J-Gaz. Samba Member
Joined: November 19, 2007 Posts: 613 Location: 253 Then, Now 206.
Posted: Wed Jan 15, 2014 4:41 pm Post subject: 1970 seasonal use maintenance issues |
Hello all!
I have built a 1600 single port for my 1970 Beetle. I rarely drive it because my work requires me to leave the state for 6 months at a time.
My question is.
How likely is the Main seal to tear after 6 months of sitting.
Here is the Story:
Not but 3 months ago I drove my Beetle from a suburb of Seattle to Bend Oregon. I averaged 70 MPH and it drove fantastic.
However, when returning from Oregon, Just out side of Olympia my oil light came on while i was also experiencing loss of power climbing s slight incline. I immediately pulled over.
at that time i could see no issue. no oil leaks. no oil on the engine. plenty of oil on the dip stick.
Drove the car to a near by rest stop. parked for some time. looked under the engine. GIANT PUDDLE Of OIL Near where the Translate connects to the Engine.
My best guess is the Main Seal Blew.
How likely is it that my issue was caused by letting the car sit and the seal going dry causing a tear. Also, why would it wait to tear until I was on my way home, and not immediately upon start up?
thank you in advance for all your help and incite.
Justin _________________ 1970 Beetle | Basically Stock 1600 SP |
Bob Loblaw Samba Member
Joined: August 17, 2008 Posts: 865 Location: Vancouver Island, Canada
Posted: Wed Jan 15, 2014 4:48 pm Post subject: |
I can't imagine a seal tearing while just siting parked. Is it engine oil or gear oil in your puddle? _________________ sent from a phone using poor grammar and spelling |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
J-Gaz. Samba Member
Posted: Wed Jan 15, 2014 7:17 pm Post subject: |
Bob Loblaw wrote: |
I can't imagine a seal tearing while just siting parked. Is it engine oil or gear oil in your puddle? |
Bob, It was definitely Engine oil. _________________ 1970 Beetle | Basically Stock 1600 SP |
75smith Samba Member
Posted: Wed Jan 15, 2014 7:23 pm Post subject: |
hopefully it wasn't something bigger, loss of power tells me something might have gone bang, and it cracked the case....sorry to put that image in your head, but it's just a heads up that the rear seal may not be the culprit _________________ My 1975 Beetle Build Updated 8-21-12
My engine build |
Posted: Wed Jan 15, 2014 7:31 pm Post subject: |
Or just oil cooler, either way pressure was reduced, so there would be some engine wear involved _________________ My 1975 Beetle Build Updated 8-21-12
My engine build |
J-Gaz. Samba Member
Posted: Wed Jan 15, 2014 7:54 pm Post subject: |
75Smith-
my last major issue was an ill fitting oil cooler, which was successfully repaired 2 summers ago
When it had been an issue, the oil from the cooler seals leaked from the flange toward the front pulley's and down between the barrels- all that is clean with no signs of oil leaks now.
I think what I'll have to do is Cautiously run the motor and watch for leaks and listen for other internal issues.
as for a cracked case...
I had wiped up all the residual oil and have not seen a drop since. I'll have to crawl under and take another/ closer look. but upon my initial inspection everything appeared to be in excellent shape and condition _________________ 1970 Beetle | Basically Stock 1600 SP |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Thu Jan 16, 2014 12:17 am Post subject: |
I'd suspect the flywheel seal again. Does the leak occur in the center, where the engine and transmission meet? More noticeable after parking?
I installed one improperly, and I had to do it over again, using a flywheel-seal installer.
Make sure you just put in 2.6 quarts when filling the oil at oil-change time. Too much oil and it wants to find a way out ....
Tim |
J-Gaz. Samba Member
Posted: Tue Jan 28, 2014 7:25 pm Post subject: |
Tim,
Yeah-
the leak seems to be centered in the car. i was thinking bad drain plug washer...? but that seems unlikely. especially since no issue occurred for the first 500 miles (or at least that I noticed). unless it takes that kind of heat for the oil to sneak through...
i have driven the car 15 miles in my neighborhood recently to try to repeat the issue, but no such luck.
I cleaned the engine up with a rag prior to driving hoping to see the trace elements of oil beginning to spew from some seal.
spots contending for the leak include:
1. the push-rod tube closest to the driver (very little wetness from oil- cant tell where it is from suspect the seal)
2. The oil drain plug and other cap nuts (little drops of oil on all of them)
3. Case seam (there gets a little oil on the rear of the case (toward transaxel- but I think its from the oil plug blowing around... OR
4. Main Seal.
Does anyone know a solid way to "prime" the oil with the engine in the car? (with out burning up the starter).
I think I want to try to get it up to oil pressure, get the pump pumping, with the motor in the car, but not while running. that way i can watch for leaks at high RPM with the engine tin off ( most of it off).
thanks _________________ 1970 Beetle | Basically Stock 1600 SP |
J-Gaz. Samba Member
Posted: Thu Feb 06, 2014 12:24 pm Post subject: UPDATE |
Ok,
Had to run it with the tin off to watch for leaks.
definetly from between the head and barrels was a leak, a bad valve cover/ valve cover gasket and the Main seal.
Pulled the motor out replaced valve cover and gasket, Re-torqued the heads. and replaced the main seal.
after 2 days the main seal is leaking again...
the previous seal looked perfect.
