Coat hooks
russ cummings
russ cummings is offline
PostPosted: Sun Feb 02, 2014 9:54 am    Post subject: Coat hooks Reply with quote
Does anyone know how many coat hooks came on the deluxe bus ?
PostPosted: Sun Feb 02, 2014 9:58 am    Post subject: Reply with quote
3.
2 on the driver's side
1 on the passenger side, behind the rear cargo door.
This last one is the one with the grab handle.
There is only 1 grab handle.
russ cummings
PostPosted: Sun Feb 02, 2014 10:22 am    Post subject: coat hooks Reply with quote
Thank you so much for the quick reply. Russ
CaLiBus
CaLiBus is offline
PostPosted: Tue Feb 04, 2014 9:02 am    Post subject: Reply with quote
Does any one know the pitch size for the screws?
NVNATIVE
NVNATIVE is offline
PostPosted: Tue Feb 04, 2014 9:17 am    Post subject: Reply with quote
Everett,
Are you saying there are 2 hooks driver side right behind the drivers head? Then one hook passenger side behind their head, then one grab handle where?
Sorry I'm a little slow this monring....not following along Sad
64' Notch (Notcho)
67' 13 Window Deluxe (Maxwell)
turkis-deluxe
Samba Security
turkis-deluxe is offline
PostPosted: Tue Feb 04, 2014 9:28 am    Post subject: Reply with quote
NVNATIVE wrote:
Everett,
No, there is two hooks on the drivers wall but only one at the B pillar by the drivers door.
The second hook goes on the wall above the back seat. Smile
PostPosted: Tue Feb 04, 2014 9:30 am    Post subject: Reply with quote
Passenger side pic
To the left in the photo is the rear cargo door, I am sitting on the back seat taking this photo
NVNATIVE
NVNATIVE is offline
PostPosted: Tue Feb 04, 2014 9:39 am    Post subject: Reply with quote
Ok gotcha....
In my 67 deluxe the coat hooks look like big round white buttons. And i am missing the grab handle at the rear there....
Should mine have those fancy metal hooks in that picture?
64' Notch (Notcho)
PostPosted: Tue Feb 04, 2014 9:42 am    Post subject: Reply with quote
Coat hook screw thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=162772
This thread says
M4 X 0.7
NVNATIVE wrote:
Ok gotcha....
The aluminum ones (that style) are 59-63 only.
58 and earlier Deluxes also have aluminum coat hooks but they are a different shape.
64-67 are the little plastic hooks. They mount with sheet metal screws.
NVNATIVE
NVNATIVE is offline
PostPosted: Tue Feb 04, 2014 10:10 am    Post subject: Reply with quote
Ok sounds like I have the right pieces parts. i just need the strap for the rear....
Thanks for the info...
John
64' Notch (Notcho)
easy e
easy e is offline
PostPosted: Tue Feb 04, 2014 11:03 am    Post subject: Reply with quote
52-58 are less pointy
aka: Evan
CaLiBus
CaLiBus is offline
PostPosted: Wed Feb 05, 2014 4:31 pm    Post subject: Reply with quote
turkis-deluxe wrote:
NVNATIVE wrote:
Everett,
Here's what is left of an early style S hook for passenger side. Salvaged to get to the original slotted LONG screws.
CaLiBus
CaLiBus is offline
PostPosted: Wed Feb 05, 2014 4:35 pm    Post subject: Reply with quote
Here is the back side showing the mounting plate inside pillar.
