Cibie H4 headlights?
mascrappo
mascrappo is offline
PostPosted: Thu Jan 30, 2014 7:50 pm    Post subject: Cibie H4 headlights? Reply with quote
Any of you use Cibie E-code H4 headlights? RockAuto has new for $38 each, I think that is reasonable, but don't anything about Cibie (except usually very pricey). I use Hella now, and no complaints, but 4x4 crowd says Cibie even better? Now let's hear the real (VW) experts opinions.
insane68
insane68 is offline
PostPosted: Thu Jan 30, 2014 8:06 pm    Post subject: Reply with quote
I bought a set of these for mine, I am using some cheap EMPI housings, at least it has a glass lens and metal backing. I plan on buying the Sport Headlights from Mamotorworks to be able to add two extra colored lights to the housing. After installing these H4 lights I did notice that the view was 80% better over the sealed beam original and roughly 30% better than the previous installed Silverstar (crap lights). These lights has a very faint blue glow in my housings but the light it emits is nearly pure white.
http://www.ebay.com/itm/131073569382?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
68 bug, 1500 single port
83 Mercedes Benz 300SD Turbo Diesel
87 Pontiac Trans Am (original with 5 speed)
mascrappo
PostPosted: Thu Jan 30, 2014 8:11 pm    Post subject: Reply with quote
Wow, those should shine into the next county! I do love seeing at night and headlight brands/differences interest me (as everyone on here knows).
insane68
insane68 is offline
PostPosted: Thu Jan 30, 2014 8:15 pm    Post subject: Reply with quote
Well I am all about lighting lol
I have installed all LED lights except headlights on my 68 (all plug in OE plug led lights) and I am very happy with the results. I have tested quite a few different brands and it seems the off brand headlights always seem to out perform the name brands (imagine that right?)
I even used some Yellow H4 Headlight bulbs and could see better than the Silverstars. I could see my yellow on road signs even if I was behind someone before the person in front was past the sign. Although here it it is "ILLEGAL" to have yellow headlights even if you can see better with them. So I chose those to replace the yellow ones for now.
mascrappo
PostPosted: Thu Jan 30, 2014 8:35 pm    Post subject: Reply with quote
I like LED, no tried in bug yet, converted my motorcycle over to them and much brighter. What did you use for flasher?
Yellow bulbs, who would have thought? Everyone going white as they can get these days. Lol
insane68
insane68 is offline
PostPosted: Thu Jan 30, 2014 8:44 pm    Post subject: Reply with quote
I still have the original flasher relay in the car, the bulbs I used were all LED 1157 and 1156 from Autozone. Flashers and turn signals work fine without anything extra. I am not sure if this is something they fixed with the bulbs itself or not but everything seems to be okay. I even put a LED tag light bar from Autozone on it which I am about to swap for 4 LED license plate fasteners as soon as weather permits me to do so.
hitest
hitest is offline
PostPosted: Thu Jan 30, 2014 10:20 pm    Post subject: Reply with quote
mascrappo- funny you mention the 4x4 crowd with these lights. I've cibies in a bug- with stock 6v bulbs behind nonfluted lenses and they were okay. However, I bought a pair of 12v cibies for my '77 FJ-40 and they turned night to day! They were clearly up higher- and had a terrific period-correctness to them. I sold that rig and forgot to pull them! Otherwise- they would be in my '66 deluxe already. Buy the Cibies.
'62 L390 151, '62 L469 117, '63 L380 113, '65 L512 265, '65 L31 SO-42, '66 L360 251, '71 L12 113, '74 ORG 181
FU#5
BugMan114
BugMan114 is offline
PostPosted: Thu Jan 30, 2014 10:39 pm    Post subject: Reply with quote
I went with HID's, and some projector conversion lenses off ebay. the projectors distribute the light evenly, and don't blind the oncoming car. Its a radical difference from the old style glass headlights, and much better then regular H4's
I've used both 4300K and 6000K. 4300K is called OEM white which is as the name suggests just pure white light, and 6000K have a slight tint of blue. 8000K and up are just progressively deeper/ darker blue. 3000K is yellow, for that rally look I suppose. I stayed with the 6000K as it matches with my sky blue paint.
1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!!
Joel
Joel is offline
PostPosted: Fri Jan 31, 2014 1:11 am    Post subject: Reply with quote
Don't expect miracles from the blue bulbs, they throw off a nice cool blue light but that blue glass actually acts as a filter and reduces light output in most cases.
