Subaru ej25 2.5 wiring harness question, need advice
whynotvw
whynotvw is offline
PostPosted: Wed Jan 22, 2014 5:39 am    Post subject: Subaru ej25 2.5 wiring harness question, need advice Reply with quote
I'm getting a real good deal on a 2000 ej25 complete engine with about 80K miles. But it doesn't come with wiring harness but it does come with ECU. How difficult is it to get a wiring harness ? Or should I keep looking for a complete engine that comes with wiring harness.
by the way the engine is coming from 2000 impreza 2.5 rs 5 sp
thanks for the advice in advance.
Syncro Jael
Syncro Jael is offline
PostPosted: Wed Jan 22, 2014 7:42 am    Post subject: Reply with quote
There are a few places you can purchase a finished harness.
This is just one of them...
http://subaruvanagon.com/conversion_services_01.htm
My EJ22 has been in for 10 years 104K miles. No issues, always starts, always purrs like a new kitten. When it decides to sleep, I will install another one just like it. Laughing
1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat)
DAV!D
DAV!D is offline
PostPosted: Wed Jan 22, 2014 7:48 am    Post subject: Reply with quote
Go to car-parts.com and search that car model in your area and see what comes up. Go to ebay and do the same.
You are best off to try and find a u pull it type junk yard that you can pull the harness yourself.
86 Syncro Build - Ecotec Motor Swap - Pop Top Conversion - Camper Build & Syncro Conversion
ftp2leta
ftp2leta is offline
PostPosted: Wed Jan 22, 2014 7:49 am    Post subject: Re: Subaru ej25 2.5 wiring harness question, need advice Reply with quote
Yes, or, find any harness and plenum between 99-2005
Ben
Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta
insyncro
Banned
insyncro is offline
PostPosted: Wed Jan 22, 2014 2:36 pm    Post subject: Reply with quote
I prefer to use all matched parts coming from running donors Wink
Makes life much easier.
whynotvw
whynotvw is offline
PostPosted: Wed Jan 22, 2014 10:51 pm    Post subject: Reply with quote
Thanks everyone for your input. The seller decided to sell his wiring harness and ecu after all.
The engine has 80k miles should I change the head gaskets and do the timing kit while the motor is out?
Jake de Villiers
Jake de Villiers is offline
PostPosted: Wed Jan 22, 2014 11:00 pm    Post subject: Reply with quote
My engine had ~60,000 miles and I did the timing belt, water pump, etc. Might as well while its in your hands! Wink
I didn't replace the head gaskets.
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
whynotvw
whynotvw is offline
PostPosted: Wed Jan 22, 2014 11:09 pm    Post subject: Reply with quote
How many miles do you have now total.
ftp2leta
ftp2leta is offline
PostPosted: Thu Jan 23, 2014 5:52 am    Post subject: Reply with quote
You should not even ask that question. DO IT.
rubbachicken
rubbachicken is offline
PostPosted: Thu Jan 23, 2014 7:28 am    Post subject: Reply with quote
change them while the engine is out, it'll save you taking the motor out to do the job later.
lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182
Syncro Jael
PostPosted: Thu Jan 23, 2014 7:45 am    Post subject: Reply with quote
X2 On the timing belt, water pump, tensioner, pulleys, etc.
Here is a video on the process. Yours will be a snap with the engine out! Cool
I did mine with the engine in. Removing the exhaust and tin was easier than pulling the engine. Gotta love Suby's. Laughing
ftp2leta
ftp2leta is offline
PostPosted: Thu Jan 23, 2014 10:03 am    Post subject: Reply with quote
Head torque sequence
Note - oil head bolt threads and washer
1) Tighten all bolts to 29 N-m (3.0 kgf-m, 22 ft-lbs) in alphabetical sequence.
2) Then tighten all bolts to 69 N.m (7.0 kgf-m, 51 ft-lbs) in alphabetical sequence.
3) Back off all bolts by 180" first; back them off by 180" again.
4) Tighten the bolts (a) and (b) to 34 N-m (3.5kgf-m, 25 ft-lb).
5) Tighten the bolts (c), (d), (e) and (f) to 15 N.m (1.5 kgf-m, 11 ft-lb).
6) Tighten all bolts by 80 to 90" in alphabetical sequence.
CAUTION: Do not tighten the bolts more than 90".
7) Further tighten all bolts by 80 to 90" in alphabetical sequence.
