Air to air intercooler in D pillar ideas please!
lloydy
lloydy is offline
PostPosted: Sun Mar 09, 2014 1:28 pm    Post subject: Reply with quote
i did see that thread, some good stuff on there..
here's a shot of roughly how it will be mounted
16" multivan pop top AFN TDI
“Give a man a fire and he's warm for a day, but set fire to him and he's warm for the rest of his life.”
POS
POS is offline
PostPosted: Sat Mar 08, 2014 3:26 pm    Post subject: intercooler Reply with quote
"All my life's a circle"
Might take gander at this...
http://www.thesamba.com/vw/forum/viewtopic.php?t=394631&postdays=0&postorder=asc&start=0
kombisutra wrote:
"This thead is about badgers, not hyenas.... get back on track ok?"
82pdtdi
82pdtdi is offline
PostPosted: Sat Mar 08, 2014 2:59 pm    Post subject: Reply with quote
this is where i am putting my inter cooler still have to duct it in. i plan on adding a 911 turbo type scoop also.
[/url]
Waldi
Waldi is offline
PostPosted: Sat Mar 08, 2014 12:14 pm    Post subject: Re: my aircooler solution Reply with quote
rmcd wrote:
Waldi wrote:
Hi,
here u can see my solution in a 16 Syncro with AAZ and watercooled turbo.
https://fotos.web.de/ui/external/sI_-gRgXSgiY-kjJIa0RnQ96203
Feel free to insert the pics into ur awnser.
Thanks for the photos Waldy. Very helpful. Your implementation seems to encapsulate the best practices discussed so far.
What function does the piece of bent diamond plate provide? Does this create a low pressure area near the rear inside the fender?
Lloydy. Your craftsmanship makes me tear up. Those bent piece are beautiful. Thanks for posting.
No, its just for dirt protecting. And maybe less overpressure.
lloydy
lloydy is offline
PostPosted: Sat Mar 08, 2014 11:20 am    Post subject: Reply with quote
Now, while i would love to claim this work as my own...... it's not Laughing
All being carried out by the guy doing the bodywork on my van. I'll post pictures for sure as and when work is done, i'm really looking forward to seeing it fitted myself!
dkoesyncro
dkoesyncro is offline
PostPosted: Sat Mar 08, 2014 11:03 am    Post subject: Reply with quote
beautiful job! Please keep us posted. I want to see where this is going to be mounted. Applause
rmcd
rmcd is offline
PostPosted: Sat Mar 08, 2014 10:56 am    Post subject: Re: my aircooler solution Reply with quote
Waldi wrote:
Hi,
Syncro panel van camper build
http://www.thesamba.com/vw/forum/viewtopic.php?t=575458&highlight=
Gizmoman
Gizmoman is offline
PostPosted: Sat Mar 08, 2014 8:12 am    Post subject: Reply with quote
Very nice craftsmanship.
Post your results when you get a chance.
I have a WAIC unit (Frozen Boost)I am just now hooking up. My fan is about the same size as yours but it's cooling water.
82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize Spare rack - stock location https://www.thesamba.com/vw/classifieds/detail.php?id=2169071
lloydy
lloydy is offline
PostPosted: Sat Mar 08, 2014 2:28 am    Post subject: Reply with quote
i thought i would post up a few pics of how my intercooler is shaping up
internal division to balance cores equally
better idea here
mock up
position of fan sensor
kit form Laughing
fast fwd
used the cad cutter to make the inlet flange mount as its 10mm conical,this is important as a flat plate with a stub would render it likely to flex in and out and over time possibly cause fatigue cracking
here the fan mount is welded to the end tanks and the 90' fold is sufficient to prevent movement that could be an issue, also the fan is now securely fixed via SS rivnuts/capheads and is i think a decent way to do this.
and so we have this Very Happy
so now i will place it and make a simple effective mounting for it
costal_cat
costal_cat is offline
PostPosted: Sun Mar 02, 2014 4:59 pm    Post subject: Reply with quote
[/quote]
To defeat the pre-heating of the intake air, you could install a water methanol injection system above the charge cooler in the pillar. It would cool the charge cooler, the intake air and keep your EGT down too. Just saying... Smile
Jeff[/quote]
So I was looking at this for my TDI.
http://www.snowperformance.net/mpg-max-vw-tdi.html
Is this what you are thinking?
87 Syncro Westy
TDI Overland Parts engine conversion
Jeff's Old Volks Home
Jeff's Old Volks Home is offline
PostPosted: Sat Mar 01, 2014 2:54 pm    Post subject: Reply with quote
furrylittleotter wrote:
goffoz wrote:
perpetual motion?
