panel Samba Member
Joined: December 02, 2001 Posts: 1090 Location: Victoria B.C. Canada
Posted: Wed Nov 06, 2019 12:23 pm Post subject: Re: Oregon Trail Syncro build |
Zeitgeist 13 wrote: |
Where did you source all that heat shielding? |
Yeah , that looks really nice. _________________ My '65-Subaru EJ20 Turbo conversion |
dkoesyncro Samba Member
Posted: Wed Nov 06, 2019 12:47 pm Post subject: Re: Oregon Trail Syncro build |
The heat shield is thermo-cool insulation behind some tin that came from the exhaust tunel from a Passat found in a wrecking yard. |
Posted: Sun Nov 24, 2019 9:50 pm Post subject: Re: Oregon Trail Syncro build |
Some progress, more has been done than pictured! I forget about how consuming the little things are. I'm getting near completion but not before a handful or two of little things to do first!
Posted: Mon Dec 30, 2019 11:08 pm Post subject: Re: Oregon Trail Syncro build |
A month later and a bit more progress, Maybe I'll be able to start it next weekend??
4Gears4Tires Samba Member
Posted: Tue Dec 31, 2019 8:59 am Post subject: Re: Oregon Trail Syncro build |
Man, that looks fantastic. _________________ '87 Syncro
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Tue Dec 31, 2019 9:07 am Post subject: Re: Oregon Trail Syncro build |
Wow! Incredible! _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Posted: Tue Dec 31, 2019 6:48 pm Post subject: Re: Oregon Trail Syncro build |
4gears and Joe,
Thanks guys I am feeling very good about this iteration, It's been fun! |
Posted: Tue Feb 04, 2020 11:33 pm Post subject: Re: Oregon Trail Syncro build |
Things are getting near, I know I often am optimistic about this but I'm so close!
Here I've fabbed up what I believe will help cool the turbo, the D pillar intercooler exhausts itself into the singular lower plenum where the air will pass into/under the heat shield of the exhaust manifold.
The other pillar will house the trans cooler and the goofy bracket will hold the Volvo oil cooler
Launch control, just kidding! Seriously,this is for boost control!
I had to make new coolant pipes to work with this set up
Earlier I mentioned about lightning the load on the starter mostly for ease of working on this. I've opted for this lug/gang
Lastly, taillights! These are from "Super Bright LEDs"
Here's the air box, the Dodge/Chrysler V6. I have to figure out the rest of the intake plumbing. Possibly 2.5" rigid shop vac hose or similar??
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10371 Location: Sunshine Coast B.C.
Posted: Wed Feb 05, 2020 12:45 pm Post subject: Re: Oregon Trail Syncro build |
Interesting; this box I can't flip the lid. It has over/under or interlocked hinge on one side and the other has spring steel tabs to close it up. It was from a 3.3 litre.
Thanks Neil- |
Posted: Wed Feb 05, 2020 3:39 pm Post subject: Re: Oregon Trail Syncro build |
dkoesyncro wrote: |
Vanagon Nut wrote: |
re: Dodge air box. I've used that box before. The reversible lid is nice
Neil. |
Thanks Neil- |
You're welcome.
Well, it was some years ago so I could be misremembering. Or you're using a different box than I did. But regardless, ironically, as per your comment, it seems the smaller box was used on the slightly larger 3.3 dodge engine. Some of the diesel swap people used 3.0 box which IIRC is a little bigger. _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Posted: Fri May 15, 2020 11:06 pm Post subject: Re: Oregon Trail Syncro build |
A bit more progress and soon I'll be back in the seat.
The trans cooling/filtration has come together; thanks to the PNW guys Tom L, Tom M, Dale, David and the Garner Family of PioneerWagenWorks for helping me see this through!
