Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Mon Feb 27, 2017 9:56 am Post subject: Re: Vintage speed type 3 exhaust |
Thanks for the update, Josh...good to know it's still going to happen. _________________ 71 Elm Green FI A/T Squareback |
VWDog Samba Member
Joined: June 24, 2005 Posts: 617 Location: Ladysmith, BC
Posted: Fri Jun 30, 2017 8:49 am Post subject: Re: Vintage speed type 3 exhaust |
I am keen to replace the header/quiet pack but am a bit confused by the timeline in this thread. Just to clarify....Is the VS muffler to heater box conundrum now solved with these?:
http://shop.vintagespeed.com.tw/s.nl/it.A/id.582/.f
Thanks!
Don _________________
1970 Lotus White Single Cab 2015- , 1979 Sage Green 2014-2015, 1978 Dakota Beige Westy 2012-2015, 1978 Neptune Blue Riviera 2012-2017 , 1970 Neptune Blue Bus 2010-2012, 1970 Deluxe Savannah Beige 2010-2012, 1985 Iltis 2010- , 1962 Single Cab 2010-2013, 1975 Brasilia? Bay/Split Kombi from Brazil 2008-2011, 1985 DoKa 1999-2009, 1971 Bus 1999-2000, 1968 Double Cab 1991-1998, 1965 Ghia 1987-1991, 1970 Westfalia-bought by Mum and Dad in 1970, sold by me in 1993 why-oh-why :_(
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Fri Jun 30, 2017 9:11 am Post subject: Re: Vintage speed type 3 exhaust |
VWDog wrote: |
Thanks!
Don |
You can currently use the lower heat exchangers with the VS exhaust that's been on the market for a few years now.
The discussion I've been involved in revolves around the smaller 'upper' heat exchangers (aka: preheat box) - which are not yet available from Vintage Speed. This means that you will have to run flexible tubing from the fan shroud to the lower heat exchangers.
The proposed Vintage Speed manufactured upper heat exchangers would fit at #2 and #4 as the stock upper heat exchangers do with a stock exhaust and eliminate the need for flexible hose between the fan shroud and the lower heat exchangers.
Clear as mud, right? |
VWDog Samba Member
Posted: Fri Jun 30, 2017 10:05 am Post subject: Re: Vintage speed type 3 exhaust |
ataraxia wrote: |
Yeah... as soon as I figure out the difference between the upper and lower heat exchangers
I am new to Type 3 ownership. All I have ever owned is Type 2s _________________
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Jun 30, 2017 12:18 pm Post subject: Re: Vintage speed type 3 exhaust |
Take $500 & this picture of the Vintage Speed exhaust to your local Muffler Shop. They'd have it fabricated & installed in a couple days. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
VWDog Samba Member
Posted: Sat Jul 01, 2017 9:49 pm Post subject: Re: Vintage speed type 3 exhaust |
ataraxia wrote: |
VWDog wrote: |
I finally had a look at what is on my Squareback and have read this and other threads more closely. It is much clearer now. The upper heat exchangers are long gone, so until I found some pics I was a bit mystified as to why there would be any. They basically act like the kidneys in the stock mufflers in Type 1s and 2s, correct? I can see why the upper heat exchangers are desirable, as it is probably akin to why my stock muffler set up works better at giving me heat in my 70 SC than the crappy quiet packs I have had to deal with in the past.
Mike Fisher wrote: |
Take $500 & this picture of the Vintage Speed exhaust to your local Muffler Shop. They'd have it fabricated & installed in a couple days. |
You'd have to see where I live to know this is not an option(i.e. I live in a backwater ). _________________
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Sun Jul 02, 2017 9:32 am Post subject: Re: Vintage speed type 3 exhaust |
[quote="VWDog"]
ataraxia wrote: |
VWDog wrote: |
I finally had a look at what is on my Squareback and have read this and other threads more closely. It is much clearer now. The upper heat exchangers are long gone, so until I found some pics I was a bit mystified as to why there would be any. They basically act like the kidneys in the stock mufflers in Type 1s and 2s, correct? I can see why the upper heat exchangers are desirable, as it is probably akin to why my stock muffler set up works better at giving me heat in my 70 SC than the crappy quiet packs I have had to deal with in the past. |
Yes, but it's more complex than that, as the t-3 "pre-heaters" have aluminum heat sink material around the upper pipes (hence the term "pre-heaters"). They actually pre-heat the air before it goes into the main heat exchangers, adding more heat to the cabin. This is 1 reason why you don't want anything rubber or plastic sitting near the outlets in the rear kick panels. Tennis shoes have been known to melt there. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
matara Samba Member
Posted: Sun Feb 11, 2018 2:11 pm Post subject: Re: Vintage speed type 3 exhaust |
I'd be up for one of the stock replacement versions that would allow the upper heat exchangers to be retained.
