Karzapart55 Samba Member
Joined: May 26, 2004 Posts: 640 Location: Old Bridge NJ
Posted: Tue Jan 21, 2014 3:51 am Post subject: Did i kill my altenator? |
I test ran my 2.0 on the bench for 15 min. I did not have the alt. attached to the batt, nor did I have the reg. plugged in. When I installed in the Bus, the ge. light stays on. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Jan 21, 2014 4:55 am Post subject: |
Did u check voltage coming out of the Alt. with a Voltmeter?
What u did should not of hurt it _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3551 Location: San Diego (Encinitas)
Posted: Tue Jan 21, 2014 12:31 pm Post subject: |
No. Without the regulator being attached, the alternator is nothing more than a idler pulley for the belt. Alternators don't self-excite. If it is damaged, it wasn't the test run that did it. Use the Bentley diagnostic methods to troubleshoot the problem. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Tue Jan 21, 2014 12:44 pm Post subject: |
Thanks! |
