AlmostHeavenWV_VW Samba Member
Posted: Fri Mar 15, 2019 7:55 pm Post subject: Re: Windshield Washer Electric Pumps? |
Buggeee wrote: |
Tim and crew...
My Super is a 1972. It originally had the air-pressure washer bottle and the wiper stalk on the steering column had the rubber washer tubes going in and out of it for some kind of pressure switch.
The air-pressure washer system is gone and I have purchased a water bottle with an electric motor in it.
Before I install a push botton in my dash or something, I am wondering if the stock wiper stalk on the Super Beetle has an internal electric switch already. And, if so, I am wondering which prongs leading out of the steering column wiring harness would be used to signal the electric washer pump.
Thank you all for your anticipated generosities. |
Buggeee,
No beetle (except 1979+ and some Mexi-beetles I believe) have any 'electrical switch' for the windshield washer. Essentially, the washer 'switch' is really just a valve which allows the pressurized fluid (from the bottle) to flow through the wiper stalk 'valve' and squirt the windshield.
There are those who 'adapted' the stock stalk to make it electric:
https://www.thesamba.com/vw/forum/viewtopic.php?t=502329&highlight=washer+switch+electric
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20
But I personally just put a push button in next to the steering column and called it a day
Happy bug'n Buggeee! _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Meiang Samba Member
Joined: September 27, 2016 Posts: 656 Location: Perth, Western Australia
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11739 Location: Redding, CA
Posted: Fri Mar 15, 2019 8:07 pm Post subject: Re: Windshield Washer Electric Pumps? |
I remember Joel from Australia speaking about a switch connection on some stock washer arms at the column. Can’t remember which thread, but there were photos showing this connection at the stalk.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2400 Location: Gladstone, Ore
Posted: Fri Mar 15, 2019 8:16 pm Post subject: Re: Windshield Washer Electric Pumps? |
Here's the old thread for that. some of the pictures are gone.
Aftermarket 72 and up column wiper switches had the extra BLACK wire for the electric washer pump, mine had one when I got the car and the intermittent mod with the extra relays is swell.
https://forums.aussieveedubbers.com/viewtopic.php?tid=86544 _________________ 1972 1302
HPMX 40's & 019 |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4390 Location: Stuck in Ohio
themrfreeze Samba Member
Joined: June 29, 2018 Posts: 62 Location: Rochester NY
Posted: Sun Mar 24, 2019 2:49 pm Post subject: Re: Windshield Washer Electric Pumps? |
I installed one of these kits in my '68 last summer. The reservoir/pump and some of the hoses are good, the rest of the kit is a joke and should be discarded.
I ran power through an inline fuse to a momentary button mounted in the dash...lights up blue when pressed for a nice color-coded effect, lol. Reservoir is mounted to the back of my spare tire using some plastic-handled nuts and bolts to keep it out of the way yet make it a tool-less effort to remove it in case the tire is needed. Fluid hose connects directly to the washer nozzles. It's simple and works great. |
