cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Wed Feb 07, 2018 9:20 pm Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
Malokin Martin wrote: |
They make a milled modified nose cone now for this right? |
Yep. But for the cost of that you could make a dozen of these, at least. And this uses stock mounts that are readily available. _________________ nothing |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
oakman Samba Member
Posted: Wed Feb 07, 2018 9:22 pm Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
cdennisg wrote: |
Yep. But for the cost of that you could make a dozen of these, at least. And this uses stock mounts that are readily available. |
I really like the simplicity of the mount. _________________ Brandon |
Posted: Wed Feb 07, 2018 9:32 pm Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
oakman wrote: |
cdennisg wrote: |
I really like the simplicity of the mount. |
Now that I see the price of the rancho nosecone (looks like a damn nice piece) I will change my estimate to about three dozen of Jason's simple mounts for the same price. _________________ nothing |
jason Samba Member
Posted: Wed Feb 07, 2018 11:34 pm Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
It cost $6 for the plate steel, can make 66 of them. That nosecone looks really nice but it’s like $100 cheaper than a new trans. Mine is cheap, doesnt push the trans back and uses stock rubber mount that you can change without removing trans. |
Posted: Thu Feb 08, 2018 9:01 am Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
jason wrote: |
I was including the cost of paying a shop to cut them in my estimate. If you have the CNC plasma cutter already, that really cuts the cost. _________________ nothing |
jason Samba Member
Posted: Thu Feb 08, 2018 9:27 am Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
I figured cutting them with a hacksaw, drills and using the pdf. |
Posted: Thu Feb 08, 2018 3:26 pm Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
jason wrote: |
What are we, Neanderthals? _________________ nothing |
jason Samba Member
Posted: Thu Feb 08, 2018 4:23 pm Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
I know right. I have a lot more time than money lately. |
butty Samba Member
Posted: Tue Feb 20, 2018 3:28 am Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
Did you have to shave excess rubber off the front of the rubber mount ? where it bolts to the adaptor plate ? |
jason Samba Member
Posted: Tue Feb 20, 2018 7:24 am Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
Depends on the mount. Some have rubber, some don't. I did on mine. Cut it with razer and pelled off. On the plate steel part. |
butty Samba Member
Posted: Tue Feb 20, 2018 7:30 am Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
jason wrote: |
Cheers thought so thanks . |
Milanche77 Samba Member
Posted: Mon Jun 18, 2018 12:49 pm Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
hello, do you need to modify bus nose cone to enter in the hole? |
jason Samba Member
Posted: Mon Jun 18, 2018 7:43 pm Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
I don't remember clearancing anything. I would check it, some are shaped a bit different. |
jeffros 58 Samba Member
Joined: January 01, 2009 Posts: 349 Location: jackson mi
Posted: Mon Apr 15, 2019 7:01 pm Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
You say you have the file and would share ? I would like to make this for my 1957 SC . |
jason Samba Member
Posted: Mon Apr 15, 2019 9:47 pm Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
Pm your email |
dickie Samba Member
Joined: March 22, 2004 Posts: 275 Location: southern alberta
Posted: Thu Nov 14, 2019 8:08 pm Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
I used your PDF...thanks. Then cut it out using a jig saw and some files. Worked out perfectly. Everything lined up and bolted into place, even the shifting coupler fit up amazingly well. My only problem is with the two small threaded holes on each side of the original cradle mount. The holes that are there seem to be somewhat rusted out so that the 8mm coarse thread bolts that I have will not thread in, the threads are too small to grab onto anything. Or maybe I am using the wrong size bolt. Can anyone let me know what size bolt it should actually be there? It is the last step to finishing off mounting my tranny...hate to have to remove the whole transaxle in order to tap out those two holes for a larger bolt. Or perhaps there is another solution? Thanks. |
b-man Samba Member
Posted: Thu Nov 14, 2019 8:47 pm Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
dickie wrote: |
You’re using the wrong size bolts, they’re 10mm thread.
_________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle |
dickie Samba Member
Posted: Thu Nov 14, 2019 8:57 pm Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
oh, ok I will try that. But looking over the original thread, it seems as though the adaptor plate was bolted in using a nut and bolt, rather than using just the bolt into the treaded mount? Thanks. |
jason Samba Member
Posted: Thu Nov 14, 2019 10:51 pm Post subject: Re: Early bus front trans adapter that uses stock rubber mount |
I used bolts on the top. I ended up using button heads for more clearance between the bolt heads and trans. Black ones in picture. |
