Karzapart55 Samba Member
Joined: May 26, 2004 Posts: 640 Location: Old Bridge NJ
Posted: Fri Jan 10, 2014 2:50 pm Post subject: Timing or carb |
I bought a 76 bus with a 2.0 that was missing the F.I. And Dist. I have it on the bench. I installed a 009 and dual Webbers. I set the D pointing to #1 with the #1 approx. TDC. Started it on bench, fired right up. My Q. Should I set the timing 1st, or set the carbs? It idles rough. Can I set the timing with the rough idle? Thanks |
SGKent Samba Member
Posted: Fri Jan 10, 2014 3:12 pm Post subject: |
first set the timing at 3500 +/- RPM 28 - 29 degrees BTDC |
Peabody Samba Member
Posted: Fri Jan 10, 2014 7:19 pm Post subject: |
+1 on timing first. Must be in time or tuning the carbs is all for nothing. _________________ '71 Transporter "June" (traded a nissan hardbody + some $) (daily)
'76 Westy "Sandy" (traded an ak-47) (on hold)
'77 Westy (parts)
'74 Westy (parts) |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51120 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jan 10, 2014 7:57 pm Post subject: |
On the bench a sustained 3500+ RPM may be really exciting, set the timing by moving the distributor until it sounds pretty good and check with a light if you wish (~7.5 BTDC with the hoses off) then set up the carbs, then go back and do the timing at speed and the final carb tweak after it's installed.
What 3500 on a bench may resemble:
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Fri Jan 10, 2014 8:06 pm Post subject: |
I didn't know EMPI made washing machines. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
obx71super Samba Member
Joined: December 16, 2012 Posts: 340 Location: Outer Banks NC
Posted: Fri Jan 10, 2014 8:47 pm Post subject: |
Haha that was hilarious!!! _________________ 71 super auto stick basically original minus a couple resprays
73 Westy automatic with a 2 liter gex, soon to be a 1.8 liter Headflow masters
Newest Addition!! Solid straight 74 thing totally disassembled!! YEEEWWWW |
Desertbusman Samba Member
Posted: Fri Jan 10, 2014 9:38 pm Post subject: |
With an 009 the advance will be full in before it gets to 3,000 RPM. So 29* BTDC when it reaches full advance. Like BD says go ahead and tweek the timing or the carbs so you can get it up to that full advance RPM. Your question about setting the timing with a rough idle is of no concern since you won't be setting it at idle.
Do the valve adjustment first. Cold engine if it has solid lifters. Then get it up to speed to do the timing. Finally, set the carbs. If they havn't been running on that engine previously then you are going to have quite a time getting them dialed in proper. And you will need a sync tool.
For the initial settings bouncing back and forth between ignition and carbs is no problem and may be necessary. Just so the order of final tune is valves, timing and carbs.
3500 on a bench might be a bit traumatic. But only 3000 is not as bad. Mine was sitting on the ground when I ran it in for the initial 20 minutes at 2000 RPM. Now that was immediatly at 2K after first firing and before any timing light or carb tuning. _________________ 71 Superbug
71 Westy |
erikgundy98 Samba Member
Joined: September 06, 2009 Posts: 297 Location: Vancouver WA
Posted: Fri Jan 10, 2014 11:06 pm Post subject: |
asiab3 wrote: |
I didn't know EMPI made washing machines. |
I laughed out loud and agreed!! _________________ '90 Multivan Westfalia |
Posted: Sat Jan 11, 2014 6:56 am Post subject: |
busdaddy wrote: |
The neighborhood hoodlums take old machines up into the woods and blow them up, but it is so dangerous that even they can't watch what they are doing as they set the charge off. The act just leaves pieces of metal spewed everywhere. This would be a lot more fun as it takes a while and can be viewed the whole time. |
