined: September 08, 2014 Posts: 14 Location: Los Angeles, California
Posted: Wed Oct 05, 2016 1:32 pm Post subject: Re: Restoring Camper Top FAQ |
Does anyone have a resource for camper top/fiberglass refinishing? I don't have the desire to do it myself.
I'm in North East Los Angeles.
Thanks! _________________ 1971 Campmobile
1989 Westfalia
1988 Vanagon
1994 Jetta
1981 Jetta
1973 Bug |
Sally the Bus Samba Member
Posted: Tue Feb 14, 2017 12:52 pm Post subject: Re: Restoring Camper Top FAQ |
Reviving this thread....
When you guys say "rust oleum" bright white. Do you mean the topside paint they make for boats?
or the normal enamel like this? http://www.homedepot.com/p/Rust-Oleum-Stops-Rust-1...lsrc=aw.ds
I would think the topside has better UV resistance?
I'm about to do this project this weekend! |
BusterBrown Samba Member
Joined: December 15, 2009 Posts: 1397 Location: Arizona
Posted: Tue Feb 14, 2017 2:08 pm Post subject: Re: Restoring Camper Top FAQ |
Sally the Bus wrote: |
I used the off the shelf type you listed from Home Depot. That was a few years back, and it seems to be holding up well. Yes, I would imagine that the boat variety would be better, and cost more. Just my opinion. _________________ 1978 Sage Green Westfalia (Happy Trails, SOLD)
1977 Transporter
Life is short. Can I have some of yours? |
Posted: Tue Apr 18, 2017 3:10 pm Post subject: Re: Restoring Camper Top FAQ |
Dandelion here, again...
Can anyone recommend a VW/Body/Paint shop who can do this for me? I have lung disease which prevents me from being around chemicals.
No cracks or damage, just worn and dingy.
1989 Westfalia
1988 Vanagon
1994 Jetta
1981 Jetta
1973 Bug |
mr matt Samba Member
Joined: May 26, 2005 Posts: 814 Location: southeast Pa
Posted: Wed Sep 18, 2019 4:29 pm Post subject: Re: Restoring Camper Top FAQ |
Hi,
I was wondering if someone can give me some input here.
Replacing the top, which seems to be straightforward, but are noticing this chipping going on.
Mostly easily seen in the last pic. the previous pics are for perspective.
I thought at first this chip that comes off this area is dried paint, but actually I am not sure if it is some plastic or resin fiberglass.
If it is not paint, what is the best way to fix it.
Notice the lack of seam from the top to the wood... which makes me think it is plastic (?)
Thanks
_________________ 1955 3-fold semaphore Oval beetle
1971 Convertible beetle
1977 Westfalia, FI, Berlin interior |
Our79Westy Samba Member
Joined: August 08, 2012 Posts: 97 Location: Bronson, FL
Posted: Sun Sep 29, 2019 12:04 pm Post subject: Re: Restoring Camper Top FAQ |
OK, thanks,
I ended up bondo - ing over it, another type of plastic I guess, then painted it.
Matt _________________ 1955 3-fold semaphore Oval beetle
Posted: Mon Oct 07, 2019 5:04 pm Post subject: Re: Restoring Camper Top FAQ |
I am working on mounting the tent to the bus now.
but to back up some.....
I took the top off the bus
This is one area that is not discussed... how much fabric gets stapled to the wooden frame?
With the top upside down, you are looking at the bottom of the wooden frame, which I will now refer it as the top of the frame base on point of view.
When I put the tent to the top, I stapled the cloth about a half inch down from the top of the wood all along the perimeter. This is the exactly how the one I removed was. So there is some play as to how much fabric to staple to the wood before putting on the thick plastic piece. I noticed BD plastic is wider than the original. This fabric play is maybe an inch?
Soooo, with the play of how much fabric to staple to the side of the wooden frame, that will give you possibly too much or too little fabric when you mount it to the bus.
Which is what I am doing now.
With the top on, and opened all the way, enough fabric falls to the front center for me to put the metal hold down bar with screws. The fabric is quite snug tho. This worries me in that I may have too much fabric (?) This is just the front by hand.. Things seem to tighten up a bit when I try to hold down the corners.. I really dont know how it will turn out until done tho. The sides seem very tight if I hold the ridge of the fabric to the body.
I am half expecting to have to redo it all ...
Any comments?
Thanks! _________________ 1955 3-fold semaphore Oval beetle
tjrm63 Samba Member
Joined: November 15, 2007 Posts: 112 Location: Jersey Shore
Posted: Mon Oct 07, 2019 5:57 pm Post subject: Re: Restoring Camper Top FAQ |
As long as you stapled the new fabric to where the old fabric was on the pop top
you should have enough for the metal strip that holds the fabric to the roof. I put a closed 6' ladder standing up next to the middle brace so I could lower the lift bar mechanism and let the pop top rest on the ladder which will give you an easier time installing the fabric under the metal brackets. The plastic ridge on the bottom of the fabric should just be past the metal bracket. Start in the front middle and work your way out to the corners pulling it tight to the corners and work your way to the back the same way pulling it tight towards the back. After the fabric is installed all the way around push the lifting bar slowly till it locks. The fabric will be very tight but it will lock and stretch. Good luck you'll be fine.
I cut my roof out and added a late westy pop top to my 71 transporter, I had nothing to go by but I grafted and welded the top on and figured out the placement for the hinges and metal fabric brackets that hold down the cloth and it came out perfect
_________________ I don’t care how much it’s worth now.
I care how much this bus makes me happy |
Posted: Tue Oct 08, 2019 2:18 pm Post subject: Re: Restoring Camper Top FAQ |
OK, thanks,
My concern is possibly to have too much fabric; hopefully when all is done, it will be very tight.
Thanks!
& that bus looks great! _________________ 1955 3-fold semaphore Oval beetle
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4893 Location: Southern AB
Posted: Fri Mar 22, 2024 8:02 am Post subject: Re: Restoring Camper Top FAQ |
I need to replace the rear rib that had this cobbled wood brace on it from the PO.
But I need to know where the brace should go though so the new tent fits properly.
Does anyone have the dimensions or a measurement for the correct placement on a 71 westy pop top?
_________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
