hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Mon Aug 06, 2018 6:27 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
kbrower68 wrote: |
Looking for some help. Just bought a Mexico beetle and need to replace the muffler/converter. Thoughts on replacing it. Where do I find one?
Thanks Kevin |
Welcome...
Contact Antonio Trejo, you can search for his contact info here on Samba or by the userid PartsVW on facebook. You can replace the muffler/catalytic convertor or there is a cheaper 'sport' exhaust available (if you don't need to do emissions). He will be able to provide cost and availability. _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
kbrower68 Samba Member
Joined: August 05, 2018 Posts: 27 Location: Altoona, PA
Posted: Tue Aug 07, 2018 8:17 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Thanks and I did contact Antonio and he replied right away. Unfortunately I need the the muffler converter for emissions in PA. |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Tue Aug 07, 2018 9:48 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Btw hopkin, there is an o-ring on the filler neck bayonet fitting, I don't have access to mine right now to take measurements unfortunately. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
hopkin Samba Member
Posted: Tue Aug 07, 2018 9:57 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
kbrower68 wrote: |
Many $$ . I bought one a few years ago, along with new heater boxes, crossover pipe, oxygen probe, gaskets, etc. I'll be dropping my engine (maybe later this year) and I'll replace the parts, although I may hold off until my car fails emissions (to extend the life of my newer parts).
We do emissions here once every 2 years, next time for me is 2019. If it passes than I can use my existing setup up until 2021.
GArBa wrote: |
Btw hopkin, there is an o-ring on the filler neck bayonet fitting, I don't have access to mine right now to take measurements unfortunately. |
Thanks, that's good to know. I'll see if I can track one down. I'm in San Diego for a few weeks , so it will be a while before I can get back to my car . _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
Posted: Wed Aug 08, 2018 10:32 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Again sorry with all of the questions but what does everyone use or recommend as far as oil, oil filter and air filter? No manual or marking on the engine. |
hopkin Samba Member
Posted: Wed Aug 08, 2018 11:10 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
No problem with the questions, keep 'em coming....
I use 0w40 Synthetic Mobil:
I buy the oil filter at the VW dealer, sorry I'm not near my car and I don't recall the part number but it is the same one that the watercooled cars use.
I'll post it later, if I can find the number. _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
GArBa Samba Member
Posted: Wed Aug 08, 2018 12:53 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Castrol semi-synt 15W-40 is what I use. Oil filter either MANN W719/5 or W719/30. Air filter can't remember the model number but is the same as a 70s bug. I use the MANN brand also for that. MANN and MAHLE/KNECHT were the OEM for these items. _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
antonb Samba Member
Joined: December 08, 2016 Posts: 239 Location: Moscow/Russia
Posted: Thu Aug 09, 2018 7:31 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
DUP:
Hi, everybody!
The reason of replacement of a steering box - big effort on a wheel.
New steering box TRW brand lie in a garage long ago and I waited for the installation on the car.
Previously having adjusted efforts and a backlash it is installed on the car (advice to all - don't trust factory adjustments).
As some elements didn't touch 35 years - it was necessary to heat and beat out.
As a result 5 hours later the reducer is established, but the wheel remained "heavy".
To understand in what the reason, tie roads, the stabilizer were turned off and it became clear that front spindel of the right wheel is deformed that at turn of a wheel gives effort to torsion levers.
Verdict: its replacement next time.
Are also adjusted the valve, the compression in cylinders is measured, makes 8.2-8.3 atm depending on cylinders.
Also are replaced ignition system elements, wires and the coil, now ignition doesn't flow away, and gets on an electrode of candles because of what the car became more vigorous to run, tests showed 108 km/h at D-engine 34 hp and still there is a small stock, but there was no wish to force the old engine.
Next time we will replace a front right spindel and so on trifles, is what to be engaged, but speed doesn't influence generally.
