Is it possible to go Type 4 and still have a heater
mikeyboy_85
mikeyboy_85 is offline
PostPosted: Tue Jan 21, 2014 7:34 am    Post subject: Is it possible to go Type 4 and still have a heater Reply with quote
Hey guys, i was thinking putting a 2 litre type 4 into my bug and using an upright kit, but i won't wanna do this if its not possible to keep my heater.
any pics would be great, just to see how it all fits in if anyone has got this set up please send pics
Cheers Michael
oasis
oasis is offline
PostPosted: Tue Jan 21, 2014 10:22 am    Post subject: Reply with quote
One place to check would be LA Performance in the UK. I'm not sure what shipping would be like to Australia. Joel will chime in with some good ideas, I'm sure. If not, you might PM him. If still stuck, go to GermanLook.net. There are some very knowledgeable Aussies (and other folks Wink ) there who can help.
I'm five years removed from my Super and I don't have pics of mine specifically. The good news answer is: YES, it can be done.
Now: 2003 New Beetle Turbo S / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI
royraison
royraison is offline
PostPosted: Tue Jan 21, 2014 3:40 pm    Post subject: Reply with quote
I don't know how many type 2s in Austraila got type 4 engines, many countries got type 1s,,, from 1972 on the ones in North America came with type 4 engines.
Heater boxes from 72-74 are the most favored for conversions with heat
but 75-78 boxes could be used.
If your engine is one of the newer 79 and later square exaust port engines
then the 79 and later boxes can be used.
Good luck,
Derek Cobb
Annoying
Derek Cobb is offline
PostPosted: Tue Jan 21, 2014 4:01 pm    Post subject: Reply with quote
I thought the 411/412 heater boxes were a good choice for an upright conversion, but it's been years since I did any research on it.
Multi69s
Multi69s is offline
PostPosted: Tue Jan 21, 2014 7:42 pm    Post subject: Reply with quote
It can be done, but you will need the heater boxes as well as the control units / flaps. They tend to be separate pieces. You will probably have to shorten the intake hoses since the heater boxes are larger, but you will get a ton of heat.
69 road Bug 2110
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
73 Squareback - 2L, T4, Automatic W/ AC
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback
Joel
Joel is offline
PostPosted: Tue Jan 21, 2014 11:57 pm    Post subject: Reply with quote
I started building up a type 4 to put in my bug back in 2000 and it was my aim to have working heaters.
The stock bus heaters can be cut down to fit, its just rigging up the flap system in a bug that clears the axles is a pain in the arse.
A mate had V-force in Sydney build him a muffler and heater setup for his type 4 powered 72 Super, turned out sweet.
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
