GTV Samba Member
Posted: Fri Jan 17, 2014 1:35 pm Post subject: Making Jail bars |
I'm in need of jail bars for my 13 window. I have plenty of the end caps, but no bars (or braces, yet). What is the length of the rear seat piece? Is the rear seat piece a different diameter than the window bars? Going to search for some 10mm(?) round stock and polish it up... _________________ EMPI Power Rules! |
squareweave Samba Member
Joined: November 15, 2004 Posts: 448 Location: British Columbia
Posted: Fri Jan 17, 2014 2:01 pm Post subject: |
pm sent |
NVNATIVE Samba Member
Joined: August 15, 2012 Posts: 135 Location: Henderson, NV.
Posted: Fri Jan 17, 2014 3:09 pm Post subject: |
From my shabby memory the bar above the rear seat is a different diameter than around the windows. Could measure later when I get home if you need it. _________________ 64' Notch (Notcho)
67' 13 Window Deluxe (Maxwell) |
EverettB Administrator
Joined: April 11, 2000 Posts: 69821 Location: Phoenix Metro
Posted: Fri Jan 17, 2014 3:17 pm Post subject: |
When you say rear seat piece, do you mean the rear window?
Then yes, it's the same diameter bar as the side windows.
If the mean the luggage bar on the back of the rear seat back, then no, that is larger.
Unfortunately I don't have a 13/21-Window Bus or piece here to measure the length of the rear window bar but you could estimate fairly easily by measuring between the mounting holes for the ends. Or screw the end caps in and measure the distance? _________________ How to Post Photos
GTV Samba Member
Posted: Fri Jan 17, 2014 4:03 pm Post subject: |
Yes, I meant the luggage bar. Thanks Everett. _________________ EMPI Power Rules! |
GTV Samba Member
Posted: Fri Jan 17, 2014 4:28 pm Post subject: |
You rock! _________________ EMPI Power Rules! |
