Official Mexican / Brazilian Beetles - All years
Page: Previous  1, 2, 3 ... 75, 76, 77 ... 190, 191, 192  Next
Willard001
Willard001 is offline
PostPosted: Sun Apr 22, 2018 4:24 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Thanks - interesting. Makes sense- Mexico City is 2,000 m above sea level..
Sotobaggins
Sotobaggins is offline
PostPosted: Tue Apr 24, 2018 12:09 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
strange crackling and buzzing coming from the back by the computer and the distributor cap.... No codes very worried anyone have this problem before ???
Let me know.
Thanks
2001 Ultima Clasico Edicion Mexibeetle
2003 Black GTI 1.8T
hopkin Premium Member
hopkin is offline
PostPosted: Tue Apr 24, 2018 12:36 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Let me know.
Thanks
Could be the coil, my coil made a similar noise. It never failed but I did replace it with a cheap one I found on Amazon. That one failed after a year, so I bought an OEM one from Antonio, which has worked fine for the past few years.
1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car)
GArBa
GArBa is offline
PostPosted: Tue Apr 24, 2018 12:37 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
what you mean "by the computer and distributor cap"? they are quite far apart, the computer (ECU) is below the seat and the distributor on the engine. you mean both are buzzing?
cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v
GArBa
GArBa is offline
PostPosted: Tue Apr 24, 2018 12:53 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
didn't notice your answer as we posted at about the same time, coil may be a possibility. Personally I'm using a Beru coil and have no issues with it. my old one didn't make any noise but Temic coils can go bad. It's a part used on a lot of watercooled VWs too, so any reputable brand should work.
cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
hopkin is offline
PostPosted: Tue Apr 24, 2018 1:44 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
GArBa wrote:
... Personally I'm using a Beru coil and have no issues with it. my old one didn't make any noise but Temic coils can go bad...
I just checked my car, I have a Temic installed, so far no problems but every once it a while it buzzes when I turn the key to the on position (but not when the engine is running [that my getting old ears can hear Smile ]).
Maybe I'll see if I can locate a Beru coil for a spare.
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
Sotobaggins
PostPosted: Tue Apr 24, 2018 9:14 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
"what you mean "by the computer and distributor cap"? they are quite far apart, the computer (ECU) is below the seat and the distributor on the engine. you mean both are buzzing? Garba'
Yes Sir thats where buzzing is coming from not hearing it from the coil.... so from what you hand Hopkins have said possible coil?
Thanks
Sam
2003 Black GTI 1.8T
GArBa
GArBa is offline
PostPosted: Wed Apr 25, 2018 12:10 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
buzz near the distributor can be from a bad coil, buzz at the ECU, no idea. unless your connector has somehow come loose.
cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
antonb
antonb is offline
PostPosted: Wed Apr 25, 2018 7:25 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Today I am ready with new season Wink
[/img]
VW Käfer (Vocho), First registration date in Deutschland: 14/09/1984, Engine 1200.
(Hecho en México)
Sotobaggins
PostPosted: Wed Apr 25, 2018 10:47 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Garba: thanks for the pointers the buzz is in the distributor its self I will look into a new coil thanks again for the advice ....
PS Antonb car looking good
2003 Black GTI 1.8T
antonb
antonb is offline
PostPosted: Wed Apr 25, 2018 11:07 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
thanks bro!
(Hecho en México)
RedBug99
RedBug99 is offline
PostPosted: Wed Apr 25, 2018 1:29 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
So, I'm replacing my heat exchangers. I've got my car lifted on jack-stands and the rear-wheels off. My attempts to loosen the top nut where they connect to the exhaust manifold have been fruitless. Unless I'm missing something (hoping that I am), it seems as though I'll need to drop the engine to access them properly. Any advice on this topic would be greatly appreciated.
hopkin is offline
PostPosted: Wed Apr 25, 2018 4:48 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
You will need to remove the fuel injectors and rails if you drop the engine. The instructions on 1600i.de says that it can be done without, but I tried to remove my engine with them on, no luck.
I had a difficult time re-positioning the engine to remove them, but once they were off it was pretty easy to remove the engine.
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
RedBug99
RedBug99 is offline
PostPosted: Wed Apr 25, 2018 5:16 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
hopkin wrote:
[You will need to remove the fuel injectors and rails if you drop the engine. The instructions on 1600i.de says that it can be done without, but I tried to remove my engine with them on, no luck.
Hopkin, if I'm hearing you correctly, I do need to remove the engine to replace the heat exchangers?
hopkin is offline
PostPosted: Wed Apr 25, 2018 8:33 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
No, I was only commenting on my experience, if you have to remove the engine.
But, as I look into my crystal ball, I predict a similar project in my near future:
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
antonb
antonb is offline
PostPosted: Mon Apr 30, 2018 12:59 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Good afternoon!
The season is officially open, in a week around 200 kilometers I did.
Today was excellent weather and we since morning were engaged in car.
During the winter "doggie" of the fixer of the hand brake lever took off, it was necessary to adjust the hand brake and to replace a lever casing.
1. I replaced a washer reservoir on original with the electric pump which was put in a drain since 1982, but on this model I was pneumatic which used air pressure in a spare wheel. Unfortunately. a complete set in that to find anywhere any more
2. Trifles such as boots and caps are established.
3. Pressed with liqud front torsion bars.
4. High-voltage wires of ignition, and a spark plug are replaced. In 3 and 1 cylinders a situation good, and here 2 and 4 candles strongly black, it is necessary to deal with the carburetor.
5. Mineral oil in the engine is replaced with the most viscous 20W50, and also a filter in the crankcase.
The following steps, replacement of the fuel level sensor and to carry out its calibration. Further already I showed the car to children from ChipsAway Moscow
that tinted some problems on a car body and executed polish of a car body.
Generally we prepare for the VAGBURG festival which will take place in Yakhroma place which situated near Moscow 26.05.2018.
(Hecho en México)
RedBug99
RedBug99 is offline
PostPosted: Sat May 05, 2018 7:36 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Hopkin, I managed to remove my passenger side heat-exchanger. To get at the top nut at the exhaust manifold connection required this cobbled assembly of ratchet extensions—including a wobble-head extension. Documented in this photo for when I put the new one on. Smile
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Sat May 05, 2018 10:53 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Wow.. you gotta love salt on the roads.. Shocked
The Samba member since 2004.
alex857
alex857 is offline
PostPosted: Sun May 06, 2018 2:14 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Played around with my Mexicans a bit:
Washed and waxed my 1983 selvas green Beetle and took my 1984 velvet red Beetle (samtroter Sonderkäfer) for a spin in spring;
PostPosted: Sun May 06, 2018 10:27 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Beautiful photo!
Page 76 of 192
