RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Sat Apr 19, 2014 5:19 pm Post subject: |
obus Samba Member
Joined: March 08, 2001 Posts: 11070 Location: just off Garden State Parkway Exit 81
jjjjack Samba Member
Joined: August 08, 2005 Posts: 1013 Location: Gainesville, FL
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1106 Location: Burlington, WA
Posted: Sun Apr 20, 2014 10:13 am Post subject: |
Good stuff man! _________________ -Adam
'59 Mango Bus
'11 Golf TDI 6-speed
'69 Bug |
type47fan1 Samba Member
Joined: December 03, 2011 Posts: 828 Location: McDonough GA
Posted: Thu Apr 24, 2014 5:02 pm Post subject: |
Thank you everyone. Was pretty cool getting it back on the road on it's own. Of course there are plenty of items that need attention but it is operable and can be driven around to the back yard. I have driven it now using all gears and the tranny seems really smooth. First is a pain to find at stop some times but it does not grind or kick out of any gears. It stops really good and has not strange noises.
I still have a few rust areas that need attention so I tackled the drivers rear inner fender. It needed the front and rear as well as the tray in the corner. Was not really that hard to layout and weld up but just took time.
Tough to get good pictures but I think you get the idea.
The before picture is nearly impossible to even view so you have to trust me that it needed to be replaced.This is not finished pic but during. It really sucks grinding in these fender wells.
And used an autocraft tray. It dropped right in.
Now I can start the body work. The passenger side needs some of the same work but I do not plan on painting that corner so I will start the body work and work the passenger side corner during down time. _________________ JLD
My 60 Mango Build
http://www.thesamba.com/vw/forum/viewtopic.php?t=581699
My 66 Westy Build
http://www.thesamba.com/vw/forum/viewtopic.php?p=5825134#5825134 |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Sat Apr 26, 2014 4:50 am Post subject: |
as always - outstanding job Phillip _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Sun Apr 27, 2014 8:11 am Post subject: |
As usual thanks Paul.
Put the bus down by the basement Friday at 5 and started the body work. Spent Friday afternoon and Saturday priming, filling and blocking. Since the long panel had dents and waves above where I joined the two panels I got it straight enough without using much filler. The nose only needed a very small amount to fill in grind marks from finishing the welds, same with the rear corner so body work went quick.
Primer in place
I have a few more of blocked primer but no one wants to see those I am sure so here are the finished shots.
The paint is a little too bright. I am going to try and knock it down and bring some shine to the old paint but overall I think I can live with it. Much better than what is was when I drug it home. I have decided after this that I will not be blending any more sections so the sides will be as is.
A little before after action
Felt pretty good getting it painted by today but I guess I was expecting a dead on match which did not happen. The paint samples looked pretty close on the spray card after mixed but it did shoot a little bright. _________________ JLD
My 60 Mango Build
My 66 Westy Build
obus Samba Member
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Mon Apr 28, 2014 6:43 am Post subject: |
I've always been a sucker for a happy ending!!
Very nice save on this one!!
type47fan1 wrote: |
So here you go moving under it's own power again for the first time in over 30 yrs.
_________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
TRG Samba Member
Posted: Mon Apr 28, 2014 6:01 pm Post subject: |
that's awesome! did you ever get a driver seat sorted? if not, i stated in your seat thread that i could take detailed photos and measurements for you if you plan to fab one. |
6sixTinBox Samba Member
Joined: September 30, 2007 Posts: 539 Location: Confinement
Posted: Wed Apr 30, 2014 11:16 am Post subject: |
Absolutelt enjoy seeing this refurb. Awesome and many kudos to you! It gets me amped up for the 66 13 window deluxe I'm buying tomorrow. _________________ 1966 13 Window Deluxe
It is what it is |
Posted: Thu May 01, 2014 7:29 am Post subject: |
Thank you and good luck on the 13.
So the Paint this time is nearly spot on. In the first pictures the paint looks to be a good match but it was too green. I could not get it to photograph well and even in the shade it was not that apparent, once the sun hit it though it was very apparent. I took the sprayed section of the old long panel and my paint guy was able to get it this time and I asked him to add a flattening agent. When he hit it with the sun gun he said I can get this much closer.
Still not easy to see but this picture is of the old paint. The very lower part of the nose tells the bright color best.
And now with the new shade.The gloss tells on the new paint but the shade is good so I am pretty happy now.
Nose close up. Will put a little more white on the lower v and wipe it off to match the fade.
Long panel close up.
More new pics.
My 60 Mango Build
My 66 Westy Build
Cuņado Wear Samba Member
Joined: December 10, 2006 Posts: 1145 Location: The "O"
Posted: Thu May 01, 2014 11:30 am Post subject: |
type47fan1 wrote: |
More new pics.
Phillip, If I haven't said it before I'll say it now. YOUR THE MAN!! _________________
Bulli Klinik wrote: |
I may be a little late to the party, but what the hell is Cunado Wear? |
Looking for front kick panels for late 63' Deluxe Basalt Gray
60' Double Cab
63' 15 Window Deluxe |
Posted: Fri May 02, 2014 1:23 pm Post subject: |
Got one of the doors today. It is pretty solid, my original door is basically an outer shell. The original does not have any dents but also probably will not hold up to too many rides. I will try and massage this one a little straighter. The Drivers door is what I am most excited to get.
Arrival.
Little rubbing.
And mounted up.
After a rubber hammer and dolly.
Going to fix my wing windows and get all the rubber installed in the frames for the front doors this weekend. _________________ JLD
My 60 Mango Build
My 66 Westy Build
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Fri May 02, 2014 6:51 pm Post subject: |
That door looks just like it wore on that bus all these years. Perfect! |
Attorney Isaiah Loophole Samba Member
Joined: December 02, 2005 Posts: 602 Location: Zebulon, GA
Posted: Fri May 02, 2014 6:58 pm Post subject: |
Dude the bus is looking good! Nice work! The paint looks really close now. Keep it up Phil! _________________ Bryce
Georgia Dubs
61 Beetle "Old Blue"
62 Beetle
64 Beetle "Pat" |
Posted: Fri May 02, 2014 6:59 pm Post subject: |
Vehicle parked on the grass! What will the HoA say?? |
