t'sunamibus Samba Member
Joined: January 29, 2012 Posts: 202 Location: Westport, Washington
Posted: Sun Jan 26, 2014 9:48 am Post subject: Finally found some good window cranks |
My drivers window is a little stiff towards the top of the door frame and ive broken a set of replacement and aftermarket cranks. Personally I would rather be killed by my cranks in a crash.
I pulled these from a late 70's early 80's Volvo sedan. The snout was a bit long so I cut about 3/16 of an inch off. There is a raised line on the snout and I cut it there and sanded it. The Volvo's pan head screw is correct for the vanagon also and they do clear my aftermarket speakers. These are quite strong and most likely the last time I have to mess with my cranks.
spitsnrovers Samba Member
Joined: December 17, 2005 Posts: 924 Location: Calgary, Canada
Posted: Sun Jan 26, 2014 9:51 am Post subject: |
Wow, nice match! _________________ '88 VW Westfalia
'75 Triumph Spitfire 1500 |
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2238 Location: Olympia, Washington
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Sun Jan 26, 2014 10:16 am Post subject: |
Good alternative. Yeah, the original brown cranks have the life span of a snowflake in a volcano.
Another durable crank is from the Jetta (also available in brown). |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Sun Jan 26, 2014 10:26 am Post subject: |
Now you should mess with your window and see why it doesn't roll up properly.
It's better to fix the problem rather than just create a solution. _________________ 89 Westy 2.1 Auto |
Posted: Sun Jan 26, 2014 10:30 am Post subject: |
It clears the speakers.
Posted: Sun Jan 26, 2014 10:33 am Post subject: |
PDXWesty wrote: |
It's better to fix the problem rather than just create a solution. |
Window seals need attention although ive had much worse on other vehicles...all in good time |
bluebus86 Banned
Posted: Sun Jan 26, 2014 11:06 am Post subject: |
Recommend that you fix the stiff window mechanism, rather than force the window by using a stronger handle. if the window is real stiff, other components will wear faster than normal, specially when you can crank harder with the new handles. I guess if the window seizes up you can add a solid steel handle with an extra long arm for more leverage and force it even more.
fix the problem, don't bandaid it. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Sun Jan 26, 2014 11:25 am Post subject: |
bluebus86 wrote: |
fix the problem, don't bandaid it. |
wow! whats next? |
jkidd152 Samba Member
Joined: June 09, 2009 Posts: 408 Location: Portland, OR
Posted: Sun Jan 26, 2014 11:33 am Post subject: |
This is a video from Go Westy about the window operation. Pretty cool.
http://youtu.be/XqWGx8ZgoQA _________________ '85 Syncro Westy |
bluebus86 Banned
Posted: Sun Jan 26, 2014 12:23 pm Post subject: |
t'sunamibus wrote: |
bluebus86 wrote: |
wow! whats next? |
the regulator can fail (stripped parts), maybe not next, but that would be a failure mode. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Chuey Samba Member
Joined: October 18, 2010 Posts: 858 Location: Oceanside, California
Posted: Sun Jan 26, 2014 12:48 pm Post subject: |
Thanks for posting the GoWesty window video. It didn't actually say anything about how to check or fix problems with the window lifting mechanism. Is there a source (previous thread on TheSamba, perhaps) that will go through the problems that can cause the window to be hard to raise?
Mine is not hard enough that I'm concerned about breaking the handle but I'd like to know if it's a good idea to lube somewhere, with what and possible adjustments I could make.
Also, there's a white nylon guide "button" that rides in the vertical channel inside the door. One of mine is broken. Are those still available?
Chuey |
Posted: Sun Jan 26, 2014 2:07 pm Post subject: |
On the list is renewing my door seals, I had everything apart for paint. The passenger door works great while the last 2 or 3 inches gets stubborn on my divers door. It was a pita wrestling in the wing window frames and seals. In fact I just found that I never installed the screw in the top of the wing window frame...a couple of quick grips to pull it over, install the screw and its all good. I stall plan to replace all the window seals after a new tent, carpet kit and appliances. |
greenraVR6 Samba Member
Joined: January 19, 2011 Posts: 306 Location: Bellingham, WA
Posted: Sun Jan 26, 2014 3:56 pm Post subject: |
Ahwahnee wrote: |
These are what I put in my van. '85-92 golf or jetta handles are an exact fit and definitely an upgrade from the vanagon handles. They easily clear aftermarket speaker covers and they're a dime a dozen at pick n pull/pull a part yards _________________ '88 vanagon*****'91 gti 1.8t*****'04 r32*****'11 suburban z71 |
oldhuldy67 Samba Member
Joined: November 25, 2008 Posts: 506 Location: somewhere with a southern exposure
Posted: Sun Jan 26, 2014 6:31 pm Post subject: |
My old cranks were cranky...then, I found early Jetta window cranks, on the Samba or Ebay, not sure now...right color, and sturdy, but no clearance for door speakers.
Posted: Tue Jan 28, 2014 6:35 pm Post subject: |
oldhuldy67 wrote: |
haha!
your alright dude!
Kinda like me saying im hard on the cranks cause I was born without elbows |
modelttouring Samba Member
Joined: April 08, 2008 Posts: 26 Location: El Sobrante CA
Posted: Tue Jan 28, 2014 7:06 pm Post subject: |
You can get spacers for the window crank handles from a VW cabriolet, late 80's to 90's The back window handles have spacers on them to clear the extra clearance for the top. The spacers and screws will fit Vanagons. |
Posted: Tue Jan 28, 2014 8:10 pm Post subject: |
modelttouring wrote: |
Thanks...good to know. |
K58 Samba Member
Joined: July 01, 2006 Posts: 1173 Location: Santa Barbara
Posted: Tue Jan 28, 2014 10:40 pm Post subject: |
bluebus86 wrote: |
wow! whats next? |
what's next is another dumbass chiming in with a patronizing "fix it right or not at all" type post _________________ Westy HID Projector Retrofit |
rubbachicken Samba Member
Posted: Tue Jan 28, 2014 10:56 pm Post subject: |
i found that with the el cheapo window keep fit window winders, the knob part always cam off of the handle, a trip to ace hardware, and a $1.49 got me wooden knobs for my winder handles, and they've been fine since, i did have to epoxy the screw into the knob, to stop it backing out, but they've been on there 2 years already, without issue _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