Not only that most of them are cheap garbage made in China.
I got a comparison pic somewhere of my bug with a blue bulb in one side and standard but same wattage in the other, the clear bulb had far more intense light and range.
Theres plenty of reviews on the net of all the different type H4 bulbs.
I'm very fussy with my lighting doing so much country driving at night.
I've found 100/90w H4s through relays and 6000K HIDs in hella driving lights leaves even the upmarket euro cars lights in the dark so to speak.
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
insane68
insane68 is offline
PostPosted: Fri Jan 31, 2014 1:45 am    Post subject: Reply with quote
Yea these "Platinum White" H4s I ordered are 100/90w and I tried the Sylvania Silverstars (about $60 per set) and these cheaper Korean made are alot brighter. I did notice one difference in these new lights and the yellow bulbs I replaced. The yellow light looked as if it shined further to road signs and reflectors on the road, I mean I swear I could literally see signs from nearly 1/2 mile away on a flat road and reflectors about the same. The new lights do work well but it is more of a white reflection on signs that looks about 1/4 mile away but the light itself is brighter and a little wider on the road. I believe the yellows were 3500k lights.
Captain Jacques
Captain Jacques is offline
PostPosted: Fri Jan 31, 2014 5:18 am    Post subject: Reply with quote
I think they're making blue bulbs to give the Xenon look, whilst saving you a few thousand bucks.
Safe Sex: The Next Best Thing To Being There.
'75 Super Vert (Carbed)
1989 Lada Niva
2000 SL320 Panoramic
2001 Alfa 156 Sportwagon Selespeed
mascrappo
PostPosted: Fri Jan 31, 2014 6:52 am    Post subject: Reply with quote
I am reaching, do you know which ones you got at Autozone, part #? My moto gave me fits when I changed to LED is why I asked.
mascrappo
mascrappo
PostPosted: Fri Jan 31, 2014 6:56 am    Post subject: Reply with quote
I wonder if the height to center of headlight is playing a key role?
I also forgot to pull a set of lights out of a truck I sold, still regret it 20yrs later LOL.
I like the Cibie look better than Hella in that Cibie has convex/rounded lense, not flat. But I am not sure for that alone I am willing to shell out $100.
mascrappo
PostPosted: Fri Jan 31, 2014 6:57 am    Post subject: Reply with quote
I would like to see a pic of it, sounds like a nice setup.
mascrappo
PostPosted: Fri Jan 31, 2014 7:00 am    Post subject: Reply with quote
I know you would show up Joel. How about Cibie? I am using your series Hellas now, stock setup. I am a sucker for brand name headlights on sale, hard to pass up a deal...
insane68
insane68 is offline
PostPosted: Fri Jan 31, 2014 8:48 am    Post subject: Reply with quote
I don't exactly but I do remember the ones I used in the tail lights were 1157 socket for the brake/parking light socket, 1156 socket for the turn signal and reverse lights and they were all red LED for the rear. The front was 1157 socket that was amber. They don't offer too many if not but one brand LED replacement lights which I believe Pilot was the brand name.
hitest
hitest is offline
PostPosted: Fri Jan 31, 2014 8:56 am    Post subject: Reply with quote
That's awesome! In all fairness, my Cibies for the FJ came from scrapyard- got them for $2 a pair. The FJ's height may have helped- but I expect the 12volts in a bug to be just as effective. The set I have waiting in the wings are flat Cibies from a swap meet that will go in my '71 beetle- but they do lack the cool convex look. Any swaps in your area? I'm sure a pair will drop in.
In a side note: sorry insane68 thinks this is his show... he'll learn about threadjacking I'm sure.
FU#5
mascrappo
PostPosted: Fri Jan 31, 2014 9:12 am    Post subject: Reply with quote
hitest $2???????????? You suck! Smile Maybe I will shop around the swap meets and see what turns up!
I like the rounded look on a bug, round bug, rounded headlight! The flat Hellas are OK, but personal preference is rounded.
insane68, pay no attention to hitest, I appreciate your LED input, albeit, I think we were talking about headlights? LOL
I will drop by Autozone this weekend and see what they got. The last thing I want to do is go through flasher issues, bike was a pain in the a$$.
insane68
insane68 is offline
PostPosted: Fri Jan 31, 2014 9:16 am    Post subject: Reply with quote
Well I still have original wiring, flasher relay, and still running the generator and I have had zero issues. Yes we were talking about headlights. lol
