nize Samba Member
Joined: June 21, 2004 Posts: 537 Location: Sweden - Cheesy town
Posted: Thu Jan 09, 2014 12:26 am Post subject: Master brake cylinder and CSP disc brakes? |
I have a problem with what master brake cylinder I should use for my barndoor. I will run beetle spindles up front with a CSP brake disc kit at the front. In the rear I will run Porsche 356A drum brakes.
I started looking at this one but it is 55 and up and 22,2 mm.
http://www.csp-shop.com/cgi-bin/cshop2/front/shop_...0&all=
What about the Porsche 356 dual circut one, 19mm?
What are you guys running in similar setups? _________________ ----------(VW)----------
1954 Kombi
1957 lowlight ghia coupe
bubblehead Samba Member
Posted: Fri Jan 10, 2014 9:08 am Post subject: |
I'm running 72-79 bus master (and spacer) w/ CSP disc front & 1 ton drums in the rear. I don't think the 19mm 356 bore will work well with discs. The 22.2 kit you linked should fit and work fine. _________________
| Lind wrote: |
| I think that buses attract weirdos that do weird things in weird places. |
Trevor P Samba Member
Joined: January 21, 2004 Posts: 899 Location: Saskatoon, SK, Canada
Posted: Fri Jan 10, 2014 11:27 am Post subject: |
The 19mm will be fine. I'm using a type 1 '67 and later dual circuit on mine with CB discs and Type 3 rear drums, works great. _________________ 53 SG Barndoor SC
53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy |
nize Samba Member
Posted: Mon Jan 13, 2014 7:04 am Post subject: |
Thanks for the feedback! I think I will buy the kit for the 22,2 version for 55-> bus. _________________ ----------(VW)----------
1954 Kombi