_________________ VW Käfer (Vocho), First registration date in Deutschland: 14/09/1984, Engine 1200.
(Hecho en México) |
AlmostHeavenWV_VW Samba Member
Posted: Thu Aug 09, 2018 7:14 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
GArBa wrote: |
..... Air filter can't remember the model number but is the same as a 70s bug. I use the MANN brand also for that. MANN and MAHLE/KNECHT were the OEM for these items. |
Engine air filter part #'s for my 1973 bug:
MANN C3474
FRAM CA3373
WIX 42170
Alternate/OEM Part Number(s): 25041032, 25041033, 25041171, 53002184, 53006317, 8953002184, 8996604 _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
wcfvw69 Samba Purist
Posted: Thu Aug 09, 2018 7:22 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Your original steering gear doesn't look to be worn out? The worm gear adjustment still has plenty of adjustment. What was wrong with it out of curiosity? _________________ Contact me at [email protected]
The Samba member since 2004.
hopkin Samba Member
Posted: Thu Aug 09, 2018 7:49 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
kbrower68 wrote: |
I found one of Antonio's pictures that show the part number (VW Brand):
The number shown will be cross referenced to another equivalent VW number (if you go to the dealer). _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
Posted: Fri Aug 10, 2018 12:29 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
hopkin wrote: |
kbrower68 wrote: |
The number shown will be cross referenced to another equivalent VW number (if you go to the dealer). |
Thanks for the filter help. |
Posted: Fri Aug 10, 2018 12:30 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Has anyone attempted the roof rack with the slider roof? Doesn't look like there is enough room.. |
Sotobaggins Samba Member
Joined: February 23, 2016 Posts: 264 Location: Orlando, FL United States
Posted: Fri Aug 10, 2018 3:47 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Well lets put it this way my uncle had a 66 and drove it everywhere and he also had a roof rack he finally removed it back in 77 when he got out of the USAF and never had an issue with the sliding roof or the rack... hope this helps _________________ 2001 Ultima Clasico Edicion Mexibeetle
2003 Black GTI 1.8T |
GArBa Samba Member
Posted: Sat Aug 11, 2018 2:57 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
The open air roof grafted on late mexis is different from a factory ragtop of the 60s. I suspect kbrower is enquiring if the open air plastic surround somehow obstructs a rack install. _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
hopkin Samba Member
Posted: Sat Aug 11, 2018 5:17 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
GArBa wrote: |
The open air roof grafted on late mexis is different from a factory ragtop of the 60s. I suspect kbrower is enquiring if the open air plastic surround somehow obstructs a rack install. |
The roof frame (and roof) sit on top of the cut out area (maybe 1/2 inch or so), and then the roof will bunch slightly when operating (maybe another 1/2 or so), which reduce the clearance between a roof rack and the car. I've never thought to measure or photograph the car with that in mind. (And I'm away from my car for a few weeks).
Maybe post the question on the Mexican Beetle Open Air Facebook page, lots of owners of them are on that page and might be able to answer the question, or maybe even try it out:
https://www.facebook.com/groups/1581580365490543/?ref=bookmarks _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
hopkin Samba Member
Posted: Sat Aug 11, 2018 6:41 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I found another picture in my gallery that shows the oil filter with the part number to ask for at a VW dealer :
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
antonb Samba Member
Posted: Sat Aug 11, 2018 8:45 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
wcfvw69 wrote: |
Your original steering gear doesn't look to be worn out? The worm gear adjustment still has plenty of adjustment. What was wrong with it out of curiosity? |
It is worn out and damaged gasket, wthout grease. _________________ VW Käfer (Vocho), First registration date in Deutschland: 14/09/1984, Engine 1200.
(Hecho en México) |
antonb Samba Member
Posted: Mon Aug 20, 2018 5:34 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Small photo session nearby Moscow river, Russia
(Hecho en México) |
GArBa Samba Member
Posted: Sat Aug 25, 2018 12:32 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
cleaned all the interior... my garage has always been quite dry, now it started with some mold on the running boards and before I could notice it had extended to all the interior rubber-leatherette parts, some even on the seat belts... removed the protective seat covers, applied copious amount of protective spray on all leatherette/plastic/rubber surfaces, cleaned the the steering wheel cover and the OE overmats, sent the seat covers and overmats to be examined by my mother: if possibile I'll wash them, if not... they are cheap.
now I have everything clean, I'll let the smell of the protective spray evaporate overnight leaving the windows down, then tomorrow morning I'll put new moisture-absorbing salt inside and seal the car for a week. that should nail the mold inside the cabin. _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