Thanks
Steve _________________ ~-~-~-~-~-~-~-~
Sydney, Australia
Click to view image |
Posted: Sat Apr 21, 2018 10:42 am Post subject: Re: Vintage speed type 3 exhaust |
Update: I don't believe the upper rear heat exchangers are going to happen.
The information I got was: "They're too expensive to make"
No additional information was provided. |
Posted: Sat Apr 21, 2018 12:04 pm Post subject: Re: Vintage speed type 3 exhaust |
ataraxia wrote: |
Well, that sucks. I'm not surprised they say that though.
They make a good product, but fall short on the details to make a great product. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
VWDog Samba Member
Posted: Sat Apr 21, 2018 6:56 pm Post subject: Re: Vintage speed type 3 exhaust |
Bobnotch wrote: |
ataraxia wrote: |
They make a good product, but fall short on the details to make a great product. |
Well put. I guess they don't understand driving in cold weather? _________________
Posted: Sat Apr 21, 2018 7:44 pm Post subject: Re: Vintage speed type 3 exhaust |
Bobnotch wrote: |
ataraxia wrote: |
I asked what the definition of 'expensive' was but got no reply. Seems their focus is more on T1/T2 and Porsche parts. |
Posted: Mon Apr 23, 2018 9:11 am Post subject: Re: Vintage speed type 3 exhaust |
ataraxia wrote: |
Bobnotch wrote: |
ataraxia wrote: |
That sounds about right...go where the money is. The only reason they made 1 for the type 3 was because they could basically use most of the existing parts/tooling and sell another product. That just like all the other headers and mufflers on the market. Add some tubing and bends, and you have a type 3 header that uses an off the shelf quiet pack muffler. Add a little less tubing, and you have a type 3 dual muffler set up for more money because it fits a type 3.
I guess you're just going to have to figure out how to add the pre-heaters to the upper pipes on your own if you want them. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Apr 23, 2018 9:14 am Post subject: Re: Vintage speed type 3 exhaust |
Bobnotch wrote: |
I guess you're just going to have to figure out how to add the pre-heaters to the upper pipes on your own if you want them. |
It's not really possible due to the location of the connections. |
Posted: Mon Apr 23, 2018 9:29 am Post subject: Re: Vintage speed type 3 exhaust |
ataraxia wrote: |
Bobnotch wrote: |
Oh come on, you're a resourceful kind of guy. I'm sure you could make it work. Although you'll have to alter/change the tin for it. Just think outside the box a little. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Apr 23, 2018 9:30 am Post subject: Re: Vintage speed type 3 exhaust |
Bobnotch wrote: |
ataraxia wrote: |
Bobnotch wrote: |
Oh come on, you're a resourceful kind of guy. I'm sure you could make it work. Although you'll have to alter/change the tin for it. Just think outside the box a little. |
I no longer want it that bad...I'm already having to alter the VS exhaust so that it'll stop blackening my bumper guard. |
VWTECHEDITOR Samba Member
Joined: March 02, 2004 Posts: 99 Location: Southern Maryland, USA
Posted: Tue May 29, 2018 6:23 am Post subject: Re: Vintage speed type 3 exhaust |
Good Morning, Folks,
I've been following this thread for a while now and have been impressed with the thought you all have given to this problem. I have a few questions to add to the discussion:
- What does the VS unit look like inside as far as damping and pipe length? Is there a cutaway picture?
- Has there (ever) been a side-by-side comparison done between all of the readily available T3 systems? I've read here that the sound is good on the VS systems; how to they compare to others as far as power?
At some point not too far down the road, my '69 SB will need a replacement, so the time to start looking is now. Thanks.
Art LeBrun
vwtecheditor (semi-retired) |
Posted: Thu Aug 02, 2018 2:39 pm Post subject: Re: Vintage speed type 3 exhaust |
Just as an FYI: Beyond this post I won't have any more updates about the progress (or lack thereof) regarding the creation of a VS exhaust that'll work with the upper rear heat exchangers. It's highly unlikely that it'll happen at this point. If it does, it'll have to happen with someone else's help as I've sold all of my Vintage Speed exhausts and parts. |
Jason37 Samba Member
Posted: Fri Aug 18, 2023 2:55 pm Post subject: Re: Vintage speed type 3 exhaust |
Anyone running this tune with a wideband? Curious which side you mounted the O2 sensor on. |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
Posted: Sat Aug 19, 2023 10:14 pm Post subject: Re: Vintage speed type 3 exhaust |
Jason37 wrote: |
No but I will be tackling the upper HE problem when I put this "Abarth Repop" on my car. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
