dkoesyncro Samba Member
Posted: Fri Jun 07, 2019 8:42 am Post subject: Re: Oregon Trail Syncro build |
vwhammer wrote: |
I must have missed it somewhere but what intake is this? |
Android keeps auto correcting...it's an ADP/bleep the ADP was installed on a crossflow 1.6 for the A4/B5 chassis in the European market the bleep replaced it going to the 2.0 |
Posted: Fri Jun 07, 2019 8:43 am Post subject: Re: Oregon Trail Syncro build |
dkoesyncro wrote: |
vwhammer wrote: |
Bleep is Aye Zee Em, see if this works? |
vwhammer Samba Member
Joined: May 20, 2006 Posts: 998 Location: Boulder CO.
Posted: Fri Jun 07, 2019 9:04 am Post subject: Re: Oregon Trail Syncro build |
Hmm ok.
Any info on how well this intake flows compared to the original ABA or later AEG intake.
I don't think I have enough time left until my build deadline to try to track down a Euro only intake and any other associated parts but I will definitely keep it in mind.
I have the MK4 intake on my ABA and am lowering the engine to clear the deck lid but it would be super awesome if I did not have to.
I do however like the better flow rate of the MK4 intake.
I suppose with a turbo that does not matter as much with your build |
Posted: Fri Jun 07, 2019 11:06 am Post subject: Re: Oregon Trail Syncro build |
vwhammer wrote: |
Hmm ok.
If you look back through the thread you'll see my commitment to (what I thought) simplicity and efficiency. Some things I hung on to and a lot has changed. Maintaining ground clearance and deck hieght have been the driver, but what I've learned is less one off stuff or custom pieces. I started to lean towards factory/oem parts.
The manifold is almost all runners very little plenum, the plenum volume is enough to supply the 2.0 but the runners are the magic! The ABA had a large plenum and long runners but nothing quite like the AEG or this manifold, I'd bet this might provide more torque on the low end compared to the AEG only because the runners are gradual swept with out the hard bend of the 2 piece units of the other ones. This manifold was on the economy engine larger framed cars over there. eBay.de was a good source maybe $100 US for manifold and fuel rail... |
Posted: Fri Jun 07, 2019 11:40 am Post subject: Re: Oregon Trail Syncro build |
Does it accept the US throttle body and did you try to see if any of the US fuel rails and/or injectors will work with the euro manifold?
I did find a couple of the manifolds for about $120 US shipped but no fuel rails.
It's pretty tempting but I did change my rear suspension a bit to change the travel range to accommodate the the engine and trans drop so maybe I should just stick to the original game plan.
Ok sorry that's the last question. Not trying to derail your thread any.
We can carry on with private messages if you would like. |
Posted: Sun Jun 16, 2019 5:14 pm Post subject: Re: Oregon Trail Syncro build |
Well with the front diff out now, getting some attention. It will receive new R&P, solid shaft and a locker. I am focusing on the van-again. We got some stainless coolant lines in, swapped out the leaking steering rack for a reconditioned manual rack. I am also turning my attention to the epas system and Audi cluster!
Posted: Sat Jul 20, 2019 9:55 pm Post subject: Re: Oregon Trail Syncro build |
I'm going stir crazy...I need my drivetrain....
I finished the epas, I used 2004 Ford Explorer slip shaft with double u joints for my linkage bits coupled with some VW u joints welded to the business ends.
The Audi cluster is wired, retrofitted some MK2 stalks with Cruise and MFA. The cruise ecm is installed, I'll chip away at that later. I'm even adding a mk2 dash bezel to accept a double din...that's my plan anyways!
Posted: Fri Oct 18, 2019 10:52 pm Post subject: Re: Oregon Trail Syncro build |
So...a lot has happened and still a ways to go! I got my drivetrain back from "Syncro Shop". We discussed our options and went with the 6.17 R/P set, GT gears and mainshaft, GT main bearing housing, oiling/cooling mods, front locker and Toms' solid shaft. I'm very excited about this build, it's allowed me to get to know Tom (Hell of a good guy) and a further understanding of these gearboxes.
The dash has gotten a bit more shape, I'll be covering it soon.
Here's some pics. I'll report on Sunday!
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Sat Oct 19, 2019 8:48 am Post subject: Re: Oregon Trail Syncro build |
I see some wicked sh*t right there !
(all camouflaged)
This HAS to increase the power-handing capacity of the transmission.
If we only knew "how much".
But then someone would just hang a V6 on there and put it back to 'zero net'.
(with big smiles though ) _________________
....KTMs, GasGas, SPOT mtb |
4Gears4Tires Samba Member
Posted: Sun Oct 20, 2019 5:41 am Post subject: Re: Oregon Trail Syncro build |
What do those pipes do? Attachments for oil cooling? _________________ '87 Syncro
Posted: Sun Oct 20, 2019 8:13 am Post subject: Re: Oregon Trail Syncro build |
Pressurized oiling of critical areas. |
Sodo Samba Member
Posted: Sun Oct 20, 2019 10:57 am Post subject: Re: Oregon Trail Syncro build |
dkoesyncro wrote: |
That 6.17 is quite the worm!!