From trans into Magnom filter
Magnom to Turbowerx pump (Weddle) and into the Canton "spin on" filter
In to the upper heat xchanger coupled with a thermostatic fan switch (swapping soon with a dial-adjust)
Makes its way now filtered cooled to the trans via the cross to the critical areas that the Toms and Paul Gaurd have taken the time to solve or extend the life of our gear boxes.
and two more, notice the black AN fittings
Posted: Sun May 17, 2020 7:31 pm Post subject: Re: Oregon Trail Syncro build |
A bit more progress "the function element"
Wired up the puller fan on the modified TDI A/A intercooler that's the top blue switch. Next in the stack was the fan override for the trans cooler along with the Lil fella at the bottom to control the pump! This is all wired to the xline via the added fuse panel behind the glove box and relays next to the accessories behind the tail light.
The taillights are nice, they remind me of the Mk1 golf/rabbit although super bright! The gauge pod will be housing a trans temp gauge from intellitronicks and the dualing banjo intake temp from glowshift.
Posted: Mon May 18, 2020 7:41 pm Post subject: Re: Oregon Trail Syncro build |
Today was the day of "judgment", I filled the gear box via the pump was that a slick "no mess fuss" what a joy. Hooked up the epas system and whoa, effortless you can practically steer it with mind control. After a shakedown and out of the garage it came, that 6:17 and these 27" tires what a goat! By brail ass 1st gear feels just an oomph higher than the 4:86 in gelande gear. I never got above 2nd gear in my neighborhood and an alignment is needed after doing the whole steering mod. Once again thank you to the folks of the PNW, that's Idaho, Washington and Oregon. I'm am so pleased and hope to move onto new things in this ever evolving syncro. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9605 Location: Western WA
Posted: Mon May 18, 2020 10:58 pm Post subject: Re: Oregon Trail Syncro build |
Congrats !! _________________
....KTMs, GasGas, SPOT mtb |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Mon May 18, 2020 11:34 pm Post subject: Re: Oregon Trail Syncro build |
Nice!
So much ingenuity in this build. Amazing work, dude!! |
FrankenSubySyncro Samba Member
Joined: May 03, 2007 Posts: 638 Location: Vancouver, WA.
Posted: Mon May 18, 2020 11:58 pm Post subject: Re: Oregon Trail Syncro build |
When can I come over and check it out in person? I will wear a mask with gloves and practice social distancing! _________________ Syncronize it!
1987 Franken Syncro (converted 2WD auto)
2004 2.5 SOHC Subaru
F & R lockers, decoupler, SS, 6.17 R&P
Trans Cooler
EMPI race prepped 930 CVs and axles
Bilstein coilover front, rear ProComp MX-6066R shocks, 14" hypercoil springs
30x9.5 15" BFG Muds
Custom skid plates
Nose job (custom front bumper) http://www.flickr.com/photos/subyvanagon/sets/72157624970330925/ |
Posted: Tue May 19, 2020 6:43 am Post subject: Re: Oregon Trail Syncro build |
Thank you all- it's been fun, challenging and rewarding. The alignment is scheduled for 4:00 today and until then I have luminated pressure switches to troubleshoot (reverse light/locker indicators)
Dave, I'll text you-
Eric, really liking your photography, you have got an eye!
Tom, thanks again for the arm chair theories and conclusive conversation, you've been great. |
Posted: Sun Apr 25, 2021 2:08 pm Post subject: Re: Oregon Trail Syncro build |
Reviving this thread as I'm about to embark into another phase of this machine. Although it works, but not without some issues I'm going to swap out my management for Microsquirt, the modified 1.8t harness just has some issues.... nothing consistent...often chasing gut intuition... without results or eureka!
While I'm swapping out the wiring I've thought about relocating the battery. Factory location is fine, I've just felt like these places might better serve camping and daily life. I've considered going to diesel layout but changed my mind and will stay at 15° and my engine bay is sorted out well enough. This leaves me thinking about under the back seat, any thoughts or opinions on location? (Just finished up reading a fair amount, I think I'll leave the battery alone and use the opposite for the house battery, aka westy style)
While addressing wiring, I will add a house battery and some convenience plugs,lights, USB's etc.
Cheers |
erste Samba Member
Posted: Mon Apr 26, 2021 11:00 pm Post subject: Re: Oregon Trail Syncro build |
Looking forward to the updates! |
