Official Mexican / Brazilian Beetles - All years
Page: Previous  1, 2, 3 ... 144, 145, 146 ... 190, 191, 192  Next
GArBa
GArBa is offline
PostPosted: Mon May 03, 2021 10:43 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
nagerjaeger wrote:
Sunz out. Bugz out. 1998 City Car. 24K kilometers. Not a great photo but I'm loving the bug life today.
tornado red rocks!
cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v
nagerjaeger
nagerjaeger is offline
PostPosted: Tue May 04, 2021 9:26 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
I like the gray hubcaps and the black stripe on the bumper.
GArBa wrote:
tornado red rocks!
thedishking
thedishking is offline
PostPosted: Tue May 04, 2021 2:15 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
I am having issues with my '98 Vocho.
A few days ago, I noticed a "stall", or hesitation when leaving a stop light.
It does it at every stop light now.
The car starts perfectly, but it smells rich (gassy). There is also smoke when the car is initially started.
When the car first starts, the accelerator seems fine. However, after running for a brief time, the car will stall if you accelerate quickly.
I can slowly rev the car (very slowly) and get the RPM higher, and then begin to drive.
However, as I am driving, I am unable to really accelerate quickly.
I did check fuel pressure at the rail, and found 35 PSI. I've seen specification is 43 PSI. I don't know if this is an issue or not.
I pulled the codes on VCDS-Lite (new version of Vag Com) and found:
3 Faults Found:
00532 - Supply Voltage B+
07-00 - Signal too Low
Supply voltage out of range
Should be 10 to 16 V
00519
Intake Manifold Pressure Sensor G71 - no signal
-Defective sensor, tubing to manifold
00518
Throttle Valve Position Pot G88, Open circuit or short circuit
-Wiring or defective part
I have tested sensor G71 & G88 with ohm meter, and they look identical to spare units I have.
I did clear the codes and they have not come back yet.
I have also re-soldered the pads on ECU Relay (#30).
I have noticed this unit is warm (not hot) after the car has been running for several minutes.
http://www.1600i.de/1600i-elektronik/relais-steuergeraet/CheckingandrepairingtheECUrelay.htm
The gas tank is clean and fuel lines should be good.
I replaced the fuel pump in January of this year when I cleaned the gas tank.
I also installed new fuel filter at that time.
I have about 11,800 miles on my spark plugs.
Would anyone have any ideas? Could this be a defective #30 relay? Or timing be off?
Thanks for your help!!!
GArBa
GArBa is offline
PostPosted: Tue May 04, 2021 11:19 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
to me it sounds vacuum related. have you double checked the green hose from the manifold to the pressure sensor inside the ECU?
cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
thedishking
PostPosted: Wed May 05, 2021 9:24 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
I have only checked that it is physically connected. I see there is a test that can be done by disconnecting it - and hopefully observing a change.
I will do that.
Also, I have read that fuel pressure regulator may have issues, but I can't seem to find much info on testing / troubleshooting.
GArBa
GArBa is offline
PostPosted: Wed May 05, 2021 10:10 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
I will do that.
IIRC there is a piece of vacuum hose also inside the ECU itself. as for the fuel pressure, was the pump you replaced an original spare or aftermarket? Chinese pumps may be hit and miss. A way to test the regulator would be to check if you have fuel coming back to the swirl pot.
cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
thedishking
PostPosted: Thu May 06, 2021 7:57 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Thank you Garba!!!
It was a cracked hose inside ECU. You called it on vacuum!
It was odd. I pulled the green line off of ECU yesterday, and saw the motor performance suffer instantly.
However, since the issue persisted, I swapped ECU units and problem is gone.
After tearing down old ECU - I found a cracked hose. Hopefully this ECU is still good - just need to get a replacement piece of hose.
To answer your other question - the fuel pump is OEM VW. The aftermarket stuff tends to scare me.
Thank you again for your help!!!!