Lots of sliding in that R&P.
It is Sodo’s (current) opinion/belief that the 6.17 R&P will generate lots more heat from oil shear, and this trans can benefit from cooling as well. And with a pump, filtering is a given. What a great trans you have built dkoe! Be sure to add theft protection, that van has a pot of gold underneath. _________________
Posted: Sun Oct 20, 2019 10:16 pm Post subject: Re: Oregon Trail Syncro build |
Thank you Sodo! As much as I love R&D, I think I'll just hang my 2.0 gasser on it. I was thinking about something like Mad Max, a series of switches that if not done correctly ignites a pack of C4. I know I'll be down a van but it would send a message to the vanagon thieves here in the PNW.
I know I promised an update but work kept me busy all day yesterday and half the day today! I have the green goblins installed and just routing wiring, breathers and odds and ends! I really hoped for more but.... work emergencies.
I spoke with Tom of Syncro Shop, we're going to show what a build like this is and what goes into it! Stay tuned for that. I know you will enjoy it. |
Sodo Samba Member
Posted: Mon Oct 21, 2019 11:30 am Post subject: Re: Oregon Trail Syncro build |
A hypoid gear does NOT have rolling contact.
It has sliding contact, thus wastes energy, and requires different lubricants.
Modern cars avoid hypoids, because they are in an 'efficiency' game, eliminating the wasteful friction of sliding gears (worms).
Which is why Redline has recused their own MT-90 from use in transaxles that contain Hypoids. A front wheel drive car, transverse engine would NOT have a hypoid for example because it doesn't need to turn the torque 90°.
There's lots of sliding in that 6.17 R&P, LOTS more than a 4.86.
I think it's about double the sliding of a 4.86 hypoid, so there's gonna be lots more heat.
And only 6 teeth on the pinion head.
I'd ask Swepco directly what oil they recommend for that R&P.
It might be useful to know (before talking to Swepco) what the hypoid offset distnce is, and the tooth counts, in case they are willing to process that info in their recommendation. _________________
Posted: Sun Nov 03, 2019 10:35 pm Post subject: Re: Oregon Trail Syncro build |
The drive train is hung and for the most part everything is bolted on!
Ive temporarily switched focus on the engine carrier, it's loosely a Porsche design. The family of Pioneer Wagenwerkes use a similar design on their Pump Duse conversions. I fell in love with it's form and function. I had to replicate something for the early block at 15°.
I have a bit more Fab to do but it's close.
Posted: Tue Nov 05, 2019 10:46 pm Post subject: Re: Oregon Trail Syncro build |
Im pleased to say/see this is now hanging without the support of straps, chains or come-a-longs. Hopefully this coming weekend will bring some completion in another loose end.
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Tue Nov 05, 2019 11:03 pm Post subject: Re: Oregon Trail Syncro build |
Nice progress!
Just noticed the BFI valve cover - haven't seen that one before. The USRT exhaust manifold is cool too. Such a unique build! |
Escorial Syncro Samba Member
Joined: May 02, 2004 Posts: 437 Location: Manitou Springs, CO
Posted: Wed Nov 06, 2019 7:08 am Post subject: Re: Oregon Trail Syncro build |
Nice work on the motor mount system. That arm on the engine side looks super beefy and well built. I like how you positioned the motor mount brackets in the corners of engine bay. I'm very taken with that Pioneer design as well for my 50 degree TDI build. Seems like a cleaner way to go, easier fab. Which motor mounts did you go with? Thanks, Joel _________________ Joel Lane
1985 Vanagon converted to syncro, ALH TDI, Reimo Primus top with Westy interior
2002 Toyota Tundra 4x4
1974 Honda CL360 Scrambler (for sale!) |
Posted: Wed Nov 06, 2019 8:34 am Post subject: Re: Oregon Trail Syncro build |
Escorial Syncro wrote: |
Nice work on the motor mount system. That arm on the engine side looks super beefy and well built. I like how you positioned the motor mount brackets in the corners of engine bay. I'm very taken with that Pioneer design as well for my 50 degree TDI build. Seems like a cleaner way to go, easier fab. Which motor mounts did you go with? Thanks, Joel |
A local distributor had a surplus of motor mounts for nearly 75% off MSRP. They are the hydraulic Gel mounts for the Audi S4/Passat B5 V6. Actual German made TuV approved, quite surprised at the quality for the price I got them! |
Zeitgeist 13 Samba Member
Posted: Wed Nov 06, 2019 8:48 am Post subject: Re: Oregon Trail Syncro build |
I'm really intrigued with that mount design. I think I'll try to recreate something like it for my next version.
Where did you source all that heat shielding? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
