Finally found some good window cranks
Page: Previous  1, 2, 3
dhaavers
dhaavers is offline
PostPosted: Sat Oct 17, 2015 9:06 am    Post subject: Reply with quote
dhaavers wrote:
t'sunamibus wrote:
I just got these from GW & I plan to FILL THEM with JB Weld. They're already
better than the "OE" replacement cranks (also just a batch of cold pot metal...) Rolling Eyes
UPDATE: JB weld-reinforced handle & screw to secure press-fit knob:
Two cranks took a whole small package of JB weld (effectively doubling my investment... Rolling Eyes ) but man, they're pretty solid!
- Dave
Cool
"The WonderVan"
jvan
jvan is offline
PostPosted: Mon Sep 26, 2016 11:18 am    Post subject: Reply with quote
kamzcab86 wrote:
modelttouring wrote:
You can get spacers for the window crank handles from a VW cabriolet, late 80's to 90's The back window handles have spacers on them to clear the extra clearance for the top. The spacers and screws will fit Vanagons.
An FYI, in case anyone is about to go junkyarding:
A) 1991-1993 Cabriolets only.
B) Spacer/adapter is part number 155847363.
C) Will require the 18mm screw too (part #N0142675), along with the base/washer gizmo (part #155837595).
D) The spacer is for the 4x6 rear speaker grille clearance in those years (prior years did not have external speaker grilles due to the little 3.5" speakers mounted behind the panels, therefore not requiring a spacer); it has nothing to do with the convertible top.
Someone early mentioned some years of jettas too, no? How about these? https://www.amazon.com/gp/aw/d/B005ZL497Y/ref=mp_s...ref=plSrch
Or
https://www.amazon.com/gp/aw/d/B0046VNUX8/ref=pd_a...ADPKDTKKTA
tin top.
Farfrumwork
Farfrumwork is offline
PostPosted: Tue Sep 27, 2016 8:32 pm    Post subject: Re: Finally found some good window cranks Reply with quote
^^ I'd like to know too. Is it just the screw that varies (which could be easily overcome), or is the spindle a different diameter/spline?
Both my GW replacement handles broke... and they didn't really clear my speakers either Rolling Eyes
sold Sad -> '85 Wolfsburg Syncro / 'Built' DOHC EJ25 (a great machine!)
'07 Legacy spec.B, road tuned stgII
'17 4x4 Sprinter, stone grey, SMB pop-top, on 33"s
"Blood stains, speed kills - Fast cars, cheap thrills - Rich girls, fine wine - I've lost my sense, I've lost control, I've lost my mind"
dhaavers
dhaavers is offline
PostPosted: Wed Aug 08, 2018 8:48 pm    Post subject: Re: Finally found some good window cranks Reply with quote
OK, forget my JB blob treatment above...lasted barely 10 months of use (van garaged Nov-Mar)... Rolling Eyes
After taking the past 6 years to reluctantly try <almost> every other conceivable option, finally installed
perhaps the last set of window cranks I may ever need:
https://www.amazon.com/gp/product/B0046VNUX8/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
Relatively cheap ($10/pair!), easily clear my aftermarket speakers & are absolutely solid.
Works for me... Cool
- Dave
"The WonderVan"
?Waldo?
?Waldo? is offline
PostPosted: Wed Aug 08, 2018 9:54 pm    Post subject: Re: Finally found some good window cranks Reply with quote
I have a pair of those also. When I got them the knobs were a bit loose/wobbly. I pulled the center plug from the knob, crimped the rivet down a bit more snugly, and reinstalled the plug. Now they are very nice and indeed quite solid.
Ahwahnee
Ahwahnee is offline
PostPosted: Thu Aug 09, 2018 5:52 am    Post subject: Re: Finally found some good window cranks Reply with quote
Now you need one of these...
dhaavers
dhaavers is offline
PostPosted: Thu Aug 09, 2018 7:13 am    Post subject: Re: Finally found some good window cranks Reply with quote
^^^ Wow...except I know I'm not cool enough for that...
Embarassed Laughing Wink
- Dave
"The WonderVan"
Guybrush
Guybrush is offline
PostPosted: Thu Aug 09, 2018 7:26 am    Post subject: Re: Finally found some good window cranks Reply with quote
After breaking a couple cranks, then trying the same cranks with JB Weld filling, I just bought the HD ones from Gowesty. Finish could be better in my opinion, but those are definitely the last set you'll need to buy. It won't take long before you spend at least as much going through the cheap ones.
pbrown
pbrown is offline
PostPosted: Thu Aug 09, 2018 7:49 am    Post subject: Re: Finally found some good window cranks Reply with quote
I had some of those chrome ones on my Squareback when I was 16 but never did the foot pedal.
I’m running the GoWesty cranks on my van and they work great. They clear my 5” speakers too.
Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF
RainierSyncro
RainierSyncro is offline
PostPosted: Thu Aug 09, 2018 10:09 am    Post subject: Re: Finally found some good window cranks Reply with quote
X 3 on the HD GoWesty cranks. The knob came off my standard replacement crank 2 months after I bought it. I then said screw it and got the HD cranks. At $40 each, they are not cheap, but I will never EVER have to try rolling up a window with snapped off cheap plastic knob.
http://www.gowesty.com/product/interior-parts/24648/heavy-duty-high-offset-window-crank?v=
hozbee
hozbee is offline
PostPosted: Tue Aug 14, 2018 8:08 pm    Post subject: Re: Finally found some good window cranks Reply with quote
- Dave
x2
Hated the cheap and flimsy plastic replacement cranks I bought awhile back from one of our longtime vendors. Too loose even with spacers and proper torque. Got the Empi's from Amazon. Nice and solid crank for a relatively cheap price. Absolutely no play when tightened down and easily clears my speaker grills. Most likely the last set of cranks I'll be purchasing too.
singletrackrod
singletrackrod is offline
PostPosted: Thu Aug 16, 2018 7:37 am    Post subject: Re: Finally found some good window cranks Reply with quote
I have been using the Empi's for six or seven years. They occasionally loosen a bit, but other than that, they have been stellar. Recommended.
Ella '89 Full Camper - bit by bit I'm importing the pieces from my wrecked '87
Louise '87 Full Camper - bought her new - zero hours 2.5L subie conversion. She had more add-ons and mods than I could ever count. (lost in an accident 10/25/2020)
'08 Stage 2 STI (sold)
'04 Forester XT
'00 4Runner Limited (sold)
singletrackrod
PostPosted: Thu Aug 16, 2018 7:38 am    Post subject: Re: Finally found some good window cranks Reply with quote
'04 Forester XT
Kirsche Wasserboxer
Kirsche Wasserboxer is offline
PostPosted: Thu Jun 27, 2019 12:36 pm    Post subject: Re: Finally found some good window cranks Reply with quote
After two years of use, the knob broke off the EMPI crank on my driver's door. At $12ish a pair, I'm going to go with them again, as I could get four of these for less than one of the HD cranks from GW. The passenger side is fine, but from day one, the driver side crank knob was always a little too loose. I tried the suggestion above to try to tighten it up, but I think that only hastened its failure.
1990 Westfalia Vanagon
2.1 Wasserboxer
michaelbteam
michaelbteam is offline
PostPosted: Sat Jun 29, 2019 11:50 am    Post subject: Re: Finally found some good window cranks Reply with quote
Another vote for the GoWesty cranks!
Page 3 of 3