I just dont know what to do. I am beyond frustrated with it, and it is my only car... _________________ 1970 Beetle | Basically Stock 1600 SP |
mukluk Samba Member
Posted: Thu Feb 06, 2014 1:17 pm Post subject: |
Time to figure out why the seal keeps leaking:
- Defective or cheap quality seal
- Improper installation damaging the seal
- Burr or similar defect on the flywheel damaging the seal
- Groove worn into the flywheel providing a poor sealing surface
- Sealant between case and main seal is deficient
Make sure you're lubing the main seal lip sufficiently when installing the flywheel as well, otherwise the new seal will get damaged. _________________ 1960 Ragtop w/Semaphores "Inga" |
72Pstroke Samba Member
Joined: April 04, 2011 Posts: 182 Location: North Idaho
Posted: Thu Feb 06, 2014 1:47 pm Post subject: |
Make sure your oil galley plugs aren't leaking. That could be mistaken for a rear main seal leak.
Tim |
Posted: Thu Feb 06, 2014 4:28 pm Post subject: |
Mukluk has good advice.
Get an Erling brand seal.
Get a seal installer that costs about $29.00. It has a threaded portion that you tighten where the gland nut goes. You tighten this tool until it stops--about 1/8 or so past flush. $29.00 is a bitch--but so is doing this job over and over again ....
Grease up the outer part of the Erling seal before install. White grease.
Oil the inner part of the seal where it contacts the rim of the flywheel (the snout, so to speak). Oil the back of the flywheel where it contacts the flywheel seal.
Replace the big "O" ring thats in the back and inside of the flywheel (inside the snout). You didn't mention doing this before. Oil the "O" ring well.
This should do it.
You are checking to see if you have noticeable play in the crank, before you do all this, right? And you're checking before installing the seal?
And use the lightest weight oil you can use for the ambient air temps in your area.
Good luck.
Tim |
J-Gaz. Samba Member
Posted: Thu Feb 06, 2014 8:18 pm Post subject: |
thanks everyone.
I will check the fly wheel for burrs.
I lubed up the ID of the seal really well with white lithium grease as to not have it tear.
In my "how to rebuild your ACVW" book, it says to use Permetex H3 sealant on the OD of the Main seal gasket, are you all finding that its not necessary? and I should use a little oil to help the seal glide into position?
I did also replace the inner O-ring on the flywheel along with the paper gasket that goes between it and the crank shaft. interestingly enough, the gasket that was between the crank and fly wheel was metal. I must have put that in thinking it was better than paper as they both had come with the gasket kit.
nonetheless. I have to drive it, but am watching the oil level intensely. So far no noticeable drop in oil level- just a pesky drip down the back of the motor... I am completely anti oil leaks! I cant stand it. I get so frustrated when everyone- mechanics included, tell me that its an old VW, that's what they do- especially because my motor in 99% brand new.
I'll tear into _________________ 1970 Beetle | Basically Stock 1600 SP |
J-Gaz. Samba Member
Posted: Tue Apr 23, 2019 7:07 am Post subject: How'd I miss this before... |
J-Gaz. wrote: |
I did also replace the inner O-ring on the flywheel along with the paper gasket that goes between it and the crankshaft. interestingly enough, the gasket that was between the crank and flywheel was metal. I must have put that in thinking it was better than paper as they both had come with the gasket kit... |
No one noticed before?
That I installed BOTH the O-Ring and the Paper gasket...?
Isn't that a big "no-no"...?
Just need to O-Ring (Or so I've read recently...)
It's been parked over 5 years now.
Ran Occasionally just to cycle the oil... & Listen to the Exhaust...
I never figured this out.
I Just Parked her...
Now Back at it & Read about using only the O-ring for O-ring models & Not both the paper gasket too-
Wouldn't that be funny if that was the issue...
I'll get to it in a few weeks or so & Update this thread! ha! _________________ 1970 Beetle | Basically Stock 1600 SP |
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Tue Apr 23, 2019 10:33 am Post subject: Re: 1970 seasonal use maintenance issues |
We're going to be laughing for another 5 yrs. _________________
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
Tom K. Samba Member
Joined: March 10, 2005 Posts: 1605 Location: Central Pennsylvania
J-Gaz. Samba Member
Posted: Tue Apr 23, 2019 6:44 pm Post subject: Re: 1970 seasonal use maintenance issues |
Tom K. wrote: |
Sorry I wasn't hanging out on the forum back in 2014, but I would have caught that had I read it. What a bummer that it sat for 5 years for such a silly reason. |
So frustrating, right? Ha!
Still need to confirm.
I don't have a shop, so I've got to get my uncle to agree to let me use his! (I live about an hour and a half from him too, which complicates things a little...) _________________ 1970 Beetle | Basically Stock 1600 SP |
Tom K. Samba Member
J-Gaz. Samba Member
Posted: Tue Apr 23, 2019 10:57 pm Post subject: Re: 1970 seasonal use maintenance issues |
Tom K. wrote: |
Yes. To confirm, only early 40HP engines required either the metal gasket or paper gasket. Later dual port 1600 engines (assuming that is what you have) have neither gasket and instead have the o-ring. |
Thanks for this Tom.
My engine is not original - but build as close to the original stock 1600 single port engine that was in it.
So I've got a 1600 Single port with a flywheel that takes an O-Ring.
I can't remember if the original flywheel had a groove for the O-Ring.
For some reason, I decided I needed a new flywheel back in 07
So this is the Flywheel I've got now:
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-311-105-271
When I built the motor it was 100% new parts.
Unfortunately, the old case was too warn to warrant Boring. _________________ 1970 Beetle | Basically Stock 1600 SP |