Pegasín
Pegasín is offline
PostPosted: Thu May 06, 2021 9:42 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
My VAG-COM 311.2n with OBD2 cable only runs with Windows95/XP and didn´t works with modern softwares
So now I'm looking for an scan tool for diagnostic and fault codes. Which is recommended?
I found this model but I don´t know if it works with mexi Digifant '95
Ancel VD500 and Ancel VD700
Better options?
https://www.amazon.com/-/es/funciones-especiales-v...image_auto
nagerjaeger
PostPosted: Thu May 06, 2021 10:15 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
I'm using an XTOOL V401.
https://www.amazon.com/XTOOL-VAG401-Scanner-Actuation-Function/dp/B013LPC40E
Made an adapter for it.
Here is a photo of the screen.
Better options?
Pegasín
Pegasín is offline
PostPosted: Thu May 06, 2021 10:26 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Better options?
That's my OBD II cable, also with "adapter" Very Happy
GArBa
GArBa is offline
PostPosted: Fri May 07, 2021 1:56 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
same here. it is glitchy sometimes but it works.
cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
nagerjaeger
PostPosted: Fri May 07, 2021 6:05 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
The windshield washer pump on my 1998 City Car has never worked. I was able to find a knock off pump on Amazon, an ACI 177113. The only problem is that it is slightly taller than the original. So it is cocked just a bit. I used the original grommet.
This photo shows that it is taller.
Installed. A bit cocked. But it doesn't leak so far. Putting in only a little fluid in case there is a leak. As time goes on if it doesn't leak I'll put in more.
Beetlebaum
Beetlebaum is offline
PostPosted: Sat May 08, 2021 10:28 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
How does that pump work? Maybe I should get one for my (US-spec) '73 Super Beetle, which has never had a working windshield washer system.
1973 Super Beetle
2003 New Beetle
Post your Super here: http://www.thesamba.com/vw/forum/viewtopic.php?t=331999
Beetle Bums VW Club Member
hopkin Premium Member
hopkin is offline
PostPosted: Sat May 08, 2021 1:38 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
The have the original VW of Mexico one at cip1:
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2DBAA%2D955%2D449%2DA
They also have a kit with a switch, I don't know if the tank is the Mexican one:
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D113%2D989%2D453
Note that neither one of these will fit your Super due to the shape of the fender. This one looks like it work for you:
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D133%2D989%2D453%2DB
1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car)
nagerjaeger
PostPosted: Sat May 08, 2021 7:41 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Conceptually it is very simple. Just a positive and negative spade connector with a volume of fluid and a discharge to the washer hose. Here is a kit that will fit your Super Beetle.
https://www.mamotorworks.com/vw/product/vw-1968-1974-universal-12v-windshield-washer-tank-kit-111111
Gerrelt
Gerrelt is offline
PostPosted: Sun May 09, 2021 3:02 am    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
I've replied to this message in the thread about super beetle windows washing:
https://www.thesamba.com/vw/forum/viewtopic.php?p=9633826#9633826
homepage
Beetlebaum
PostPosted: Tue May 11, 2021 1:55 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Thanks for the answers, everybody! Cool
1973 Super Beetle
2003 New Beetle
alikatcraig
alikatcraig is offline
PostPosted: Fri May 14, 2021 12:59 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Spotted on FB. Cheap!
https://www.facebook.com/marketplace/item/21261900...l%7D%22%7D
1967 Ghia
1971 Deluxe Microbus
1974 Convertible Bug
1973 Standard Bug
1998 Mexican Bug
Sotobaggins
Sotobaggins is offline
PostPosted: Wed May 26, 2021 2:46 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Everyones super Quiet...must be out Driving their Bugs.....
2001 Ultima Clasico Edicion Mexibeetle
2003 Black GTI 1.8T
aquavette
aquavette is offline
PostPosted: Sun May 30, 2021 5:16 pm    Post subject: Re: Official Mexican / Brazilian Beetles - All years Reply with quote
Would a '95-'96 mexican beetle have the mounts to add pop out windows under the headliner?
Page 145 of 192
