36 hp H beam rods are done
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Tue Jan 21, 2014 12:08 pm    Post subject: 36 hp H beam rods are done Reply with quote
All right all you 36hp power guys, I just got word that the 36 hp H Beam rods are done and are now being checked out in quality control. These will be available in either 20mm or 22mm wrist pins. I should have a set of each here in a week or two to check out and test
"no more hacking my sig line"
Mr. Motorhead
Mad Scientist
Mr. Motorhead is offline
PostPosted: Tue Jan 21, 2014 12:53 pm    Post subject: Reply with quote
Are those the ones AA performance were working on or are they raw rods that are finished elsewhere?
30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy
splitpile
PostPosted: Tue Jan 21, 2014 2:43 pm    Post subject: Reply with quote
Yes they are being made by AA
pig-pen
pig-pen is offline
PostPosted: Tue Jan 21, 2014 3:30 pm    Post subject: Reply with quote
I want, must have. Happy to test for ya Very Happy
vw7266
vw7266 is offline
PostPosted: Tue Jan 21, 2014 3:31 pm    Post subject: Reply with quote
so when will they be able to be purchased?
splitpile
PostPosted: Fri Jan 31, 2014 12:10 pm    Post subject: Reply with quote
They're here
Mr. Motorhead
Mad Scientist
PostPosted: Fri Jan 31, 2014 12:52 pm    Post subject: Reply with quote
splitpile wrote:
They're here
I have not gotten mine yet, should be a couple days. I ordered up a set for the 20mm pin. I have a build in the works right now using a WW grind cam and ceramic coated dome tops. Not having the rods as yet, I was told they weigh a bit more than a stock rod. Do you have a weight in grams?
Some Chinese guy
splitpile
PostPosted: Fri Jan 31, 2014 1:35 pm    Post subject: Reply with quote
splitpile wrote:
They're here
495 with out bolts 545 with ARP bolts
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Fri Jan 31, 2014 2:01 pm    Post subject: Reply with quote
Can you comment what you do to QA these rods?
While they look much stronger than stock, I've always been wary of products make in China.
Cheers,
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
splitpile
PostPosted: Fri Jan 31, 2014 2:40 pm    Post subject: Reply with quote
Cheers,
Paul
Almost every rod you buy tday is made in china, scat, cb, bugpack etc besides the high dollar ones which are still made in the us, but a lot of the high dollar blanks are made in china then machined here. These rods have been checked on a rod machine for bore and a rod checker for length and twist
Mr. Motorhead
Mad Scientist
PostPosted: Fri Jan 31, 2014 3:49 pm    Post subject: Reply with quote
So about 100 grams more depending on the stock rod measured. This rod all in itself is such over kill, let alone adding ARP bolts too.
Cheers,
Paul
These would be a finished piece ready to install. I've used many other AA rods with no issues, I would expect these to be the same quality. I was surprised AA made a short run, most companies don't. It's been a very long time since any after market rods have been available for a 36hp.
Some Chinese guy
slalombuggy
slalombuggy is offline
PostPosted: Fri Jan 31, 2014 4:25 pm    Post subject: Reply with quote
We hung "H" beams in Todd's big 36er 2 years ago. 'bout time you guys caught up Twisted Evil Wink
brad
splitpile
PostPosted: Fri Jan 31, 2014 5:26 pm    Post subject: Reply with quote
stock 36 hp rod 427 grams hp 36
My first bonneville WW Okrassa has stock 36 hp rods, shot peened with ARP bolts, made 67 hp
AA H beam 36hp rod 545 grams with bolts (going in a turbo engine) shooting for 150hp
Porsche rods (as in my IDA 36hp) 499 grams 124 hp
H beam chevy rods (as in my supercharged 36 hp) 586 grams hoping for 100+hp if I can get the boost
I just don't want to break a rod, better safe then sorry, even though I sacrafice hp for strength and cranks I use aren't cheap
I don't think Tom Bruch has ever broken a stock rod, I'll have to ask him or matbe he'll pipe in here.
Mr. Motorhead
Mad Scientist
PostPosted: Sat Feb 01, 2014 12:04 pm    Post subject: Reply with quote
Never had a broken one, but they do bend. This rod came out of a 25hp to boot. I think the engine was a 46' or 47'. This rod BTW weighs in at 391 grams. I'm not saying a heavier rod is a bad thing, just that it's a lot more beef than a stock rod. Kind of like putting an Olympic weight lifter in a ballet because you're afraid the regular guy might drop the ballerina. The H beam rod will eliminate some minor problems with piston choice. You could use a 36hp journal stock/stroker crank and choose the pin size (20mm or 22mm) on the rod depending on the piston set used. The more off the shelf type of parts there are will make it easier to build a larger than stock 36hp that will run reliably.
Some Chinese guy
my59vw
my59vw is offline
PostPosted: Sun Feb 02, 2014 9:54 am    Post subject: Reply with quote
What is going to be the price on these? I am interested in getting a set.
Brian Murphy
57 Beetle
59 Euro Rag Beetle
mark tucker
mark tucker is offline
PostPosted: Tue Feb 04, 2014 9:33 am    Post subject: Reply with quote
you would be surprized how easy how eazy it is to bend/twist a rod. our sunnen rod recon station has a bar(for bending twisting)jigs for checking & aliging them on both plains (twist&bend or tilt,no you dont fix a dead rod with a kink in it,but oh so many rods have a twist to them or off angle/bend/tilt) the first one I did was for a 340/360 mopar and it twisted back oh so easy I thought something was rong(no press just by hand) I then got an old dead junk rod and gave it a try. same thing, these things twist easely.and straighten back easy but need to be done the right way so both twist&tilt is accounted for so the piston dosent cock or go wonkey throught its travel in the stroke as the rod angle changes.
on some rods there is a big bevel where the cap meets the rod,some race engine builders will weld(tig) this up&rework the rods( in the days befor the cheep rods cameabout,I dont know if it's still done much, the big block chevy dimple rod with the 7/16"rod bolt had the bigest bevell some almost .100" wide. china rods are so cheep it isant worth reworking oe rods these days.....except for engines that dont have the china stuff out....yet
Mr. Motorhead
Mad Scientist
PostPosted: Tue Feb 04, 2014 11:18 am    Post subject: Reply with quote
AA currently has them listed on their site for $299 with the 200k bolts with the ARP 2000 bolts costing another $36.
http://aapistons.com/shop/connecting-rods/4340-5-1-chromoly-h-beam-rods-vw-type-36-hp.html
I did the setup on the rods yesterday for the engine I'm building and everything went together very nice. All the rods were dead on weight wise and the pins slipped in for a very nice fit.
I was just going to use fresh stock rods for this build as it is more to see how well ceramic coating works/doesn't work on the piston tops and chambers, but the H beams came available just as I was getting ready for the bottom end assembly. Here's a comparison between stock and the H beams:
I hope to be running it by the months end in my Bonneville car.
Some Chinese guy
splitpile
PostPosted: Tue Feb 04, 2014 11:47 am    Post subject: Reply with quote
toiga
toiga is offline
PostPosted: Tue Feb 04, 2014 11:50 am    Post subject: Reply with quote
Hi, can these be adapted to a 40hp motor?
Mr. Motorhead
Mad Scientist
PostPosted: Tue Feb 04, 2014 12:24 pm    Post subject: Reply with quote
I'm sure you could if you cut your rod journals down to the size of a 36hp.......that would be kind of a step backwards going smaller from the 40hp rod journal though.
Some Chinese guy
