Sotobaggins Samba Member
Joined: February 23, 2016 Posts: 264 Location: Orlando, FL United States
Posted: Wed Oct 09, 2019 5:38 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
adams115 wrote: |
Hello, I am brand new here. My name is Lorenzo and I'm a missionary in Guatemala. My beetle is a 97 1600i motor and it's my daily driver. It's always loaded with stuff and climbing mountains. Recently everytime I come to a stop the idle starts surging up and down. If I kick the pedal quickly sometimes it will even out. I have a OBD2 scanner that works on my other vehicles but not this one. Any ideas I could try? |
there is an engine carb/throttle body cleaner called seafoam its good for cleaning out the engine and throttle body either as a engine cleaner and or straight in the tank it will help good luck if all fails try mercadolibre.com.mx and look for a new throttle body _________________ 2001 Ultima Clasico Edicion Mexibeetle
2003 Black GTI 1.8T |
concpt Samba Member
Joined: September 19, 2018 Posts: 27 Location: Powder Springs, GA
Posted: Wed Oct 09, 2019 7:35 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I had the same issue with my 98. It is either the idle speed sensor (black round thing on back side of intake manifold below throttle body or it could be an air leak in the green line that runs from the engine to the computer below the back seat. I would take some crab cleaner and spray the green line as the car idles and see if it smooth out, if so its leaking. I had a green hose disconnect inside the computer box and took for ever to get it right. |
radstude Samba Member
Joined: January 29, 2005 Posts: 397 Location: Lynchburg Va.
Posted: Thu Oct 10, 2019 7:32 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Hopkins, Do you have part number for your lower clear back up light? |
Posted: Thu Oct 10, 2019 6:49 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
radstude wrote: |
Just to let you know its an aftermarket part which can be found in any catalog. Also was a fav of the Type3 _________________ 2001 Ultima Clasico Edicion Mexibeetle
hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Thu Oct 10, 2019 7:22 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
radstude wrote: |
It's a Hella light PN# 2ZR 003 030 (clear lens).
Soto is correct, the light is an aftermarket light and is still listed in the current Hella catalog.
BTW the light is available with a red lens (could be used for a rear fog light or brake light):
Hella: 2NE 003 030
I originally bought the one with a red lens to replace a cheap rear fog light that was on my car when I bought it. At that time all I wanted was a Hella light and spotted the one I bought on eBay. A couple years later I wanted to add the backup light with one that would match the rear fog light.
It took a bit of searching but I found the backup light. The housings and shape of the lens are identical between the two lights. _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
Posted: Fri Oct 11, 2019 1:04 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I like your set up, I have a NOS 911 rear fog lamp, which is the same.
I can always use more when backing up. With your numbers, I found one on EBay UK. Thanks Here my fog lamp
hopkin Samba Member
Posted: Fri Oct 11, 2019 3:46 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
radstude wrote: |
I like your set up... |
I hooked the reverse light up to the passenger side reverse light (using connector, see below) in the lens and ran a blue wire (same colour as VW used for reverse light), through the existing tube:
All lights on!
Both lights are mounted using the bumper bolts, no drilling.
Very simple hookup and easily reversed (no pun intended) if you change your mind on the setup. _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
Posted: Fri Oct 11, 2019 8:00 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Thanks! Boy that look good! |
antonb Samba Member
Joined: December 08, 2016 Posts: 239 Location: Moscow/Russia
Posted: Mon Oct 21, 2019 5:46 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Greetings all!
September 1, gathered a large number of machines with air cooling, at the meeting were VW Beetles and buses and the representatives of the Soviet car industry, the aircooled soviet ZAZ 965-968 models.
Visited the Museum the Engines of October, and drove on a warm autumn Moscow.
We should meet more often!
Good day everyone!
_________________ VW Käfer (Vocho), First registration date in Deutschland: 14/09/1984, Engine 1200.
(Hecho en México) |
hopkin Samba Member
Posted: Sun Nov 03, 2019 5:47 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Back in August I replaced the oil seals in my engine:
At that time I noticed the front wheel bearings were loose, so I tightened them and put my Antares rims back on the car, no problem!
Well, during the winter I store the car with the stock rims mounted:
After tightening the wheel bearings the stock rims rubbed on the brake calipers. I ordered some spacers from cip1 and picked up some longer wheel lugs (from a MK II Golf and/or Jetta).
You can see how much longer the ‘new’ lugs are, stock lug is on the right. (The head is 17 mm, the stock lug is 19 mm).
As the stock rims never rubbed before, I can only guess that the wheel bearings have always been loose, I never noticed and I guess I was lucky. When I inspected them (when I tightened them), they seem to be fine.
I have a new set just in case!
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Mon Nov 04, 2019 2:02 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
hopkin wrote: |
After tightening the wheel bearings the stock rims rubbed on the brake calipers. |
I have difficulties in understanding how's that possible. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
hopkin Samba Member
Posted: Mon Nov 04, 2019 6:46 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
GArBa wrote: |
I have difficulties in understanding how's that possible. |
I can see that, but I can't think of any other explanation as that is the only thing that changed since last year. Any other ideas? _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
73buggy Samba Member
Posted: Sun Nov 10, 2019 8:12 pm Post subject: Brake fluid to used on a MEX 2003 |
Hello.
I need help to find the correct brake fluid to use in my Mex 2003.
Is time to replace all the brake fluid. The car has 14,000 Km and I am the only owner. The Mex instructions manual, on page 27, stated to use the following brake fluid NOM174LFD 13 or 4, but I cannot find it.
Please let me know what today brake fluid I can use to replace it. That I cannot have problem with master cylinder, calipers and rear brake cylinders, also the rubber hoses. If I not wrong using the incorrect brake fluid can do a damage on the brake systems
Maybe Antonio Trejo knows what is the correct brake fluid to be used on my Mex 2003.
THANKS |
hopkin Samba Member
Posted: Sun Nov 10, 2019 8:45 pm Post subject: Re: Brake fluid to used on a MEX 2003 |
73buggy wrote: |
Hello.
THANKS |
When I did my brakes a couple years ago I flushed the brake fluid, this is what I used:
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
Posted: Sun Nov 10, 2019 9:40 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Thanks for the reply.
Do you know where I can buy this brake fluid in US?
Regards |
hopkin Samba Member
Posted: Mon Nov 11, 2019 11:45 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
73buggy wrote: |
Regards |
73B: You don't need the stuff I used, there is a spec called out in the second picture, just look for brake fluid that shows that. It's pretty standard, so you should be able to find what you need just about anywhere. _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
Posted: Mon Nov 11, 2019 3:27 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Hello
Thanks for the info
Regards |
Posted: Mon Nov 11, 2019 9:08 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
at any auto parts store I like O'Riellys the best since it was a great store for VW parts in Oklahoma... _________________ 2001 Ultima Clasico Edicion Mexibeetle
alikatcraig Samba Member
Joined: September 09, 2007 Posts: 556 Location: Anaheim, CA
Posted: Tue Nov 12, 2019 10:55 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Does anyone have Antonio's direct email address to hand please? Going through his ads is not getting a response. _________________ 1967 Ghia
1971 Deluxe Microbus
1974 Convertible Bug
1973 Standard Bug
1998 Mexican Bug |
Antonio Trejo VW Parts Dealer
Joined: December 17, 2003 Posts: 937 Location: Mexico City