Not exactly, but I like where your mind's at. Wink
Here is a flowchart/diagram:
The beauty is the higher the rpms, the more flow and the more "precharge" cooling.
Neil2
Jeff
www.jeffsoldvolkshome.com
2004 Jetta TDi Wagon
2002 Smyth Ute TDi
1990 Vanagon weekender Syncro AAZ
1987 Syncro Doka AAZ...soon to be TDI Smile
2014 DL650ABS Xpedition
1986 Weekender Syncro (Under construction)
1987 Westfalia (Under construction)
1987 Syncro Single cab
rmcd
rmcd is offline
PostPosted: Sat Mar 01, 2014 2:14 pm    Post subject: Reply with quote
Does anybody have pictures of the body modification s necessary to vent to the rear or underneath (is this a low pressure area)?
Would the fan sit on top of the Saab intercooler and pull air into itself and through the intercooler or would it be better to put it under the intercooler? Maybe doesn't matter?
Howesight
Howesight is offline
PostPosted: Fri Feb 28, 2014 12:54 pm    Post subject: Reply with quote
The Mack Maxidyne diesels (1960's and 1970's) used compressed bleed air from the turbo to drive a small air-powered turbine that drove the integral fan in the intercooler air-box. Nice design in that higher boost drove the cooling fan faster and vice versa. No pesky electric fan for the Mack, nosiree . . .
'86 Syncro Westy SVX
costal_cat
PostPosted: Fri Feb 28, 2014 6:50 am    Post subject: Reply with quote
Hello all.. Just reading along and I have something a little different in my TDI set up that seems to be working well. I have my air intake on one pillar, in this case the right rear where the original intake was. Then i bring it across the back of the engine compartment to an air to air intercooler on the left rear pillar. I have an digital temp gun and I seem to be getting good temps. Air comes in hotter than it goes out the other side which is what I think I want. Now I know I cant pull that temp gun out while driving at 60mph and check but I have checked immediately after stopping and it still holds the variance. I had a variety of performance issues but it is running really solid now. I have added fuel coolers, oil and gear oil coolers in various places that have also helped. The shop just completed a new pipe from intercooler that has better bends in it but I seem to roll fine even during a summer day at 75 with the AC on. Not sure if this helps but it is my experience. If any one thinks this is flat out a bad idea and I can get better performance otherwise I would love to hear about it. I have the van off in at the shop for storage over the winter but i could have some pics sent ...
87 Syncro Westy
furrylittleotter
furrylittleotter is offline
PostPosted: Fri Feb 28, 2014 6:17 am    Post subject: Reply with quote
OddN wrote:
I dont get it... You are making the intake air hotter by letting it cool the chargecooler. Wouldnt that equate to no additional cooling effect in total?
I was thinking the cool air introduced would offset the heating of the air going through the cooler. In other words, yes it would heat it, bit would also cool it, hopefully cooling more than heating it.
Maybe it would, maybe it wouldn't.
Wouldn't take much to find out if someone wants to try. I don't have a turbo so I can't or I would, but all my other ideas have worked out.
Neil2
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Fri Feb 28, 2014 5:57 am    Post subject: Reply with quote
That's a classic hot air intake system...kinda self defeating. You want to draw your intake air ahead of the IC, or from the other pillar
Casey--
'89 Westfalia Bluestar mTDI (ALH)
'01 Westfalia Weekender VR6 (AXK)
Volkswagens powered by Volkswagen
OddN
OddN is offline
PostPosted: Fri Feb 28, 2014 5:49 am    Post subject: Reply with quote
goffoz wrote:
perpetual motion?
Neil2
1991 VW Multivan syncro 1,9 TD
furrylittleotter
PostPosted: Fri Feb 28, 2014 4:58 am    Post subject: Reply with quote
goffoz wrote:
perpetual motion?
Neil2
Waldi
Waldi is offline
PostPosted: Fri Feb 28, 2014 2:22 am    Post subject: my aircooler solution Reply with quote
Hi,
goffoz
goffoz is offline
PostPosted: Thu Feb 27, 2014 11:46 pm    Post subject: Reply with quote
I have a very simple solution to increase airflow through a pillar mounted intercooler; simply mount the intercooler, seal around it, mount a tapered shroud over it and connect your fresh air intake tube to it, that will draw fresh air through the intercooler, cooling it. Simple. Very Happy
Neil2
nice Very Happy perpetual motion?
Anyhow
..Fresh air intake is in the drivers side pillar, snorkeled.
... IC is on the passenger side, scooped.
....obstruction is the fuel filler(syncro)..it'll be nice to smooth the turbulence with some ABS or Al. ducting.
We'll see Confused
Page 4 of 6