CAUTION: Ensure the total "re-tightening angle" [in the former two steps], do not exceed 180".
Jake de Villiers
PostPosted: Thu Jan 23, 2014 11:05 am    Post subject: Reply with quote
I've put a little over 40,000 miles on the van since the transplant. Its my daily driver.
www.thebassspa.com
furrylittleotter
furrylittleotter is offline
PostPosted: Thu Jan 23, 2014 11:13 am    Post subject: Reply with quote
They had sorted out the head gasket issues by 2000 so I would not change the gaskets. it is due for a timing belt though if it is still the original.
Have fun with the conversion and welcome to the wonderful world of Subaru power. It is a glorious thing! Frees up so much space under the rear seat because you do snot need to bring half of a spare engine with you everywhere.
(for the record you DO NOT need to pull the motor to change the head gaskets if you ever need to. I don't know where some of these folks get their information, it is obviously not first or even second hand experience).
Neil2
*Edit*, BTW where are you located, CA?
JeffRobenolt
JeffRobenolt is offline
PostPosted: Thu Jan 23, 2014 11:43 am    Post subject: Reply with quote
They sorted out the internal head gasket leak and gained an external leak.
Make sure you get your gaskets from Subaru or allwheeldriveauto
Here is a link that will tell you all you would ever want to know about Subaru head gaskets
http://allwheeldriveauto.com/subaru-head-gasket-problems-explained/
Jeff
jfats808 wrote:
Most, some, few is not all. You can always learn something from everyone , even the fool.
zippyslug31
zippyslug31 is offline
PostPosted: Thu Jan 23, 2014 3:29 pm    Post subject: Reply with quote
Certainly would be easier to do the belts with the motor sitting on an engine stand, but aren't they "pretty easy" to do even with the motor installed?
previous:
'80 westy
current:
'90 syncro westy 2.5L subi, triple knob, 16" wheels.
'84 sunroof van, 2.1L motor.
Howesight
Howesight is offline
PostPosted: Thu Jan 23, 2014 6:12 pm    Post subject: Reply with quote
Depending on the adaptor (SC, Outfront, Kennedy, RMW), access to the timing belt area varies. It's not just that. You also need to remove all accessory belts, your coolant crossover pipe (unless you have a reversed coolant manifold), remove the accessory drive tensioners, remove your muffler, and on and on. No sane Subaru tech would change the timing belt without changing the water pump. So you are draining coolant also. Then you are filling, burping etc.
If the engine is out, it is a breeze doing all these things and you don't spend hours stooped over. At least that's my experience. At a minimum, you will want to change cam seals, meaning the valve covers are coming off - - not a comfortable job under the van.
The head gasket job is easy on the 2.2 or 2.5. Subaru head gaskets are not something that might go wrong. Instead, it's best to think of them as consumable items. When you inevitably have a running issue in future (because sensors do fail), you will not be wondering if the issue has to do with a failing head gasket, timing belt or water pump.
'86 Syncro Westy SVX
whynotvw
whynotvw is offline
PostPosted: Thu Jan 23, 2014 9:04 pm    Post subject: Reply with quote
LOL Yes sir, thanks Ben,
Question, I have two choices, One is with full ej25 with the full ej25 wiring harness with complete rebuild.
ej25 short block with ej22 heads so (franenmotor) same complete rebuild. i can use my current ej22 wiring harness With this set up I save money on wiring harness
so what would you do.? anyone
ftp2leta
ftp2leta is offline
PostPosted: Fri Jan 24, 2014 7:03 am    Post subject: Reply with quote
Jeff
Voila!
Worse case it's a leak at the lower oil return passage (bottom).
Engine lowered for head gasket change (2009, made a terrible stupid mistake wile doing the timing and bent 2 valves - 2 hours job):
Some reading for you guys (hidden page on my site):
http://www.benplace.com/subaru_25_bent_valve.htm
That said, my 2 personal car are 2 old Subaru (2002), a forester and a legacy. Both have around 200,000km. Both are on original head gasket.
The Forester as BAD piston slap since we owned it (4-5 years).
In my life I had worse problem with Honda's and Toyota's so Subaru's are no worse or better then a lot of other car companies...
furrylittleotter
PostPosted: Fri Jan 24, 2014 7:08 am    Post subject: Reply with quote
Frankenmotor, of course! With Stan's header if possible. I'm building a custom one with even smaller equal length primaries but Stan's is sweet looking!
Neil2
