1950split Samba Member
Posted: Tue Jan 28, 2014 6:52 am Post subject: BN4 Copper tubing and fitting specs |
Hi,
I'll be reassembling my BN4 shortly and would like to fit the glass ball filter from a 6v BN4.
I'd like to use, as original, a copper tubing from the T for the carb and heater to the fuel filter.
What is the correct size for the tubing and what type of flaring/nut is used at the end, where it is screwed on the fuel filter ?
Thanks,
Phil |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Tue Jan 28, 2014 7:29 pm Post subject: |
Are you sure it's copper? Im guessing brass. Copper will get brittle with vibration. |
busdaddy Samba Member
Posted: Tue Jan 28, 2014 8:06 pm Post subject: |
Or copper plated steel. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Jan 29, 2014 2:05 am Post subject: |
Thanks for your replies.
It certainly has the color of copper but it is not 100%.
I went to a hydraulic shop this morning and they have the proper nipples that need to be brazed on the tubing. I'll use 6mm Cunifer tubing for its ability to take sharp curves, which is needed for this fuel line. |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Wed Jan 29, 2014 4:14 pm Post subject: |
I recall it being copper plated steel, like the beetle fuel lines are. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Wed Jan 29, 2014 4:41 pm Post subject: |
I'll check when I get home but I'm pretty sure it's all copper. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
BarryL Samba Member
Posted: Fri Jan 31, 2014 7:13 pm Post subject: |
Checked out two units I have. It's definitly copper. Looks to be annealed type M. Someone else can give you the dimensions. The ends are slip-fit sweat-soldered with loose coupler nuts. Looks to be silver solder. |
